problem playing movies from external hard disk
I can navigate in my disk from ps3 but when i try to open the movies folder it doesnt show anything inside. if i copy the same move in my internal pc hard drive i dont have this problem. and this is the log
any suggestions?
DEBUG 2013-09-06 14:06:44.730 [main] Reading cred.path: default: "", current: "/root/.config/UMS/UMS.cred"
DEBUG 2013-09-06 14:06:44.730 [main] Error killing old process java.io.FileNotFoundException: /root/.config/UMS/data/pms.pid (Δεν υπάρχει τέτοιο αρχείο ή κατάλογος)
DEBUG 2013-09-06 14:06:44.796 [main] Reading run_wizard: default: true, current: false
INFO 2013-09-06 14:06:44.797 [main] Starting Universal Media Server 3.0.0-a5
INFO 2013-09-06 14:06:44.797 [main] Based on PS3 Media Server by shagrath, copyright 2008-2013
INFO 2013-09-06 14:06:44.798 [main] http://www.universalmediaserver.com
INFO 2013-09-06 14:06:44.798 [main] Build: e795cd371 (2013-09-03)
INFO 2013-09-06 14:06:44.798 [main] Java: OpenJDK Server VM 1.7.0_25 32-bit by Oracle Corporation
INFO 2013-09-06 14:06:44.798 [main] OS: Linux 32-bit 3.8.0-29-generic
INFO 2013-09-06 14:06:44.799 [main] Encoding: UTF-8
INFO 2013-09-06 14:06:44.827 [main] Memory: 682 MB
INFO 2013-09-06 14:06:44.828 [main]
INFO 2013-09-06 14:06:44.829 [main] Working directory: /usr/local/src/ums-3.0.0-a5
INFO 2013-09-06 14:06:44.829 [main] Temp directory: /tmp/universalmediaserver
INFO 2013-09-06 14:06:44.830 [main] Logging config file: /usr/local/src/ums-3.0.0-a5/logback.xml
INFO 2013-09-06 14:06:44.830 [main] debug.log: /var/log/universalmediaserver/root/debug.log
INFO 2013-09-06 14:06:44.831 [main] Profile directory: /root/.config/UMS
INFO 2013-09-06 14:06:44.831 [main] Profile directory permissions: rw
INFO 2013-09-06 14:06:44.832 [main] Profile path: /root/.config/UMS/UMS.conf
INFO 2013-09-06 14:06:44.832 [main] Profile permissions: rw
INFO 2013-09-06 14:06:44.832 [main] Profile name: S.Antonis
INFO 2013-09-06 14:06:44.833 [main] Web conf path: /root/.config/UMS/WEB.conf
INFO 2013-09-06 14:06:44.833 [main] Web conf permissions: file not found
DEBUG 2013-09-06 14:06:45.528 [main] Reading hide_advanced_options: default: true, current: false
DEBUG 2013-09-06 14:06:45.555 [main] Reading maximum_bitrate: default: "110", current: "50"
DEBUG 2013-09-06 14:06:46.179 [main] Reading mpeg2_main_settings: default: "Automatic (Wired)", current: "Automatic (Wireless)"
INFO 2013-09-06 14:06:47.128 [main] Loading MediaInfo library
INFO 2013-09-06 14:06:47.297 [main] Loaded MediaInfoLib - v0.7.59
INFO 2013-09-06 14:06:47.313 [main] Loading renderer configurations from /usr/local/src/ums-3.0.0-a5/renderers
INFO 2013-09-06 14:06:47.324 [main] Loading configuration file: AirPlayer.conf
INFO 2013-09-06 14:06:47.330 [main] Loading configuration file: Android.conf
INFO 2013-09-06 14:06:47.350 [main] Loading configuration file: BlackBerryPlayBook-KalemSoftMP.conf
INFO 2013-09-06 14:06:47.371 [main] Loading configuration file: Bravia4500.conf
INFO 2013-09-06 14:06:47.375 [main] Loading configuration file: Bravia5500.conf
INFO 2013-09-06 14:06:47.391 [main] Loading configuration file: BraviaEX.conf
INFO 2013-09-06 14:06:47.397 [main] Loading configuration file: BraviaEX620.conf
INFO 2013-09-06 14:06:47.403 [main] Loading configuration file: BraviaHX.conf
INFO 2013-09-06 14:06:47.410 [main] Loading configuration file: BraviaW.conf
