UMS 7.5.0 on Ubunutu 18.04
anilw
Post by anilw »
Hi i have Odroid XU4 and i have Ubunutu 18.04 running with it...
i managed to install UMS-4.4.0 using the following link
viewtopic.php?f=10&t=2761
then i have installed UMS 7.5.0 on this as per the tutorial published above...
but when i start UMS using
service ums start
i get the following error..
Job for ums.service failed because the control process exited with error code.
See "systemctl status ums.service" and "journalctl -xe" for details.
pls help me to fix this issue..
Also tell me how to add files to media library after the UMS is installed
waiting for your kind help
boss
Re: UMS 7.5.0 on Ubunutu 18.04
Post by boss »
Did you create the init script. "/etc/init.d/ums"
If so, you should be starting it using that script.
EG:
/etc/init.d/ums start
/etc/init.d/ums stop
/etc/init.d/ums restart
anilw
Post by anilw »
ok noted.. can you psl help me to add media files in to the server..
my hard disk located at
/media/odroid/Transcend
pls tell me how to add the above in tot he server (media library)
If you can't access the GUI you can add:
folders = /media/odroid/Transcend
to UMS.conf
boss
Post by boss »
You can also have more than one folder.
This is mine in Linux:
folders = /home/media_mnt/Images, /home/media_mnt/Music, /home/media_mnt/Music Videos, /home/media_mnt/Videos
So when you bring up UMS, you get a choice which one you want to go into from the start instead of going down the folder tree.
So if your drive was at: /media/odroid/Transcend
You might have something like:
folders = /media/odroid/Transcend/Images, /media/odroid/Transcend/Music, /media/odroid/Transcend/Music Videos, /media/odroid/Transcend/Videos
anilw
Post by anilw »
Hi tks for the reply...
this how i put my settings.. but the scanning happening only for the root folder...
strange...
can you pls give your UMS.config file and location of the file...
boss
Post by boss »
Sorry for the late reply. I have been in hospital.
The location of my UMS.conf is:
/root/.config/UMS/
My actual UMS.conf file is attached.
UMS.conf
(56.49 KiB) Downloaded 501 times
