[Solved] UMS will not start
HI Iam Using Mac OSX version 10.9.4. Have latest version of UMS 4.0.0 & Java. 7 installed . UMS icon just sits in the dock .Cannot open or see any user interface . Any help would be appreciated. Thankyou.
- Optimus_prime
Re: UMS WILL NOT START
I'll check this evening for the issue on Mavericks. do any other versions work, like 3.6.4?
Ive been having this issue for the past few releases the last version that worked is 3.6.1. All I see is the icon on the dock screen, nothing else shows up. I'm running OSX 10.7.5, Java 7 Update 67.
- Optimus_prime
Iamjohn, which version are you using, Official (java 6) or the Java 7 labeled version?
Same problem encountered with official release and Java 7 release.
Both,
Did you try to copy the icon from the newly downloaded version or are you using the icon from a previous install.
First try to start up UMS directly from the application folder or through launchpad.
Sometimes the 'older' dock icon is not properly linked to the correct folder/file.
Next option is go to : HD/user/Library/Application Support and fully delete the UMS folder and try to set up UMS from the start.
BE AWARE THAT USING THIS OPTION WILL CAUSE YOU TO LOOSE ALL PREVIOUS SETTINGS !!!
When none of the above will do it's job , try to download the file again and install it all over.
Good luck.
Good luck.
Same problem here with Lion Server 10.7.5, last version that works for me is UMS 3.6.0
Tried UMS 4.0.2 for Java 6 and 7 today, but no go. Java 7 is installed. Trashing the UMS folder in Application Support helps nothing. I am pretty sure it is Lion related cause on Mavericks UMS 4.0.2 works just fine.
Log:
8/9/14 11:43:14.864 PM [0x0-0x89089].net.pms.PMS: 23:43:14.853 [main] DEBUG o.a.c.c.ConfigurationUtils - ConfigurationUtils.locate(): base is null, name is /Users/xxxxxxx/Library/Application Support/UMS/UMS.conf
8/9/14 11:43:14.864 PM [0x0-0x89089].net.pms.PMS: 23:43:14.861 [main] DEBUG o.a.c.c.DefaultFileSystem - Could not locate file /Users/xxxxxxxx/Library/Application Support/UMS/UMS.conf at null: no protocol: /Users/xxxxxxxx/Library/Application Support/UMS/UMS.conf
8/9/14 11:43:14.864 PM [0x0-0x89089].net.pms.PMS: 23:43:14.862 [main] DEBUG o.a.c.c.ConfigurationUtils - Loading configuration from the absolute path /Users/xxxxxxxx/Library/Application Support/UMS/UMS.conf
8/9/14 11:43:14.864 PM [0x0-0x89089].net.pms.PMS: 23:43:14.862 [main] DEBUG o.a.c.c.PropertiesConfiguration - Base path set to file:///Users/xxxxxxx/Library/Application%20Support/UMS/UMS.conf
8/9/14 11:43:14.959 PM [0x0-0x89089].net.pms.PMS: 23:43:14.958 [main] DEBUG o.a.c.c.PropertiesConfiguration - FileName set to UMS.conf
8/9/14 11:43:14.959 PM [0x0-0x89089].net.pms.PMS: 23:43:14.959 [main] DEBUG o.a.c.c.PropertiesConfiguration - Base path set to /Users/xxxxxxxxxx/Library/Application Support/UMS
8/9/14 11:43:15.177 PM [0x0-0x89089].net.pms.PMS: 23:43:15,176 |-INFO in ch.qos.logback.core.joran.action.DefinePropertyAction - About to instantiate property definer of type [net.pms.logging.DebugLogPathDefiner]
