UMS not working at all (going on)
jps92
Post by jps92 » Fri Feb 05, 2016 8:42 am
v 5.4.0 works very well but when i'm executing 6.0.0 nothing happen.
It asks for language at the beginning and it is everything. There is even no change in the debug.log !
I use Linux Mint 32 (lmde).
(l'm french)
Re: UMS not working at all (going on)
Post by Nadahar » Fri Feb 05, 2016 9:09 am
Even if there's no change in debug.log, I'd like to see it. Also, in UMS.conf you should change "log_level" to "TRACE". When that's done, start UMS and debug.log should have more information.
If nothing is written to debug.log, it must be a permission issue. Check that the user running UMS has write permission to UMS' profile folder.
jps92
Post by jps92 » Mon Feb 08, 2016 4:28 am
You're right it was a permission issue. Sorry. Thank you.
