bad renderer
jps92
bad renderer
Post by jps92 » Fri Oct 26, 2018 6:39 am
My yamaha RN 500 is detected like a Philips Streamium by UMS !!!
boss
Re: bad renderer
Post by boss » Fri Oct 26, 2018 12:52 pm
You can give the Yamaha-RN500.conf a higher priority if you like.
Edit the renderer file "Yamaha-RN500.conf" and place the following:
LoadingPriority = 2
below the line:
UpnpDetailsSearch = R-N500
Re: bad renderer
Post by SubJunk » Fri Oct 26, 2018 1:08 pm
The suggestion by boss is good and will work. Also please attach logs so we can try to fix the wrong detection
Edit: Also you can disable the Streamium renderer in the UMS General tab, so you don't have to edit a file. That way it will be saved when you update version too
jps92
Re: bad renderer
Post by jps92 » Sat Oct 27, 2018 8:39 am
You're right, it's detected well now. Thank you.
jps92
Re: bad renderer
Post by jps92 » Sat Dec 01, 2018 8:38 am
Since v7.6.2, even without LoadingPriority =2, there's no more problem.
