Trying to refigure out subtitles settings I had
crimson30
Post by crimson30 » Sun Oct 29, 2017 12:49 pm
1. I had UMS on a CentOS server working fine (forced subtitles on everything) streaming to PS3.
2. Wiped server and reinstalled.
3. I can't seem to tweak the settings to get subtitles working on everything again (the way I had it).
When I select files from the #--TRANSCODE--# subfolder, subtitles play just fine... but I'd like to get it working without going to the #--TRANSCODE--# subfolder. I could've sworn I forced transcoding on everything to get it working without going to the subfolder.
May seem small, but I'd rather like to get it working the way I had it and I figure it's probably a simple .conf setting.
debug.zip
(66.14 KiB) Downloaded 56 times
valib
Re: Trying to refigure out subtitles settings I had
Post by valib » Wed Nov 01, 2017 3:03 am
Please follow the Forum rules written in red above and send all files the UMS makes not only log.
Post by Nadahar » Wed Nov 01, 2017 3:06 am
@valib He's probably running headless so the GUI packaging isn't available.
crimson30
Post by crimson30 » Wed Nov 01, 2017 7:06 am
Those instructions seem to be geared toward the GUI. What other files are there to look at for debugging?
Post by Nadahar » Wed Nov 01, 2017 7:28 am
The GUI will also include your UMS.conf and the renderer configuration file(s) for the renderer(s) in use.
crimson30
Post by crimson30 » Wed Nov 01, 2017 9:36 am
Whats' the renderer config file named?
Post by Nadahar » Wed Nov 01, 2017 9:48 am
There are many, it depends on the renderer(s) used. They have a ".conf" extension and can be found inside a folder called "renderers" somewhere in the unpacked UMS files (I don't remember exactly where). You don't have to attach the renderer configuration if it's unchanged.
crimson30
Post by crimson30 » Wed Nov 01, 2017 9:58 am
I didn't mess with the renderer files. Here's UMS.conf.
UMS.conf
(54.3 KiB) Downloaded 63 times
Sami32
Post by Sami32 » Sun Nov 05, 2017 11:25 am
@crimson30 Part of your issue come from that you didn't read our Wiki. Click on the green link into my signature and read it carefully.
You are using the default settings that disable subtitles for english, and that is your case.
Sami32
Post by Sami32 » Sun Nov 05, 2017 11:45 am
@Valib Subtitle type UNKNOWN is displayed instead of SubRip, but showed correctly while parsing the media.
