Share a folder from another disk(partition)
marlonmrn
Post by marlonmrn » Fri Feb 19, 2016 12:10 pm
I'm using Elementary OS(Debian based), first of all, congratulations on your work, it is the best DLNA server I found. 0 problems so far, just one question :D
Straight to the point: How I share a folder from another partition?
All of my movies are in a different partition from my OS, it's a dedicated partition to my files (most a backup, but ok).
It's really annoying (and time-costy) have to copy every film before I watch it.
When I try to add another folder to the shared's, I can only see the mount point ( / ) to inside. I cant select another partitions, how do I do this?
(partition were mounted)
Thank you, Marlon
Tonne M
Re: Share a folder from another disk(partition)
Post by Tonne M » Tue Mar 01, 2016 6:51 am
Try one more level up. There you will see "media". Open that folder and see what's there.
marlonmrn
Post by marlonmrn » Wed Mar 30, 2016 1:45 pm
Tonne M wrote:Try one more level up. There you will see "media". Open that folder and see what's there.
Thank you so much, worked like a charm.
love you <3