INFO 2013-09-06 14:06:47.417 [main] Loading configuration file: DLinkDSM510.conf
INFO 2013-09-06 14:06:47.422 [main] Loading configuration file: DirecTVHR.conf
INFO 2013-09-06 14:06:47.427 [main] Loading configuration file: FreeboxHD.conf
INFO 2013-09-06 14:06:47.430 [main] Loading configuration file: FreecomMusicPal.conf
INFO 2013-09-06 14:06:47.434 [main] Loading configuration file: Kuro.conf
INFO 2013-09-06 14:06:47.438 [main] Loading configuration file: LGST600.conf
INFO 2013-09-06 14:06:47.448 [main] Loading configuration file: N900.conf
INFO 2013-09-06 14:06:47.456 [main] Loading configuration file: NetgearNeoTV.conf
INFO 2013-09-06 14:06:47.462 [main] Loading configuration file: OPPOBDP83.conf
INFO 2013-09-06 14:06:47.470 [main] Loading configuration file: OPPOBDP93.conf
INFO 2013-09-06 14:06:47.485 [main] Loading configuration file: OnkyoTX-NR717.conf
INFO 2013-09-06 14:06:47.487 [main] Loading configuration file: PS3.conf
INFO 2013-09-06 14:06:47.508 [main] Loading configuration file: Panasonic.conf
INFO 2013-09-06 14:06:47.518 [main] Loading configuration file: Philips.conf
INFO 2013-09-06 14:06:47.526 [main] Loading configuration file: PhilipsPFL.conf
INFO 2013-09-06 14:06:47.548 [main] Loading configuration file: PopcornHour.conf
INFO 2013-09-06 14:06:47.551 [main] Loading configuration file: Realtek.conf
INFO 2013-09-06 14:06:47.554 [main] Loading configuration file: SMP-N100.conf
INFO 2013-09-06 14:06:47.567 [main] Loading configuration file: Samsung-SMT-G7400.conf
INFO 2013-09-06 14:06:47.580 [main] Loading configuration file: SamsungAllShare-D7000.conf
INFO 2013-09-06 14:06:47.591 [main] Loading configuration file: SamsungAllShare.conf
INFO 2013-09-06 14:06:47.594 [main] Loading configuration file: SamsungWiseLink.conf
INFO 2013-09-06 14:06:47.596 [main] Loading configuration file: SharpAquos.conf
INFO 2013-09-06 14:06:47.599 [main] Loading configuration file: Showtime3.conf
INFO 2013-09-06 14:06:47.611 [main] Loading configuration file: Showtime4.conf
INFO 2013-09-06 14:06:47.623 [main] Loading configuration file: SonyBluray.conf
INFO 2013-09-06 14:06:47.627 [main] Loading configuration file: SonyHomeTheatreSystem.conf
INFO 2013-09-06 14:06:47.640 [main] Loading configuration file: Streamium.conf
INFO 2013-09-06 14:06:47.644 [main] Loading configuration file: TelstraTbox.conf
INFO 2013-09-06 14:06:47.652 [main] Loading configuration file: VideoWebTV.conf
INFO 2013-09-06 14:06:47.655 [main] Loading configuration file: VizioSmartTV.conf
INFO 2013-09-06 14:06:47.662 [main] Loading configuration file: WDTVLive.conf
INFO 2013-09-06 14:06:47.673 [main] Loading configuration file: WMP.conf
INFO 2013-09-06 14:06:47.682 [main] Loading configuration file: XBMC.conf
INFO 2013-09-06 14:06:47.684 [main] Loading configuration file: XBOX360.conf
INFO 2013-09-06 14:06:47.692 [main] Loading configuration file: YamahaRXA1010.conf
INFO 2013-09-06 14:06:47.694 [main] Loading configuration file: YamahaRXV3900.conf
INFO 2013-09-06 14:06:47.703 [main] Loading configuration file: YamahaRXV671.conf
INFO 2013-09-06 14:06:47.708 [main] Loading configuration file: iPad-iPhone.conf
INFO 2013-09-06 14:06:47.715 [main] Please wait while we check the MPlayer font cache, this can take a minute or so.
DEBUG 2013-09-06 14:06:47.716 [main] Launching: ./mplayer
INFO 2013-09-06 14:06:47.836 [main] Finished checking the MPlayer font cache.
