I’m not understanding VirtualFolders.conf [soled]
I’m running Ubuntu 15 in headless mode. Running UMS-6.2.2-Java7
I’m not understanding VirtualFolders.conf. Does this feature not work under linux or is it a bug of this version of UMS?
This statement works as
virtual_folders = Cinema|/home/Video,/home/Cinema
But when I put in the config file for testing. It falls
virtual_folders_file =/etc/ums/VirtualFolders.conf
"name":"Cinema",
"files":[
"/home/Video",
"/home/Cinema"
Thank you for your help
"name":"Cinema",
"files":[
"/home/Video",
"/home/Cinema"
Re: I’m not understanding VirtualFolders.conf
Your setup seems correct, does the logfile say anything about UMS not being able to find or read /etc/ums/VirtualFolders.conf
here is what is in ther log
INFO 2016-06-28 13:38:17.550 [main] Graphics environment not available or headless mode is forced
INFO 2016-06-28 13:38:17.550 [main] Switching to console mode
DEBUG 2016-06-28 13:38:17.578 [main] Checking dbgpack property in UMS.conf
DEBUG 2016-06-28 13:38:17.587 [main] Reading virtual_folders_file: "/etc/ums/VirtualFolders.conf" (default: "")
DEBUG 2016-06-28 13:38:17.587 [main] adding /etc/ums/etc/ums/VirtualFolders.conf
DEBUG 2016-06-28 13:38:17.587 [main] adding /etc/ums/WEB.conf
DEBUG 2016-06-28 13:38:17.587 [main] adding /etc/ums/UMS.conf
Fixed
virtual_folders_file =file name
Not the full path to file.
virtual_folders_file =VirtualFolders.conf
