Error "There is no inputstream to return"
HI,
I could not play any video on my TV. All my media files are correctly listed on the TV (render), include thumbnails, but when I try to play I always get the same error (at log tab on PC), please find below:
I am using a Xubuntu 14.04 with UMS 6.2.1.
Best regards, sorry bad English,
Eduardo Donato
What is wrong?ERROR 15:41:46.244 [Hanging External Process Stopper] External input stream instance is null... stopping process
ERROR 15:41:46.244 [New I/O worker #3] There is no inputstream to return for The.Simpsons.S26E01.Clown.in.the.Dumps.720p.WEB-DL.DD5.1.H.264-NTb.DUAL-CS {External Subtitles}
Eduardo Donato
- (68.4 KiB) Downloaded 492 times
Re: Error "There is no inputstream to return"
Guys,
For information, I disable subtitles and then worked.
How work with subtitle?
I solved the problem by myself.
I remove/delete the ffmpeg files from "ums<version>\linux folder" and then install ffmpeg at my computer. Works fine now. The files that came with the UMS return "segmentation fault" when transconding video with subtitle.
For information, on my TV Sony Bravia 1080p videos appears to be stretched vertically. To fix that, I comment the OverrideFFmpegVideoFilter parameter at render config.
Wow!
$sudo add-apt-repository ppa:mc3man/trusty-media
$ sudo apt-get update
$ sudo apt-get install ffmpeg gstreamer0.10-ffmpeg
Wow!
Mark this topic as solved please.
Hi ebdonato, thanks for the feedback. I have fixed the OverrideFFmpegVideoFilter setting for your TV in the next version.
It looks like the version of FFmpeg we include for Linux doesn't load the font properly. We get our Linux builds from http://johnvansickle.com/ffmpeg/, do you have any idea where to get better static builds?