INFO 2013-09-06 14:06:47.846 [main] Searching for plugins in /usr/local/src/ums-3.0.0-a5/plugins
INFO 2013-09-06 14:06:47.847 [main] No plugins found
INFO 2013-09-06 14:06:47.877 [main] Registering transcoding engine: FFmpeg Audio
INFO 2013-09-06 14:06:47.882 [main] Registering transcoding engine: MEncoder
INFO 2013-09-06 14:06:47.883 [main] Registering transcoding engine: FFmpeg
INFO 2013-09-06 14:06:47.884 [main] Registering transcoding engine: VLC
DEBUG 2013-09-06 14:06:47.887 [main] Error reading ffmpeg web filters: File '/root/.config/UMS/ffmpeg.webfilters' does not exist
DEBUG 2013-09-06 14:06:47.889 [main] FFmpeg supported protocols: [mms, https]
INFO 2013-09-06 14:06:47.889 [main] Registering transcoding engine: FFmpeg Web Video
INFO 2013-09-06 14:06:47.890 [main] Registering transcoding engine: MEncoder Web
INFO 2013-09-06 14:06:47.891 [main] Registering transcoding engine: VLC Web Video
INFO 2013-09-06 14:06:47.893 [main] Registering transcoding engine: tsMuxeR
INFO 2013-09-06 14:06:47.894 [main] Registering transcoding engine: Audio High Fidelity
INFO 2013-09-06 14:06:47.895 [main] Registering transcoding engine: VLC Web Audio (Legacy)
INFO 2013-09-06 14:06:47.896 [main] Registering transcoding engine: VLC Web Video (Legacy)
INFO 2013-09-06 14:06:47.896 [main] Registering transcoding engine: dcraw Thumbnailer
INFO 2013-09-06 14:06:47.973 [main] Using address /192.168.2.4 found on network interface: name:wlan0 (wlan0)
INFO 2013-09-06 14:06:47.974 [main] Created socket: /192.168.2.4:5001
DEBUG 2013-09-06 14:06:48.107 [main] Sending ALIVE...
DEBUG 2013-09-06 14:06:48.125 [main] Reading uuid: default: null, current: "83c26e81-9009-4cc8-a16a-0fdaf1d1dd3e"
INFO 2013-09-06 14:06:48.125 [main] Using the following UUID configured in UMS.conf: 83c26e81-9009-4cc8-a16a-0fdaf1d1dd3e
INFO 2013-09-06 14:06:48.378 [main] The server is now available for renderers to find
INFO 2013-09-06 14:06:50.677 [New I/O worker #1] No IP filter specified, access granted to /192.168.2.5
INFO 2013-09-06 14:06:50.688 [pool-4-thread-1] Checking IP: 192.168.2.5 for WMP
DEBUG 2013-09-06 14:06:50.705 [New I/O worker #1] HTTP User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50
INFO 2013-09-06 14:06:55.867 [pool-4-thread-1] Renderer WMP found on this address: 192.168.2.5
DEBUG 2013-09-06 14:06:55.872 [pool-4-thread-1] Starting ping -c 3 -s 64000 192.168.2.5
DEBUG 2013-09-06 14:06:55.874 [pool-4-thread-1] Unix process ID (ping): 24136
DEBUG 2013-09-06 14:06:56.035 [Thread-8] PING 192.168.2.5 (192.168.2.5) 64000(64028) bytes of data.
DEBUG 2013-09-06 14:06:56.035 [Thread-8] 64008 bytes from 192.168.2.5: icmp_req=1 ttl=128 time=161 ms
DEBUG 2013-09-06 14:06:57.047 [Thread-8] 64008 bytes from 192.168.2.5: icmp_req=2 ttl=128 time=172 ms
DEBUG 2013-09-06 14:06:57.873 [SpeedStats Failsafe] Stopping Unix process 24136: ping-0
INFO 2013-09-06 14:06:57.875 [pool-4-thread-1] Address /192.168.2.5 has an estimated network speed of: 3 Mb/s
DEBUG 2013-09-06 14:06:58.377 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2013-09-06 14:07:18.378 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2013-09-06 14:10:18.379 [UPNP-AliveMessageSender] Sending ALIVE...
