UMS won't start on Mavericks
Re: UMS won't start on Mavericks
Thanks for trying!
- The command did not return anything
- I don't have a /System/Java/Library/Extensions folder...
- In the /Library/Java/Extensions folder, I have a slf4j link to "/usr/local/xuggler/share/java/jars/slf4j-api.jar"
When I tryed to delete both the slf4j and the link, it did not help to start UMS. I then tried the java launcher of UMS and got the following:
/Applications/Universal\ Media\ Server.app/Contents/MacOS/JavaAppLauncher ; exit;
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [jar:file:/Library/Internet%20Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/ext/logback-classic.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/usr/local/xuggler/share/java/jars/logback-classic.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/Applications/Universal%20Media%20Server.app/Contents/Java/ums-4.0.3-jar-with-dependencies.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
Failed to instantiate SLF4J LoggerFactory
Reported exception:
java.lang.NoClassDefFoundError: org/slf4j/spi/LoggerFactoryBinder
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:800)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:449)
at java.net.URLClassLoader.access$100(URLClassLoader.java:71)
at java.net.URLClassLoader$1.run(URLClassLoader.java:361)
at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
at java.lang.ClassLoader.loadClass(ClassLoader.java:412)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
at org.slf4j.LoggerFactory.bind(LoggerFactory.java:129)
at org.slf4j.LoggerFactory.performInitialization(LoggerFactory.java:108)
at org.slf4j.LoggerFactory.getILoggerFactory(LoggerFactory.java:302)
at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:276)
at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:288)
at net.pms.PMS.<clinit>(PMS.java:91)
Caused by: java.lang.ClassNotFoundException: org.slf4j.spi.LoggerFactoryBinder
at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
... 19 more
Exception in thread "main" java.lang.NoClassDefFoundError: org/slf4j/spi/LoggerFactoryBinder
... 19 more
logout
[Process completed]
- Optimus_prime
Ok, lets try this. Reinstall the latest java, try if you could getting the JDK not the JRE.
Plus grab the latest UMS for Java 8 and try again.
Ok I will try, but I copied the slf4j file back to its folder since it is necessary for another software... will that be a problem?
Just tried:
I installed java 8 jdk
I also installed the latest UMS for java 8. It still does not start and the java launcher still gives me:
java -version
java version "1.8.0_20"
Java(TM) SE Runtime Environment (build 1.8.0_20-b26)
Java HotSpot(TM) 64-Bit Server VM (build 25.20-b23, mixed mode)
Exception in thread "main" java.lang.NoSuchMethodError: org.slf4j.spi.LocationAwareLogger.log(Lorg/slf4j/Marker;Ljava/lang/String;ILjava/lang/String;[Ljava/lang/Object;Ljava/lang/Throwable;)V
at org.apache.commons.logging.impl.SLF4JLocationAwareLog.debug(SLF4JLocationAwareLog.java:133)
at org.apache.commons.configuration.AbstractFileConfiguration.setFileName(AbstractFileConfiguration.java:588)
at org.apache.commons.configuration.AbstractFileConfiguration.setFile(AbstractFileConfiguration.java:663)
at org.apache.commons.configuration.AbstractFileConfiguration.setPath(AbstractFileConfiguration.java:694)
at net.pms.configuration.PmsConfiguration.<init>(PmsConfiguration.java:494)
at net.pms.configuration.PmsConfiguration.<init>(PmsConfiguration.java:454)
at net.pms.PMS.main(PMS.java:1116)
logout
[Process completed]
- Optimus_prime
Shouldn't be, what software uses a different version?Ok I will try, but I copied the slf4j file back to its folder since it is necessary for another software... will that be a problem?
The software using it is Xuggler. In fact, all 4 items that I have in the /Library/Java/Extensions folder are links to jar files located in a subfolder of this application...
- Optimus_prime
Hmm, give me a few days and i'll try come up with something to fix this
....so? Any news?
Want to chime in and say I'm having the same issue.
Tried with Java6 and Java7, with newest UMS as well as earlier versions.
After install I go to open the application and there's no GUI. Just Universal Media Server in the top bar and nothing else.
PS3 Media Server opens without any issue.
Hmm, it might be a bit different in my case because I can't open PMS either...