8/9/14 11:43:15.183 PM [0x0-0x89089].net.pms.PMS: 23:43:15,179 |-INFO in ch.qos.logback.core.joran.action.DefinePropertyAction - Popping property definer for property named [debugLogPath] from the object stack
8/9/14 11:43:15.184 PM [0x0-0x89089].net.pms.PMS: 23:43:15,183 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [net.pms.logging.FrameAppender]
8/9/14 11:43:15.185 PM [0x0-0x89089].net.pms.PMS: 23:43:15,185 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [traces]
8/9/14 11:43:15.255 PM [0x0-0x89089].net.pms.PMS: 23:43:15,252 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
8/9/14 11:43:15.255 PM [0x0-0x89089].net.pms.PMS: 23:43:15,252 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [console]
8/9/14 11:43:15.284 PM [0x0-0x89089].net.pms.PMS: 23:43:15,264 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.FileAppender]
8/9/14 11:43:15.284 PM [0x0-0x89089].net.pms.PMS: 23:43:15,268 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [debug.log]
8/9/14 11:43:15.284 PM [0x0-0x89089].net.pms.PMS: 23:43:15,276 |-INFO in ch.qos.logback.core.FileAppender[debug.log] - File property is set to [/Users/xxxxxxxx/Library/Application Support/UMS/debug.log]
8/9/14 11:43:15.284 PM [0x0-0x89089].net.pms.PMS: 23:43:15,280 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.rolling.RollingFileAppender]
8/9/14 11:43:15.284 PM [0x0-0x89089].net.pms.PMS: 23:43:15,282 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [debug.log.10MB]
8/9/14 11:43:15.310 PM [0x0-0x89089].net.pms.PMS: 23:43:15,309 |-INFO in ch.qos.logback.core.rolling.FixedWindowRollingPolicy@70216c0 - Will use zip compression
8/9/14 11:43:15.328 PM [0x0-0x89089].net.pms.PMS: 23:43:15,324 |-INFO in ch.qos.logback.core.rolling.RollingFileAppender[debug.log.10MB] - Active log file name: /Users/xxxxxxxx/Library/Application Support/UMS/debug.log
8/9/14 11:43:15.328 PM [0x0-0x89089].net.pms.PMS: 23:43:15,324 |-INFO in ch.qos.logback.core.rolling.RollingFileAppender[debug.log.10MB] - File property is set to [/Users/xxxxxxxx/Library/Application Support/UMS/debug.log]
8/9/14 11:43:15.328 PM [0x0-0x89089].net.pms.PMS: 23:43:15,325 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [org.apache] to WARN
8/9/14 11:43:15.328 PM [0x0-0x89089].net.pms.PMS: 23:43:15,326 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [httpclient.wire] to WARN
8/9/14 11:43:15.328 PM [0x0-0x89089].net.pms.PMS: 23:43:15,327 |-INFO in ch.qos.logback.classic.joran.action.RootLoggerAction - Setting level of ROOT logger to DEBUG
8/9/14 11:43:15.328 PM [0x0-0x89089].net.pms.PMS: 23:43:15,327 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [traces] to Logger[ROOT]
8/9/14 11:43:15.328 PM [0x0-0x89089].net.pms.PMS: 23:43:15,327 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [console] to Logger[ROOT]
8/9/14 11:43:15.329 PM [0x0-0x89089].net.pms.PMS: 23:43:15,327 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [debug.log] to Logger[ROOT]
8/9/14 11:43:15.331 PM [0x0-0x89089].net.pms.PMS: 23:43:15,329 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - End of configuration.