INFO 2013-09-06 14:12:03.069 [UPNPHelper] No IP filter specified, access granted to /192.168.2.8
INFO 2013-09-06 14:12:07.526 [pool-4-thread-2] Checking IP: 192.168.2.8 for PlayStation 3
DEBUG 2013-09-06 14:12:07.548 [New I/O worker #3] HTTP User-Agent: UPnP/1.0
DEBUG 2013-09-06 14:12:11.526 [pool-11-thread-2] Starting /usr/local/src/ums-3.0.0-a5/mplayer -identify -endpos 0 -v -ao null -vc null -vo null -dvd-device /initrd.img dvd://1
DEBUG 2013-09-06 14:12:11.527 [pool-11-thread-2] Unix process ID (/usr/local/src/ums-3.0.0-a5/mplayer): 26697
DEBUG 2013-09-06 14:12:11.529 [Thread-11] MPlayer SB50 (C) 2000-2013 MPlayer Team
DEBUG 2013-09-06 14:12:11.529 [Thread-11] Custom build by SubJunk, http://www.spirton.com
DEBUG 2013-09-06 14:12:11.529 [Thread-11] CPU vendor name: GenuineIntel max cpuid level: 10
DEBUG 2013-09-06 14:12:11.529 [Thread-11] CPU: Intel(R) Core(TM)2 CPU T7200 @ 2.00GHz (Family: 6, Model: 15, Stepping: 6)
DEBUG 2013-09-06 14:12:11.529 [Thread-11] extended cpuid-level: 8
DEBUG 2013-09-06 14:12:11.529 [Thread-11] extended cache-info: 268468288
DEBUG 2013-09-06 14:12:11.529 [Thread-11] Detected cache-line size is 64 bytes
DEBUG 2013-09-06 14:12:11.529 [Thread-11] Testing OS support for SSE... yes.
DEBUG 2013-09-06 14:12:11.529 [Thread-11] Tests of OS support for SSE passed.
DEBUG 2013-09-06 14:12:11.529 [Thread-11] CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNowExt: 0 SSE: 1 SSE2: 1 SSE3: 1 SSSE3: 1 SSE4: 0 SSE4.2: 0 AVX: 0
DEBUG 2013-09-06 14:12:11.529 [Thread-11] Compiled with runtime CPU detection.
DEBUG 2013-09-06 14:12:11.529 [Thread-11] get_path('codecs.conf') -> '/home/simis/.mplayer/codecs.conf'
DEBUG 2013-09-06 14:12:11.529 [Thread-10] libdvdread: Using libdvdcss version 1.2.12 for DVD access
DEBUG 2013-09-06 14:12:11.529 [Thread-11] Reading optional codecs config file /home/simis/.mplayer/codecs.conf: No such file or directory
DEBUG 2013-09-06 14:12:11.529 [Thread-11] Reading optional codecs config file /usr/local/etc/mplayer/codecs.conf: No such file or directory
DEBUG 2013-09-06 14:12:11.530 [Thread-11] Using built-in default codecs.conf.
DEBUG 2013-09-06 14:12:11.530 [Thread-10] libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
DEBUG 2013-09-06 14:12:11.530 [Thread-11] init_freetype
DEBUG 2013-09-06 14:12:11.530 [Thread-10] libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed
DEBUG 2013-09-06 14:12:11.530 [Thread-11] Using MMX (with tiny bit MMX2) Optimized OnScreenDisplay
DEBUG 2013-09-06 14:12:11.530 [Thread-11] get_path('fonts') -> '/home/simis/.mplayer/fonts'
DEBUG 2013-09-06 14:12:11.530 [Thread-10] libdvdread: Can't open file VIDEO_TS.BU.
DEBUG 2013-09-06 14:12:11.530 [Thread-11] Configuration: --enable-static --enable-runtime-cpudetection --disable-vidix --disable-sse3 --disable-sse4 --disable-sse42 --disable-avx --disable-mp3lame --disable-faac --disable-smb --disable-gethostbyname2 --disable-directfb --disable-vesa --disable-svga --disable-librtmp --extra-libs=-lpthread
DEBUG 2013-09-06 14:12:11.530 [Thread-10] Can't open VMG info!
DEBUG 2013-09-06 14:12:11.530 [Thread-11] CommandLine: '-identify' '-endpos' '0' '-v' '-ao' 'null' '-vc' 'null' '-vo' 'null' '-dvd-device' '/initrd.img' 'dvd://1'
DEBUG 2013-09-06 14:12:11.530 [Thread-11] Using nanosleep() timing
DEBUG 2013-09-06 14:12:11.530 [Thread-10] No stream found to handle url dvd://1
DEBUG 2013-09-06 14:12:11.530 [Thread-11] get_path('input.conf') -> '/home/simis/.mplayer/input.conf'
DEBUG 2013-09-06 14:12:11.530 [Thread-11] Reading optional input config file /home/simis/.mplayer/input.conf: No such file or directory
DEBUG 2013-09-06 14:12:11.530 [Thread-11] Reading optional input config file /usr/local/etc/mplayer/input.conf: No such file or directory
DEBUG 2013-09-06 14:12:11.530 [Thread-11] Falling back on default (hardcoded) input config
DEBUG 2013-09-06 14:12:11.530 [Thread-11] get_path('1.conf') -> '/home/simis/.mplayer/1.conf'
DEBUG 2013-09-06 14:12:11.530 [Thread-11] Playing dvd://1.
