Subtitles codepage problem
I've started using UMS and I really excited about what it can do. However I have a problem with subtitles.
Currently I am using UMS 6 (last release available on the main page) running on CentOS Linux release 7.2.1511 (Core), which is fully updated.
The problem, based on debug log, seems to be with subtitles codepage. I have my subtitles in cp1250. When in UMS.conf nothing is set, the following is executed:
Which ends up in error. I have decided to change the codepage setting in UMS.conf to hardcode it to cp1250, but still no luck.
I have encoded subtitles into utf-8, which solved the problem:
Though I would like to have my subtitles in cp1250 if possible. Then, I have tried the ffmpeg command with charenc=cp1250 against local (provided by Centos/epel/nux) ffmpeg and that did work:
So I guess my question is, how do I make UMS to read the subtitles encoded in cp1250 correctly?
DEBUG 2016-02-03 21:12:44.590 [ffmpeg64-2] Starting /opt/ums-6.0.0/linux/ffmpeg64 -y -loglevel fatal -i /home/storage/public/seriale/H/Hfull.mkv -filter_complex subtitles=/home/storage/public/seriale/H/Hfull.txt:charenc=WINDOWS-1250 -bufsize 7000000 -maxrate 44000000 -g 5 -q:v 1 -qmin 2 -qmax 3 -c:a copy -c:v mpeg2video -f vob /tmp/UMS-ums/ffmpegvideo_42_1454530364285
DEBUG 2016-02-03 21:12:44.592 [ffmpeg64-2] Reading pipe: /tmp/UMS-ums/ffmpegvideo_42_1454530364285
DEBUG 2016-02-03 21:12:44.634 [ffmpeg64-2-2] Error initializing complex filters.
DEBUG 2016-02-03 21:12:44.634 [ffmpeg64-2-2] Invalid argument
DEBUG 2016-02-03 21:10:55.544 [ffmpeg64-2] Starting /opt/ums-6.0.0/linux/ffmpeg64 -y -loglevel fatal -i /home/storage/public/seriale/H/Hfull.mkv -filter_complex subtitles=/home/storage/public/seriale/H/Hfull.txt:charenc=cp1250 -bufsize 7000000 -maxrate 44000000 -g 5 -q:v 1 -qmin 2 -qmax 3 -c:a copy -c:v mpeg2video -f vob /tmp/UMS-ums/ffmpegvideo_38_1454530255238
DEBUG 2016-02-03 21:10:55.546 [ffmpeg64-2] Reading pipe: /tmp/UMS-ums/ffmpegvideo_38_1454530255238
DEBUG 2016-02-03 21:10:55.603 [ffmpeg64-2-2] Error initializing complex filters.
DEBUG 2016-02-03 21:10:55.604 [ffmpeg64-2-2] Invalid argument
DEBUG 2016-02-03 21:17:23.955 [ffmpeg64-2] Starting /opt/ums-6.0.0/linux/ffmpeg64 -y -loglevel fatal -i /home/storage/public/seriale/H/Hfull.mkv -filter_complex subtitles=/home/storage/public/seriale/H/Hfull.txt -bufsize 7000000 -maxrate 44000000 -g 5 -q:v 1 -qmin 2 -qmax 3 -c:a copy -c:v mpeg2video -f vob /tmp/UMS-ums/ffmpegvideo_42_1454530643649
DEBUG 2016-02-03 21:17:23.956 [ffmpeg64-2] Reading pipe: /tmp/UMS-ums/ffmpegvideo_42_1454530643649
DEBUG 2016-02-03 21:17:24.150 [ffmpeg64-2] Attaching thread: ffmpeg64-2
DEBUG 2016-02-03 21:17:24.152 [ffmpeg64-2] Unix process ID (/opt/ums-6.0.0/linux/ffmpeg64): 3795
ffmpeg -y -loglevel fatal -i /home/storage/public/seriale/H/Hfull.mkv -filter_complex subtitles=/home/storage/public/seriale/H/Hfull.txt:charenc=cp1250 -bufsize 7000000 -maxrate 44000000 -g 5 -q:v 1 -qmin 2 -qmax 3 -c:a copy -c:v mpeg2video -f vob /tmp/UMS-ums/ffmpegvideo_38_1454530255238
Re: Subtitles codepage problem
Isn't your local ffmpeg 64bit, or is it just a different name?
You can configure the ffmpeg binary to use manually by adding
..and the actual path in UMS.conf in your profile folder which defaults to ~/.config/UMS.
ffmpeg_path =
No, it's just different naming. This is 64 bit.
I have changed the ffmpeg path and that fixed the problem. Thank you!
Though, I don't know if that was the issue in the previous versions, however, is the ffmpeg shipped with ums going to be fixed for that issue?
[root@kowalski ~]# rpm -aq | grep ffmpeg
ffmpeg-2.6.5-1.el7.nux.x86_64
ffmpeg-libs-2.6.5-1.el7.nux.x86_64
There are so many potential issues related to FFmpeg that testing a new version is a huge task. Lately some major things have changed as well, so as far as I know we have to adjust our use for it to keep working if we upgrade (the version bundled with your OS probably isn't that new). FFmpeg isn't in "my area of expertice", but from what I understand we don't do that too often but I guess we have to at one stage.zuku wrote: Though, I don't know if that was the issue in the previous versions, however, is the ffmpeg shipped with ums going to be fixed for that issue?
To make it worse, the number of Linux users are limited so getting enough feedback to deem a version "working" can be challenging.
It would be interesting if you could print the version number from both versions. You could face other issues with the version you use now even though the character encoding issue is fixed. It would also be interesting if you could report back after using it for a while if you have experienced any issues (and if you experience other issues, try to switch the FFmpeg versions to see if that affects it).
Thank you for sharing your thoughts. I will test it for a while and be back to you with the results if I have interesting ones.
The best way is to follow the Forum rules written in red above. We need the trace log to see what is wrong with FFmpeg.
