Loading next file timing out
achernar13
Post by achernar13 » Fri Feb 26, 2016 6:30 pm
I recently switched from ubuntu to centos 7 and in the process also switched from ps3mediaserver to UMS.
With the ps3media server setup I used to be able to play shows from my devices and the players (android, samsung tvs,...) used to just play the next file in the directory.
Since using UMS however, I get a loading message after every file but then it times out and the next file never plays, making me having to connect back to UMS.
Has anyone else experienced this? Any suggestions what I might be able to do to fix it? I tried different versions of JRE 7, 8, from oracle, and redhat but all exhibit the same behavior.
I have all transcoding settings set to automatic and sound is also defaults.