DEBUG 2013-09-06 14:12:11.530 [Thread-11] get_path('sub/') -> '/home/simis/.mplayer/sub/'
DEBUG 2013-09-06 14:12:11.530 [Thread-11] URL: dvd://1
DEBUG 2013-09-06 14:12:11.533 [Thread-11] Reading disc structure, please wait...
DEBUG 2013-09-06 14:12:11.534 [Thread-11]
DEBUG 2013-09-06 14:12:11.534 [Thread-11] Exiting... (End of file)
DEBUG 2013-09-06 14:12:11.534 [Thread-11] ID_EXIT=EOF
INFO 2013-09-06 14:12:12.712 [pool-4-thread-2] Renderer PlayStation 3 found on this address: 192.168.2.8
DEBUG 2013-09-06 14:12:12.719 [pool-4-thread-2] Starting ping -c 3 -s 64000 192.168.2.8
DEBUG 2013-09-06 14:12:12.741 [pool-4-thread-2] Unix process ID (ping): 26722
DEBUG 2013-09-06 14:12:14.721 [SpeedStats Failsafe] Stopping Unix process 26722: ping-2
DEBUG 2013-09-06 14:12:21.526 [DVDISO Failsafe] Stopping Unix process 26697: mplayer-1
DEBUG 2013-09-06 14:13:18.380 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2013-09-06 14:14:26.689 [New I/O worker #2] Detected encoding for /media/simis/8ACC1C05CC1BE9E9/Βίντεο/Σειρές/Breaking Bad/Season 5/Breaking.Bad.S05E01.Live.Free.or.Die.HDTV.x264-FQM.srt is ISO-8859-7.
DEBUG 2013-09-06 14:14:27.045 [New I/O worker #2] Detected encoding for /media/simis/8ACC1C05CC1BE9E9/Βίντεο/Σειρές/Breaking Bad/Season 5/Breaking.Bad.S05E01.Live.Free.or.Die.HDTV.x264-FQM.srt is ISO-8859-7.
DEBUG 2013-09-06 14:14:27.072 [New I/O worker #2] Detected encoding for /media/simis/8ACC1C05CC1BE9E9/Βίντεο/Σειρές/Breaking Bad/Season 5/Breaking.Bad.S05E02.Madrigal.HDTV.x264-FQM.srt is ISO-8859-7.
DEBUG 2013-09-06 14:14:27.338 [New I/O worker #2] Detected encoding for /media/simis/8ACC1C05CC1BE9E9/Βίντεο/Σειρές/Breaking Bad/Season 5/Breaking.Bad.S05E02.Madrigal.HDTV.x264-FQM.srt is ISO-8859-7.
DEBUG 2013-09-06 14:14:27.367 [New I/O worker #2] Detected encoding for /media/simis/8ACC1C05CC1BE9E9/Βίντεο/Σειρές/Breaking Bad/Season 5/Breaking.Bad.S05E03.Hazard.Pay.HDTV.x264-FQM.srt is UTF-8.
DEBUG 2013-09-06 14:14:27.615 [New I/O worker #2] Detected encoding for /media/simis/8ACC1C05CC1BE9E9/Βίντεο/Σειρές/Breaking Bad/Season 5/Breaking.Bad.S05E03.Hazard.Pay.HDTV.x264-FQM.srt is UTF-8.
DEBUG 2013-09-06 14:14:27.643 [New I/O worker #2] Detected encoding for /media/simis/8ACC1C05CC1BE9E9/Βίντεο/Σειρές/Breaking Bad/Season 5/Breaking.Bad.S05E04.Fifty-One.HDTV.x264-FQM.srt is ISO-8859-7.
DEBUG 2013-09-06 14:14:27.888 [New I/O worker #2] Detected encoding for /media/simis/8ACC1C05CC1BE9E9/Βίντεο/Σειρές/Breaking Bad/Season 5/Breaking.Bad.S05E04.Fifty-One.HDTV.x264-FQM.srt is ISO-8859-7.
DEBUG 2013-09-06 14:14:27.909 [New I/O worker #2] Detected encoding for /media/simis/8ACC1C05CC1BE9E9/Βίντεο/Σειρές/Breaking Bad/Season 5/Breaking.Bad.S05E05.Dead.Freight.HDTV.x264-FQM.srt is ISO-8859-7.
