Can't get stream to play on Samsung BD-E6500
Hi guys,
First and foremost, I want to thank you for the development of this awesome project. I recently purchased a Samsung BD-E6500 which has AllShare, and I've been trying to stream Blu-ray movies from my computer. I hit Cinavia audio muting about 30 minutes into my first movie. After searching all over the web, I learned of the PS3 Media Server, and eventually this new project, which further supports Samsung devices. I feel like I am so close to getting this to work!
First off, does UMS bypass Cinavia via it's transcoding process? Despite this feature, I cannot get any video to stream as of yet on my Blu-ray player. I believe I have installed things correctly on my Macbook Pro, via the UMS-1.10 distribution dmg that was just recently uploaded. I am successful in seeing the UMS on my Samsung device, and I even see the folders of my movie files, however, when I go to play any of the Transcoded options, or the original file itself, the player goes through the "Loading..." screen, and then ends up with a black screen playing nothing. The UMS window on my computer shows that it is "Serving movie_title_here [container: avi] [video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658)]"
When selecting the No Encoding option, it does not show that any transcoding buffering is occurring, which should probably be the case, and when I select a transcoding option, it mysteriously jumps to a Peak Bitrate of 781,249 MB/s. Something is fishy here...
Let me know if I should include the debug.log or if I need to further clarify what is going on.
Thanks so much for your help!
Re: Can't get stream to play on Samsung BD-E6500
Welcome and cheerskarshkarsh92 wrote:First and foremost, I want to thank you for the development of this awesome project.
No, it doesn't. PMS removed the feature a while ago for legal reasons. However if you have a DTS receiver it doesn't matter, since Cinavia only blocks when it is converted to AC3karshkarsh92 wrote:First off, does UMS bypass Cinavia via it's transcoding process?
Yeah the debug.log would be helpful, thankskarshkarsh92 wrote:Let me know if I should include the debug.log or if I need to further clarify what is going on.
I think I do have DTS! So does that mean I can use UMS transcoding to send a DTS stream to my Samsung?
Here's the debug.log:
DEBUG 2012-06-09 15:40:50.788 [main] Choosing java look and feel: com.apple.laf.AquaLookAndFeel
INFO 2012-06-09 15:41:00.361 [main] Starting Universal Media Server 1.1.0
INFO 2012-06-09 15:41:00.372 [main] Based on PS3 Media Server (ps3mediaserver.org) by shagrath, copyright 2008-2012
INFO 2012-06-09 15:41:00.373 [main] http://www.universalmediaserver.com
INFO 2012-06-09 15:41:00.374 [main] Build: b474813fb (2012-06-09)
INFO 2012-06-09 15:41:00.374 [main] Java: 1.6.0_29-Apple Inc.
INFO 2012-06-09 15:41:00.374 [main] OS: Mac OS X x86_64 10.6.8
INFO 2012-06-09 15:41:00.374 [main] Encoding: UTF-8
INFO 2012-06-09 15:41:00.375 [main] Memory: 763 MB
INFO 2012-06-09 15:41:00.375 [main] Working directory: /Applications/Universal Media Server.app/Contents/Resources/Java
INFO 2012-06-09 15:41:00.462 [main] Temp folder: /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver
INFO 2012-06-09 15:41:00.463 [main] Logging config file: /Applications/Universal Media Server.app/Contents/Resources/Java/logback.xml
INFO 2012-06-09 15:41:00.463 [main] debug.log: /Applications/Universal Media Server.app/Contents/Resources/Java/debug.log
INFO 2012-06-09 15:41:00.464 [main] Profile directory: /Users/Karshbook/Library/Application Support/UMS
INFO 2012-06-09 15:41:00.464 [main] Profile path: /Users/Karshbook/Library/Application Support/UMS/UMS.conf
INFO 2012-06-09 15:41:00.464 [main] Profile status: rw
INFO 2012-06-09 15:41:00.466 [main] Profile name: karshs-macbook.home
INFO 2012-06-09 15:41:00.467 [main]
INFO 2012-06-09 15:41:00.487 [main] Loading MediaInfo library
INFO 2012-06-09 15:41:00.837 [main] Loaded MediaInfoLib - v0.7.58
INFO 2012-06-09 15:41:00.896 [main] Loading renderer configurations from /Applications/Universal Media Server.app/Contents/Resources/Java/renderers
INFO 2012-06-09 15:41:00.924 [main] Loading configuration file: AirPlayer.conf
DEBUG 2012-06-09 15:41:00.925 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/AirPlayer.conf
INFO 2012-06-09 15:41:00.975 [main] Loading configuration file: Android.conf
DEBUG 2012-06-09 15:41:00.976 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/Android.conf
INFO 2012-06-09 15:41:00.977 [main] Loading configuration file: Bravia4500.conf
DEBUG 2012-06-09 15:41:00.978 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/Bravia4500.conf
INFO 2012-06-09 15:41:00.980 [main] Loading configuration file: Bravia5500.conf
