[Solved] No GUI under Centos under 7.0.1 - 6.8.0 works
asterixer
Post by asterixer » Sat Apr 28, 2018 1:17 am
I tried to use the Mediaserver 7.0.1. I finished the assistant, but i got only as root a GUI. As user i got only a UMS Icon on the upper left and a grey box at the bottom left.
I deleted the .config/UMS directory and installed 6.8.0. in another dir.
6.8.0 is working without problems.
After stopping 6.8.0, i started 7.0.1 by accident. And it now works!!
OS: Centos 7.4 64 bit.