DEBUG 2013-09-06 14:14:28.197 [New I/O worker #2] Detected encoding for /media/simis/8ACC1C05CC1BE9E9/Βίντεο/Σειρές/Breaking Bad/Season 5/Breaking.Bad.S05E05.Dead.Freight.HDTV.x264-FQM.srt is ISO-8859-7.
DEBUG 2013-09-06 14:14:28.219 [New I/O worker #2] Detected encoding for /media/simis/8ACC1C05CC1BE9E9/Βίντεο/Σειρές/Breaking Bad/Season 5/Breaking.Bad.S05E06.HDTV.x264-EVOLVE.srt is ISO-8859-7.
DEBUG 2013-09-06 14:14:28.460 [New I/O worker #2] Detected encoding for /media/simis/8ACC1C05CC1BE9E9/Βίντεο/Σειρές/Breaking Bad/Season 5/Breaking.Bad.S05E06.HDTV.x264-EVOLVE.srt is ISO-8859-7.
DEBUG 2013-09-06 14:14:28.481 [New I/O worker #2] Detected encoding for /media/simis/8ACC1C05CC1BE9E9/Βίντεο/Σειρές/Breaking Bad/Season 5/Breaking.Bad.S05E07.PROPER.HDTV.x264-EVOLVE.srt is ISO-8859-7.
DEBUG 2013-09-06 14:14:28.741 [New I/O worker #2] Detected encoding for /media/simis/8ACC1C05CC1BE9E9/Βίντεο/Σειρές/Breaking Bad/Season 5/Breaking.Bad.S05E07.PROPER.HDTV.x264-EVOLVE.srt is ISO-8859-7.
DEBUG 2013-09-06 14:14:28.773 [New I/O worker #2] Detected encoding for /media/simis/8ACC1C05CC1BE9E9/Βίντεο/Σειρές/Breaking Bad/Season 5/Breaking.Bad.S05E08.HDTV.x264-ASAP.srt is ISO-8859-7.
DEBUG 2013-09-06 14:14:29.080 [New I/O worker #2] Detected encoding for /media/simis/8ACC1C05CC1BE9E9/Βίντεο/Σειρές/Breaking Bad/Season 5/Breaking.Bad.S05E08.HDTV.x264-ASAP.srt is ISO-8859-7.
INFO 2013-09-06 14:14:37.030 [New I/O worker #1] Starting transcode/remux of Breaking.Bad.S05E01.Live.Free.or.Die.HDTV.x264-FQM.mp4
DEBUG 2013-09-06 14:14:37.031 [New I/O worker #1] Launching transcode with media info: container: mp4 / bitrate: 1006369 / size: 322773223 / codecV: h264 / duration: 00:42:45,00 / width: 720 / height: 404 / frameRate: 23.976 / thumb size : 0 / muxingMode: null
audio: id=0 / lang: en / flavor: audio / codec: aac / sf:48000 / na: 2 / bs: 16
sub: id=100 / lang: und / flavor: null / type: SUBRIP
DEBUG 2013-09-06 14:14:37.053 [New I/O worker #1] Starting /usr/local/src/ums-3.0.0-a5/ffmpeg -i "/media/simis/8ACC1C05CC1BE9E9/Βίντεο/Σειρές/Breaking Bad/Season 5/Breaking.Bad.S05E01.Live.Free.or.Die.HDTV.x264-FQM.mp4" -vframes 1 -c:v copy -f h264 -bsf h264_mp4toannexb -an -y pipe:
DEBUG 2013-09-06 14:14:37.064 [New I/O worker #1] Attaching thread: ffmpeg-3
DEBUG 2013-09-06 14:14:37.065 [New I/O worker #1] Unix process ID (/usr/local/src/ums-3.0.0-a5/ffmpeg): 27922
INFO 2013-09-06 14:14:37.069 [New I/O worker #1] Process /usr/local/src/ums-3.0.0-a5/ffmpeg has a return code of 139! Maybe an error occurred... check the log file
DEBUG 2013-09-06 14:14:37.071 [New I/O worker #1] The H.264 stream inside the following file is not compatible with this renderer: /media/simis/8ACC1C05CC1BE9E9/Βίντεο/Σειρές/Breaking Bad/Season 5/Breaking.Bad.S05E01.Live.Free.or.Die.HDTV.x264-FQM.mp4
DEBUG 2013-09-06 14:14:37.146 [New I/O worker #1] Starting mkfifo --mode=777 /tmp/universalmediaserver/mencoder1378466077146
DEBUG 2013-09-06 14:14:37.147 [New I/O worker #1] Unix process ID (mkfifo): 27928