DEBUG 2012-06-09 15:41:00.981 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/Bravia5500.conf
INFO 2012-06-09 15:41:00.989 [main] Loading configuration file: BraviaEX.conf
DEBUG 2012-06-09 15:41:00.990 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/BraviaEX.conf
INFO 2012-06-09 15:41:01.015 [main] Loading configuration file: DLinkDSM510.conf
DEBUG 2012-06-09 15:41:01.016 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/DLinkDSM510.conf
INFO 2012-06-09 15:41:01.017 [main] Loading configuration file: FreeboxHD.conf
DEBUG 2012-06-09 15:41:01.018 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/FreeboxHD.conf
INFO 2012-06-09 15:41:01.019 [main] Loading configuration file: FreecomMusicPal.conf
DEBUG 2012-06-09 15:41:01.020 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/FreecomMusicPal.conf
INFO 2012-06-09 15:41:01.021 [main] Loading configuration file: iPad-iPhone.conf
DEBUG 2012-06-09 15:41:01.022 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/iPad-iPhone.conf
INFO 2012-06-09 15:41:01.024 [main] Loading configuration file: Kuro.conf
DEBUG 2012-06-09 15:41:01.025 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/Kuro.conf
INFO 2012-06-09 15:41:01.026 [main] Loading configuration file: LGST600.conf
DEBUG 2012-06-09 15:41:01.027 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/LGST600.conf
INFO 2012-06-09 15:41:01.030 [main] Loading configuration file: N900.conf
DEBUG 2012-06-09 15:41:01.030 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/N900.conf
INFO 2012-06-09 15:41:01.032 [main] Loading configuration file: OPPOBDP83.conf
DEBUG 2012-06-09 15:41:01.032 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/OPPOBDP83.conf
INFO 2012-06-09 15:41:01.034 [main] Loading configuration file: OPPOBDP93.conf
DEBUG 2012-06-09 15:41:01.034 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/OPPOBDP93.conf
INFO 2012-06-09 15:41:01.036 [main] Loading configuration file: Panasonic.conf
DEBUG 2012-06-09 15:41:01.036 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/Panasonic.conf
INFO 2012-06-09 15:41:01.083 [main] Loading configuration file: Philips.conf
DEBUG 2012-06-09 15:41:01.084 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/Philips.conf
INFO 2012-06-09 15:41:01.086 [main] Loading configuration file: PhilipsPFL.conf
DEBUG 2012-06-09 15:41:01.087 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/PhilipsPFL.conf
INFO 2012-06-09 15:41:01.112 [main] Loading configuration file: PopcornHour.conf
DEBUG 2012-06-09 15:41:01.113 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/PopcornHour.conf
INFO 2012-06-09 15:41:01.121 [main] Loading configuration file: PS3.conf
DEBUG 2012-06-09 15:41:01.121 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/PS3.conf
INFO 2012-06-09 15:41:01.173 [main] Loading configuration file: Realtek.conf
DEBUG 2012-06-09 15:41:01.174 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/Realtek.conf
INFO 2012-06-09 15:41:01.176 [main] Loading configuration file: SamsungAllShare.conf
DEBUG 2012-06-09 15:41:01.177 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/SamsungAllShare.conf
INFO 2012-06-09 15:41:01.178 [main] Loading configuration file: SamsungWiseLink.conf
DEBUG 2012-06-09 15:41:01.179 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/SamsungWiseLink.conf
INFO 2012-06-09 15:41:01.182 [main] Loading configuration file: Showtime3.conf
DEBUG 2012-06-09 15:41:01.183 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/Showtime3.conf
INFO 2012-06-09 15:41:01.186 [main] Loading configuration file: SonyBluray.conf
DEBUG 2012-06-09 15:41:01.187 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/SonyBluray.conf
INFO 2012-06-09 15:41:01.189 [main] Loading configuration file: Streamium.conf
DEBUG 2012-06-09 15:41:01.190 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/Streamium.conf
INFO 2012-06-09 15:41:01.191 [main] Loading configuration file: WDTVLive.conf
DEBUG 2012-06-09 15:41:01.192 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/WDTVLive.conf
INFO 2012-06-09 15:41:01.193 [main] Loading configuration file: WMP.conf
DEBUG 2012-06-09 15:41:01.193 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/WMP.conf
INFO 2012-06-09 15:41:01.195 [main] Loading configuration file: XBMC.conf
DEBUG 2012-06-09 15:41:01.196 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/XBMC.conf
INFO 2012-06-09 15:41:01.197 [main] Loading configuration file: XBOX360.conf
DEBUG 2012-06-09 15:41:01.197 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/XBOX360.conf
INFO 2012-06-09 15:41:01.203 [main] Loading configuration file: YamahaRXV671.conf
DEBUG 2012-06-09 15:41:01.204 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/YamahaRXV671.conf
INFO 2012-06-09 15:41:01.204 [main] Checking MPlayer font cache. It can take a minute or so.
