Globally disable transcoding
For help and support with Mac OS X-specific issues
Atalantia
Post by Atalantia » Sat Jun 08, 2019 2:06 pm
how do I globally disable transcoding? I made a conf file for every device that contains:
Device = 192.168.0.12
disable_transcode_for_extensions = mp4,m4v,mkv,avi,mpg,mpeg
But do I need that for each device? Can I do?:
Device = 192.168.0.12 192.168.0.13 192.168.0.14
or:
Device = 192.168.0.12,192.168.0.13,192.168.0.14
Re: Globally disable transcoding
Post by Nadahar » Sat Jun 08, 2019 3:04 pm
There's a setting in the global configuration to do this: https://github.com/UniversalMediaServer ... #L649-L656
That said, this should only be used for troubleshooting or similar, the whole idea of "disabling transcoding" is a logical fallacy. Transcoding is only used when the renderer cannot otherwise play the media. That means that disabling transcoding is the same as "disabling playback" of said media. I doubt that's what you're after.
What is normally the real problem is that the renderer is configured wrong, so that UMS think it has to transcode when it doesn't. The fix is to correct the configuration, not disable transcoding.
Atalantia
Post by Atalantia » Sun Jun 09, 2019 3:09 pm
Thanks for answering. I'll look at little bit closer. Maybe I can disable all the conf file I made.