DEBUG 2013-09-06 14:14:37.148 [mencoder-4] Starting /usr/local/src/ums-3.0.0-a5/mencoder -ss 0 "/media/simis/8ACC1C05CC1BE9E9/Βίντεο/Σειρές/Breaking Bad/Season 5/Breaking.Bad.S05E01.Live.Free.or.Die.HDTV.x264-FQM.mp4" -msglevel statusline=2 -oac lavc -of mpeg -mpegopts format=mpeg2:muxrate=500000:vbuf_size=1194:abuf_size=64 -ovc lavc -channels 6 -lavdopts debug=0:threads=2 -lavcopts autoaspect=1:vcodec=mpeg2video:acodec=ac3:abitrate=448:threads=2:keyint=25:vqscale=1:vqmin=2:vqmax=3:vrc_maxrate=24000:vrc_buf_size=1835 -nosub -noautosub -ofps 24000/1001 -lavdopts fast -mc 0.1 -af lavcresample=48000 -srate 48000 -o /tmp/universalmediaserver/mencoder1378466077146
DEBUG 2013-09-06 14:14:37.149 [mencoder-4] Reading pipe: /tmp/universalmediaserver/mencoder1378466077146
DEBUG 2013-09-06 14:14:37.248 [New I/O worker #1] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2013-09-06 14:14:37.261 [Thread-23] [ac3 @ 0x8f80b40]Channel layout not specified
DEBUG 2013-09-06 14:14:37.261 [Thread-23] [ac3 @ 0x8f80b40]No channel layout specified. The encoder will guess the layout, but it might be incorrect.
DEBUG 2013-09-06 14:14:37.261 [Thread-23] Limiting audio preload to 0.4s.
DEBUG 2013-09-06 14:14:37.261 [Thread-23] Increasing audio density to 4.
DEBUG 2013-09-06 14:14:37.284 [Thread-23]
DEBUG 2013-09-06 14:14:37.284 [Thread-23] 1 duplicate frame(s)!
DEBUG 2013-09-06 14:14:37.316 [Thread-23]
DEBUG 2013-09-06 14:14:37.316 [Thread-23] 1 duplicate frame(s)!
DEBUG 2013-09-06 14:14:37.360 [mencoder-4] Attaching thread: mencoder-4
DEBUG 2013-09-06 14:14:37.360 [Thread-26] MEncoder SB50 (C) 2000-2013 MPlayer Team
DEBUG 2013-09-06 14:14:37.360 [Thread-26] Custom build by SubJunk, http://www.spirton.com
DEBUG 2013-09-06 14:14:37.361 [Thread-26] success: format: 0 data: 0x0 - 0x133d20e7
DEBUG 2013-09-06 14:14:37.361 [Thread-26] libavformat version 54.61.101 (internal)
DEBUG 2013-09-06 14:14:37.361 [Thread-26] libavformat file format detected.
DEBUG 2013-09-06 14:14:37.361 [Thread-26] [lavf] stream 0: video (h264), -vid 0
DEBUG 2013-09-06 14:14:37.361 [Thread-26] [lavf] stream 1: audio (aac), -aid 0, -alang eng
DEBUG 2013-09-06 14:14:37.361 [Thread-26] VIDEO: [H264] 720x404 24bpp 23.976 fps 882.5 kbps (107.7 kbyte/s)
DEBUG 2013-09-06 14:14:37.361 [Thread-26] [V] filefmt:44 fourcc:0x34363248 size:720x404 fps:23.976 ftime:=0.0417
DEBUG 2013-09-06 14:14:37.361 [Thread-26] ==========================================================================
DEBUG 2013-09-06 14:14:37.361 [Thread-26] Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
DEBUG 2013-09-06 14:14:37.361 [Thread-26] libavcodec version 54.89.100 (internal)
DEBUG 2013-09-06 14:14:37.361 [Thread-26] AUDIO: 48000 Hz, 2 ch, floatle, 119.8 kbit/3.90% (ratio: 14972->384000)
DEBUG 2013-09-06 14:14:37.361 [Thread-26] Selected audio codec: [ffaac] afm: ffmpeg (FFmpeg AAC (MPEG-2/MPEG-4 Audio))
DEBUG 2013-09-06 14:14:37.361 [Thread-26] PACKET SIZE: 2048 bytes, deltascr: 884
DEBUG 2013-09-06 14:14:37.361 [Thread-26] Opening video filter: [expand osd=1]
DEBUG 2013-09-06 14:14:37.361 [Thread-26] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
DEBUG 2013-09-06 14:14:37.361 [Thread-26] Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
DEBUG 2013-09-06 14:14:37.361 [Thread-26] Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
DEBUG 2013-09-06 14:14:37.361 [Thread-26] Movie-Aspect is undefined - no prescaling applied.