DEBUG 2012-06-09 15:41:01.205 [main] launching: osx/mplayer
INFO 2012-06-09 15:41:01.981 [main] Done!
INFO 2012-06-09 15:41:02.044 [main] Searching for plugins in /Applications/Universal Media Server.app/Contents/Resources/Java/plugins
INFO 2012-06-09 15:41:02.045 [main] No plugins found
INFO 2012-06-09 15:41:02.060 [main] Registering transcoding engine: FFmpeg Audio
INFO 2012-06-09 15:41:02.069 [main] Registering transcoding engine: MEncoder
INFO 2012-06-09 15:41:02.069 [main] Registering transcoding engine: MPlayer Audio
INFO 2012-06-09 15:41:02.070 [main] Registering transcoding engine: MEncoder Web
INFO 2012-06-09 15:41:02.070 [main] Registering transcoding engine: MPlayer Video Dump
INFO 2012-06-09 15:41:02.070 [main] Registering transcoding engine: MPlayer Web
INFO 2012-06-09 15:41:02.072 [main] Registering transcoding engine: tsMuxeR
INFO 2012-06-09 15:41:02.073 [main] Registering transcoding engine: Audio High Fidelity
INFO 2012-06-09 15:41:02.074 [main] Registering transcoding engine: VLC Audio Streaming
INFO 2012-06-09 15:41:02.074 [main] Registering transcoding engine: VLC Video Streaming
INFO 2012-06-09 15:41:02.074 [main] Registering transcoding engine: dcraw Thumbnailer
INFO 2012-06-09 15:41:02.188 [main] Using address /192.168.1.7 found on network interface: name:en1 (en1)
INFO 2012-06-09 15:41:02.188 [main] Created socket: /192.168.1.7:5001
INFO 2012-06-09 15:41:02.492 [main] Checking shared folder: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN
INFO 2012-06-09 15:41:02.493 [main] Checking shared folder: /Users/Karshbook/Desktop/50 BDRip
DEBUG 2012-06-09 15:41:02.611 [main] Sending ALIVE...
INFO 2012-06-09 15:41:02.643 [main] Using the following UUID configured in UMS.conf: 2c7f986e-5642-4bb7-b80c-b074455a25d3
INFO 2012-06-09 15:41:05.779 [New I/O server worker #1-1] No IP filter specified, access granted to /192.168.1.12
INFO 2012-06-09 15:41:05.826 [New I/O server worker #1-1] Another renderer like Samsung AllShare was found!
INFO 2012-06-09 15:41:05.844 [pool-4-thread-1] Checking IP: 192.168.1.12 for Samsung AllShare
INFO 2012-06-09 15:41:05.883 [pool-4-thread-1] Renderer Samsung AllShare found on this address: new-host-2.home (192.168.1.12)
DEBUG 2012-06-09 15:41:05.917 [pool-4-thread-1] Starting ping -c 3 -s 64000 192.168.1.12
DEBUG 2012-06-09 15:41:06.078 [Thread-9] ping: sendto: Message too long
DEBUG 2012-06-09 15:41:06.101 [pool-4-thread-1] Unix process ID (ping): 43270
DEBUG 2012-06-09 15:41:07.070 [Thread-9] ping: sendto: Message too long
DEBUG 2012-06-09 15:41:07.918 [SpeedStats Failsafe] Stopping Unix process 43270: ping-0
INFO 2012-06-09 15:41:08.129 [New I/O server worker #1-3] No IP filter specified, access granted to /192.168.1.15
INFO 2012-06-09 15:41:08.177 [New I/O server worker #1-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Mozilla/4.0 (compatible)
INFO 2012-06-09 15:41:08.241 [main] The server should now appear on your renderer
INFO 2012-06-09 15:41:10.591 [pool-4-thread-1] Checking IP: 192.168.1.15 for Streamium
INFO 2012-06-09 15:41:10.637 [pool-4-thread-1] Renderer Streamium found on this address: 00e036fa2536.home (192.168.1.15)
DEBUG 2012-06-09 15:41:10.640 [pool-4-thread-1] Starting ping -c 3 -s 64000 192.168.1.15
DEBUG 2012-06-09 15:41:10.682 [Thread-12] ping: sendto: Message too long
DEBUG 2012-06-09 15:41:10.683 [pool-4-thread-1] Unix process ID (ping): 43272
DEBUG 2012-06-09 15:41:11.675 [Thread-12] ping: sendto: Message too long
DEBUG 2012-06-09 15:41:12.655 [SpeedStats Failsafe] Stopping Unix process 43272: ping-1
DEBUG 2012-06-09 15:41:18.240 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 15:41:42.269 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 15:44:46.310 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 15:45:21.502 [background-task-0] singleton task restart started
DEBUG 2012-06-09 15:45:21.503 [background-task-0-restart(0)] task started
INFO 2012-06-09 15:45:21.503 [background-task-0-restart(0)] Sending BYEBYE...
