Transcoding settings are not available
For help and support with Mac OS X-specific issues
valorn
Post by valorn » Mon Dec 11, 2017 10:32 am
Hi
Using MacOS High Sierra, last Java, UMS 6.7.4 or 7.RC1.
I cannot access to Transcoding settings. I can only see "Disable subtitles" option there.
I have unchecked the option of hiding advanced options in General settings, then I reloaded server. I tried also to exit and enter UMS program again. By the way, it doesn't save the General settings...
If I change desktops, sometimes I can see the transcoding settings, but I cannot select any of the options there, only "disable subtitles".
Any ideas?
Sami32
Re: Transcoding settings are not available
Post by Sami32 » Mon Dec 11, 2017 10:44 am
yes, a very simple one: follow the "Problem Reporting Guideline" write in red above your post ;)
A screen capture could also help.
EDIT: "Disable subtitles" is in the "Transcoding Settings" tab.
Make sure you didn't selected "Hide advanced options" in the "General Configuration" tab.
Post by Nadahar » Mon Dec 11, 2017 1:00 pm
I think there's a problem that causes the settings not to be saved - which means that "hide advanced options" is always on. Check that UMS has write access to the profile folder (you can find the profile folder early in the log in the "Logs" tab).
valorn
Post by valorn » Tue Dec 12, 2017 9:18 am
Thank you for your help.
I manually changed UMS.conf and turned the value true into false.
Now I can see the settings.
But the changes I do in the settings are not saved. I send the debug file. How can I make it writable?
debug.txt
(32.08 KiB) Downloaded 44 times
Post by Nadahar » Tue Dec 12, 2017 9:23 am
I don't think you will be able to save other settings from the GUI either. I don't know what is changed in High Sierra, but we have had several reports of issues so my guess is that they have implemented some kind of sandboxing or other "security issue" that prevents UMS from writing to its config files.
The real solution would probably be to figure out what has changed and how to allow UMS to write to the profile folder.
valorn
Post by valorn » Tue Dec 12, 2017 9:59 am
Do you think there should be a Java issue more than High Sierra?
Sami32
Post by Sami32 » Wed Dec 13, 2017 2:25 am
@valorn If you could consider read carefully these steps: (full TRACE log create AFTER reproducing your issue)
viewtopic.php?f=9&t=556
Using the latest stable UMS realease 6.7.4, and not any 7.0.0 versions as you did, or report your issue into the 7.0.0 section. That mean that you'll have to do a clean install.
After that, we should have a usable log to look at.
For now, the only thing visible into your log is that is bad is:
ERROR 2017-12-11 22:28:15.786 [main] A serious error occurred during Universal Media Server initialization: null
