set interface
realhomer
set interface
Post by realhomer » Fri Aug 24, 2018 11:57 pm
Hi
how i can foce the interface used by the Webinterface in config.
I can't find a list of all config options.
Cheers
Homer
Re: set interface
Post by Nadahar » Sat Aug 25, 2018 7:01 am
You can find the default configuration file with descriptions here: https://github.com/UniversalMediaServer ... s/UMS.conf
I don't think you can set the network interface for the web interface separately, is will use the same interface as that used for UPnP.