8/9/14 11:43:15.332 PM [0x0-0x89089].net.pms.PMS: 23:43:15,332 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@329fefc3 - Registering current configuration as safe fallback point
8/9/14 11:43:15.435 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.433 [main] Starting Universal Media Server 4.0.2
8/9/14 11:43:15.436 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.435 [main] Based on PS3 Media Server by shagrath, copyright 2008-2014
8/9/14 11:43:15.436 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.435 [main] http://www.universalmediaserver.com
8/9/14 11:43:15.437 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.435 [main]
8/9/14 11:43:15.437 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.436 [main] Build: eb5240da9 (2014-08-05)
8/9/14 11:43:15.437 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.436 [main] Java: Java HotSpot(TM) 64-Bit Server VM 1.7.0_67 64-bit by Oracle Corporation
8/9/14 11:43:15.438 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.436 [main] OS: Mac OS X 64-bit 10.7.5
8/9/14 11:43:15.438 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.436 [main] Encoding: UTF-8
8/9/14 11:43:15.457 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.453 [main] Memory: 683 MB
8/9/14 11:43:15.457 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.454 [main] Language: en
8/9/14 11:43:15.457 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.455 [main] Working directory: /Applications/Universal Media Server.app/Contents/Resources
8/9/14 11:43:15.457 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.456 [main] Temp directory: /var/folders/dg/5_lj58pj7ksf7_zvllnywl140000gn/T/universalmediaserver
8/9/14 11:43:15.478 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.471 [main] Logging config file: /Applications/Universal Media Server.app/Contents/Resources/logback.xml
8/9/14 11:43:15.478 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.472 [main] debug.log: /Users/xxxxxxx/Library/Application Support/UMS/debug.log
8/9/14 11:43:15.478 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.473 [main]
8/9/14 11:43:15.478 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.474 [main] Profile directory: /Users/xxxxxxx/Library/Application Support/UMS
8/9/14 11:43:15.478 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.475 [main] Profile directory permissions: rw
8/9/14 11:43:15.478 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.476 [main] Profile path: /Users/xxxxxxx/Library/Application Support/UMS/UMS.conf
8/9/14 11:43:15.478 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.477 [main] Profile permissions: rw
8/9/14 11:43:15.486 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.480 [main] Profile name: xxxxxxxx.local
8/9/14 11:43:15.486 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.481 [main]
8/9/14 11:43:15.486 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.485 [main] Web conf path: /Users/xxxxxxx/Library/Application Support/UMS/WEB.conf
8/9/14 11:43:15.487 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.485 [main] Web conf permissions: file not found
8/9/14 11:43:15.487 PM [0x0-0x89089].net.pms.PMS: INFO 2014-08-09 23:43:15.486 [main]
8/9/14 11:43:17.685 PM [0x0-0x89089].net.pms.PMS: ERROR 2014-08-09 23:43:17.683 [main] A serious error occurred during PMS init
8/9/14 11:43:17.685 PM [0x0-0x89089].net.pms.PMS: java.lang.StringIndexOutOfBoundsException: String index out of range: -5
8/9/14 11:43:17.685 PM [0x0-0x89089].net.pms.PMS: at java.lang.String.substring(String.java:1875) ~[na:1.7.0_67]
8/9/14 11:43:17.685 PM [0x0-0x89089].net.pms.PMS: at net.pms.util.WindowsRegistry.readRegistry(WindowsRegistry.java:34) ~[ums.jar:4.0.2]
8/9/14 11:43:17.685 PM [0x0-0x89089].net.pms.PMS: at net.pms.configuration.PmsConfiguration.isAutoStart(PmsConfiguration.java:1527) ~[ums.jar:4.0.2]
8/9/14 11:43:17.685 PM [0x0-0x89089].net.pms.PMS: at net.pms.newgui.GeneralTab.build(GeneralTab.java:105) ~[ums.jar:4.0.2]
8/9/14 11:43:17.685 PM [0x0-0x89089].net.pms.PMS: at net.pms.newgui.LooksFrame.buildMain(LooksFrame.java:410) ~[ums.jar:4.0.2]
8/9/14 11:43:17.685 PM [0x0-0x89089].net.pms.PMS: at net.pms.newgui.LooksFrame.buildContent(LooksFrame.java:382) ~[ums.jar:4.0.2]
8/9/14 11:43:17.685 PM [0x0-0x89089].net.pms.PMS: at net.pms.newgui.LooksFrame.<init>(LooksFrame.java:251) ~[ums.jar:4.0.2]
8/9/14 11:43:17.685 PM [0x0-0x89089].net.pms.PMS: at net.pms.PMS.init(PMS.java:522) [ums.jar:4.0.2]
8/9/14 11:43:17.685 PM [0x0-0x89089].net.pms.PMS: at net.pms.PMS.createInstance(PMS.java:1044) [ums.jar:4.0.2]
8/9/14 11:43:17.685 PM [0x0-0x89089].net.pms.PMS: at net.pms.PMS.main(PMS.java:1144) [ums.jar:4.0.2]
Log:
Tried all of the suggestions and still no joy, very odd. Good to know it isn't just me though.
Are you using Lion Server? You have the same error in the log?Iamjohn wrote:Tried all of the suggestions and still no joy, very odd. Good to know it isn't just me though.
- Optimus_prime
The odd thing is that you can't use any version. I'm trying to isolate the issue, i hope i can find it