INFO 2012-06-09 15:45:25.761 [background-task-0-restart(0)] Stopping server on host 192.168.1.7 and port 5001...
INFO 2012-06-09 15:45:26.784 [background-task-0-restart(0)] Using address /192.168.1.7 found on network interface: name:en1 (en1)
INFO 2012-06-09 15:45:26.785 [background-task-0-restart(0)] Created socket: /192.168.1.7:5001
DEBUG 2012-06-09 15:45:26.786 [background-task-0-restart(0)] Sending ALIVE...
DEBUG 2012-06-09 15:45:30.108 [background-task-0-restart(0)] task ended
DEBUG 2012-06-09 15:45:39.401 [New I/O server worker #2-3] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
DEBUG 2012-06-09 15:45:39.449 [New I/O server worker #2-4] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
DEBUG 2012-06-09 15:45:40.118 [New I/O server worker #2-1] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
DEBUG 2012-06-09 15:45:40.142 [New I/O server worker #2-2] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
INFO 2012-06-09 15:45:40.162 [New I/O server worker #2-3] Checking shared folder: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN
INFO 2012-06-09 15:45:40.179 [New I/O server worker #2-3] Checking shared folder: /Users/Karshbook/Desktop/50 BDRip
DEBUG 2012-06-09 15:45:42.371 [New I/O server worker #2-1] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
DEBUG 2012-06-09 15:45:42.454 [pool-9-thread-1] Starting "/Applications/Universal Media Server.app/Contents/Resources/Java/osx/ffmpeg" -ss 1 -i "/Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv" -an -an -s 320x180 -vframes 1 -f image2 pipe:
DEBUG 2012-06-09 15:45:42.554 [pool-9-thread-1] Attaching thread: ffmpeg-2
DEBUG 2012-06-09 15:45:42.555 [pool-9-thread-1] Unix process ID (/Applications/Universal Media Server.app/Contents/Resources/Java/osx/ffmpeg): 43317
DEBUG 2012-06-09 15:45:44.625 [New I/O server worker #2-4] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
DEBUG 2012-06-09 15:45:44.648 [pool-11-thread-1] Duplicate 21 Jump Street BDRip.mkv for direct streaming to renderer: Samsung AllShare
DEBUG 2012-06-09 15:45:45.226 [Buffered IO End Checker] Stopping Unix process 43317: ffmpeg-2
DEBUG 2012-06-09 15:45:47.019 [New I/O server worker #2-3] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
INFO 2012-06-09 15:45:51.179 [New I/O server worker #2-2] Starting transcode/remux of 21 Jump Street BDRip.mkv
DEBUG 2012-06-09 15:45:51.263 [mencoder-3] Starting "/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder" -ss 0 -quiet "/Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv" -quiet -quiet -oac lavc -of mpeg -quiet -quiet -mpegopts format=mpeg2:muxrate=500000:vbuf_size=1194:abuf_size=64 -ovc lavc -channels 6 -lavdopts debug=0:threads=2 -lavcopts autoaspect=1:vcodec=mpeg2video:acodec=ac3:abitrate=640:threads=2:keyint=5:vqscale=1:vqmin=2:vrc_maxrate=11000:vrc_buf_size=1835 -quiet -quiet -subdelay 20000 -quiet -quiet -ofps 24000/1001 -quiet -quiet -lavdopts fast -mc 0 -noskip -af lavcresample=48000 -srate 48000 -o - -really-quiet -msglevel statusline=2
DEBUG 2012-06-09 15:45:51.448 [mencoder-3] Attaching thread: mencoder-3
DEBUG 2012-06-09 15:45:51.450 [mencoder-3] Unix process ID (/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder): 43326
INFO 2012-06-09 15:45:57.387 [StartPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv
DEBUG 2012-06-09 15:45:58.578 [New I/O server worker #2-1] Setting InputStream new position to: 99,999,750,000
DEBUG 2012-06-09 15:46:03.673 [New I/O server worker #2-2] Setting InputStream new position to: 99,999,500,000
DEBUG 2012-06-09 15:46:06.172 [New I/O server worker #2-1] Caught exception