DEBUG 2013-09-06 14:14:37.361 [Thread-26] videocodec: libavcodec (720x404 fourcc=3267706d [mpg2])
DEBUG 2013-09-06 14:14:37.361 [Thread-26] [VE_LAVC] Using constant qscale = 1.000000 (VBR).
DEBUG 2013-09-06 14:14:37.362 [Thread-26] Writing header...
DEBUG 2013-09-06 14:14:37.362 [Thread-26] INITV: 0.200, 0.158, fps: 23.976
DEBUG 2013-09-06 14:14:37.362 [Thread-26] INITV: 0.242, 0.200, fps: 23.976
DEBUG 2013-09-06 14:14:37.362 [Thread-26] INITV: 0.283, 0.242, fps: 23.976
DEBUG 2013-09-06 14:14:37.362 [mencoder-4] Unix process ID (/usr/local/src/ums-3.0.0-a5/mencoder): 27932
INFO 2013-09-06 14:14:37.765 [StartPlaying Event] Started playing Breaking.Bad.S05E01.Live.Free.or.Die.HDTV.x264-FQM.mp4 on your PlayStation 3
DEBUG 2013-09-06 14:14:37.771 [StartPlaying Event] The full filename of which is: /media/simis/8ACC1C05CC1BE9E9/Βίντεο/Σειρές/Breaking Bad/Season 5/Breaking.Bad.S05E01.Live.Free.or.Die.HDTV.x264-FQM.mp4 and the address of the renderer is: 192.168.2.8
DEBUG 2013-09-06 14:14:38.832 [New I/O worker #2] Setting InputStream new position to: 9.223.372.034.707.226.623
DEBUG 2013-09-06 14:14:38.882 [New I/O worker #3] Setting InputStream new position to: 9.223.372.034.707.226.623
DEBUG 2013-09-06 14:14:39.577 [Buffered IO End Checker] Stopping Unix process 27922: ffmpeg-3
INFO 2013-09-06 14:14:46.395 [New I/O worker #3] Buffer read ArrayIndexOutOfBoundsException error:
INFO 2013-09-06 14:14:46.399 [New I/O worker #3] readCount: "9223372034707226623"
INFO 2013-09-06 14:14:46.404 [New I/O worker #3] maxMemorySize: "209715200"
INFO 2013-09-06 14:14:53.907 [New I/O worker #3] Buffer read ArrayIndexOutOfBoundsException error:
INFO 2013-09-06 14:14:53.908 [New I/O worker #3] readCount: "9223372034707226623"
INFO 2013-09-06 14:14:53.909 [New I/O worker #3] maxMemorySize: "209715200"
DEBUG 2013-09-06 14:14:53.963 [New I/O worker #4] Setting InputStream new position to: 9.223.372.034.707.226.623
DEBUG 2013-09-06 14:16:18.381 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2013-09-06 14:16:34.041 [Buffered IO End Checker] Stopping Unix process 27932: mencoder-4
DEBUG 2013-09-06 14:16:34.042 [Buffered IO End Checker] Stopping Unix process 27928: mkfifo-5
INFO 2013-09-06 14:16:35.546 [StopPlaying Event] Stopped playing Breaking.Bad.S05E01.Live.Free.or.Die.HDTV.x264-FQM.mp4 on your PlayStation 3
DEBUG 2013-09-06 14:16:35.547 [StopPlaying Event] The full filename of which is: /media/simis/8ACC1C05CC1BE9E9/Βίντεο/Σειρές/Breaking Bad/Season 5/Breaking.Bad.S05E01.Live.Free.or.Die.HDTV.x264-FQM.mp4 and the address of the renderer is: 192.168.2.8
DEBUG 2013-09-06 14:16:35.547 [StopPlaying Event] Resume stop. This segment 117776 new time 117776
WARN 2013-09-06 14:16:44.042 [Process Destroyer] Sending kill -14 to the Unix process: 27932
DEBUG 2013-09-06 14:16:44.053 [Process Destroyer] Successfully sent kill -14 to the Unix process: 27932
Re: problem playing movies from external hard disk
any idea guys?
what is your default language set to in UMS?
Try changing it here and try again:
Universal Media Server Wiki!
