Java 8 Prompts for Incoming Network Connections
Success!
I diff'd the pom and see most of the changes are mostly minor except for one:
Minor:
The file: appbundler-1.0.UMS.jar was added on Apr 30, guess I never had the pom to use it.
Did a Clean - Success
Did a Build with Deps - Success - Launched - Detected renderer!
Houston, we have landed.
Thank you very much.
I didn't bother to diff the output - it all worked but can if you are curious.
Now how do we get a wiki page with this information in it for others? I have my own local "UMS Notes" which has it all.
Minor:
- changing osx => osx-java-7-8 in many places
removal of"p=${binary-revision}" in the Download binaries
message change on "Create the shortcut…"
- build package profile, id: osx to osx-java-7-8 with a different method
. . . . and a few others.
Samsung UN55C8000
Samsung UN55C8000
- Optimus_prime
Re: Java 8 Prompts for Incoming Network Connections
Thats excellent mate, i'm glad someone else has got it to work.
No-one has ever asked how i build them to be honest. Now someone has and got it working i suppose it's time to put it out there for all to see and use themselves. Thanks for asking and keeping at it
Nope not needed as you have it all working.I didn't bother to diff the output - it all worked but can if you are curious.
Well i've been meaning to update the wiki for a long time with all this information. I will over the next few weeks be submitting a pull request to get it put into the OSX-Java 7 and 8 branches, i've been busy with work and such (plus lazy as i've got it working and have been putting up with moving it all over everytime i build, into the pom.xml that is). From there if you want i can get it into the wiki if you have it all in a nice how-to.Now how do we get a wiki page with this information in it for others? I have my own local "UMS Notes" which has it all.
Anytime mate, I love to try and help where i can. I love giving back where i can to the UMS communityThank you very much.
Well thats a good question but there's a few issues in how the pom.xml works. I've had many issues in the past but i think i will spend some more time figuring them out and getting it in the code, feel free to try yourself and if you do get it to work let me know so i can test it too. Edit: We need to retain java 6 compatibility, which is the default for UMS in OSX. Thats why i've had issues getting it to play nicely in the pom.A question: since there are other build package profiles for the other systems, why can't one just add the osx-java-7-8 package profile as another profile and have only one pom file?
I'll give it a try - I may surprise myself.Optimus_prime wrote:Well thats a good question but there's a few issues in how the pom.xml works. I've had many issues in the past but i think i will spend some more time figuring them out and getting it in the code, feel free to try yourself and if you do get it to work let me know so i can test it too.A question: since there are other build package profiles for the other systems, why can't one just add the osx-java-7-8 package profile as another profile and have only one pom file?
One of the differences was the removal of the "p=${binary-revision}" in the Download binaries section. Do you know if this was necessary for getting it to work or just more redundant code.
Samsung UN55C8000
Samsung UN55C8000
NOT: Java 8 Prompts for Incoming Network Connections
No network prompt with these builds.
Since you do not see it with your builds, I am guessing it is a side effect or feature of the security enhancements in Java 7-8.
Might want to put out a call later for others to help test: run and build-run to root-cause this.
Played around with some changes I made. Some worked, some surprises but 'normal' learning curve for me.
More later.
Edit: yesterday it did not prompt, today it does. Complications. This is not the only time I have seen 'good' first-time executions followed by 'bad' there after. Thoughts later.
Edit #2: the prompting seems to have gone away. Self correcting code?
More later.
Samsung UN55C8000
Samsung UN55C8000
Ok - can I send you a pdf?From there if you want i can get it into the wiki if you have it all in a nice how-to.
Cleaning it up now, removing old bad info. Question: the mvn commands:
- I assume it's done for each project and not once for all.
mvn com.savage7.maven.plugins:maven-external-dependency-plugin:resolve-external mvn com.savage7.maven.plugins:maven-external-dependency-plugin:install-external
OK - working on this too:Well thats a good question but there's a few issues in how the pom.xml works. I've had many issues in the past but i think i will spend some more time figuring them out and getting it in the code, feel free to try yourself and if you do get it to work let me know so i can test it too. Edit: We need to retain java 6 compatibility, which is the default for UMS in OSX. Thats why i've had issues getting it to play nicely in the pom.add the osx-java-7-8 package profile as another profile and have only one pom file?
- 1- I would question Java6 as the default on the basis of Apple recommending Java8 due to security issues. (Why be way behind the release rev's?) If Java6 must be available, the id should be "osx-java-6", "osx" should be reserved for the best, recommended one or not used at all.
2- do you know if the "p=${binary-revision}" in these lines is needed for Java6? They are not in Java-7-8.Code: Select all
<!-- Download binaries --> <get src="${project.binaries-base}/osx/dcraw?p=${binary-revision}" dest="${project.binaries}/osx/dcraw" usetimestamp="true" /> <get src="${project.binaries-base}/osx/ffmpeg?p=${binary-revision}" dest="${project.binaries}/osx/ffmpeg" usetimestamp="true" /> <get src="${project.binaries-base}/osx/flac?p=${binary-revision}" dest="${project.binaries}/osx/flac" usetimestamp="true" /> <get src="${project.binaries-base}/osx/libmediainfo.dylib?p=${binary-revision}" dest="${project.binaries}/libmediainfo.dylib" usetimestamp="true" /> <get src="${project.binaries-base}/MediaInfo-License.html?p=${binary-revision}" dest="${project.binaries}/MediaInfo-License.html" usetimestamp="true" /> <get src="${project.binaries-base}/osx/mencoder?p=${binary-revision}" dest="${project.binaries}/osx/mencoder" usetimestamp="true" /> <get src="${project.binaries-base}/osx/mplayer?p=${binary-revision}" dest="${project.binaries}/osx/mplayer" usetimestamp="true" /> <get src="${project.binaries-base}/osx/tsMuxeR?p=${binary-revision}" dest="${project.binaries}/osx/tsMuxeR" usetimestamp="true" /> <get src="${project.binaries-base}/osx/tsMuxeR-new?p=${binary-revision}" dest="${project.binaries}/osx/tsMuxeR-new" usetimestamp="true" />
Samsung UN55C8000
Samsung UN55C8000
- Optimus_prime
Nice work mate, but i'm submitting the pull request this week with the pom changes. I'll detail them for you soon but it's an easy fix in the end and to prompted me to get off my arse and do them.
nope it should be done once and once only to build the list of dependencies for storage on your machine (i think thats the way it works, does for me)Cleaning it up now, removing old bad info. Question: the mvn commands:
Edited the new pom to add the old osx section as "osx-Java-6". Works fine for Java-8 but how do I test build the Java-6 (not that I really want to use it).Optimus_prime wrote:Nice work mate, but i'm submitting the pull request this week with the pom changes. I'll detail them for you soon but it's an easy fix in the end and to prompted me to get off my arse and do them.
*** What about the "p=${binary-revision}" stuff? ***
Good - I'll put it into the early "Once Only" section. The old wiki is not clear about a lot of stuff. (Also I have a ubuntu system I can fire up, update & test there too.)Optimus_prime wrote:nope it should be done once and once only to build the list of dependencies for storage on your machine (i think thats the way it works, does for me)Cleaning it up now, removing old bad info. Question: the mvn commands:
Samsung UN55C8000
Samsung UN55C8000
- Optimus_prime
Here mate:
https://github.com/UniversalMediaServer ... r/pull/552
theres the changes i've made and hopefully will be accepted this week
Feel free to submit to me any changes to the wiki in an email (pm'd it to you) and i'll put them in. Thanks for all your help mate