java.lang.ArrayIndexOutOfBoundsException: 175314800
at net.pms.io.BufferedOutputFileImpl.read(BufferedOutputFileImpl.java:727) ~[ums-1.1.0.jar:na]
at net.pms.io.WaitBufferedInputStream.read(WaitBufferedInputStream.java:43) ~[ums-1.1.0.jar:na]
at java.io.FilterInputStream.read(FilterInputStream.java:66) ~[na:1.6.0_29]
at java.io.PushbackInputStream.read(PushbackInputStream.java:122) ~[na:1.6.0_29]
at org.jboss.netty.handler.stream.ChunkedStream.hasNextChunk(ChunkedStream.java:78) ~[netty-3.2.4.Final.jar:na]
at org.jboss.netty.handler.stream.ChunkedStream.nextChunk(ChunkedStream.java:96) ~[netty-3.2.4.Final.jar:na]
at org.jboss.netty.handler.stream.ChunkedWriteHandler.flush(ChunkedWriteHandler.java:208) ~[netty-3.2.4.Final.jar:na]
at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleDownstream(ChunkedWriteHandler.java:124) ~[netty-3.2.4.Final.jar:na]
at org.jboss.netty.channel.Channels.write(Channels.java:611) ~[netty-3.2.4.Final.jar:na]
at org.jboss.netty.channel.Channels.write(Channels.java:578) ~[netty-3.2.4.Final.jar:na]
at org.jboss.netty.channel.AbstractChannel.write(AbstractChannel.java:259) ~[netty-3.2.4.Final.jar:na]
at net.pms.network.RequestV2.answer(RequestV2.java:805) ~[ums-1.1.0.jar:na]
at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:313) ~[ums-1.1.0.jar:na]
at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:271) ~[ums-1.1.0.jar:na]
at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:148) ~[netty-3.2.4.Final.jar:na]
at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:116) ~[netty-3.2.4.Final.jar:na]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:302) ~[netty-3.2.4.Final.jar:na]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.unfoldAndfireMessageReceived(ReplayingDecoder.java:522) ~[netty-3.2.4.Final.jar:na]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:506) ~[netty-3.2.4.Final.jar:na]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:443) ~[netty-3.2.4.Final.jar:na]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:274) ~[netty-3.2.4.Final.jar:na]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:261) ~[netty-3.2.4.Final.jar:na]
at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:349) ~[netty-3.2.4.Final.jar:na]
at org.jboss.netty.channel.socket.nio.NioWorker.processSelectedKeys(NioWorker.java:280) ~[netty-3.2.4.Final.jar:na]
at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:200) ~[netty-3.2.4.Final.jar:na]
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) [na:1.6.0_29]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) [na:1.6.0_29]
at java.lang.Thread.run(Thread.java:680) [na:1.6.0_29]
DEBUG 2012-06-09 15:46:08.676 [Buffered IO End Checker] Stopping Unix process 43326: mencoder-3
DEBUG 2012-06-09 15:46:08.681 [Thread-23] Error consuming stream of spawned process: Stream closed
INFO 2012-06-09 15:46:08.794 [New I/O server worker #2-3] Starting transcode/remux of 21 Jump Street BDRip.mkv
DEBUG 2012-06-09 15:46:08.814 [mencoder-4] Starting "/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder" -ss 0 -quiet "/Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv" -quiet -quiet -oac lavc -of mpeg -quiet -quiet -mpegopts format=mpeg2:muxrate=500000:vbuf_size=1194:abuf_size=64 -ovc lavc -channels 6 -lavdopts debug=0:threads=2 -lavcopts autoaspect=1:vcodec=mpeg2video:acodec=ac3:abitrate=640:threads=2:keyint=5:vqscale=1:vqmin=2:vrc_maxrate=11000:vrc_buf_size=1835 -quiet -quiet -subdelay 20000 -quiet -quiet -ofps 24000/1001 -quiet -quiet -lavdopts fast -mc 0 -noskip -af lavcresample=48000 -srate 48000 -o - -really-quiet -msglevel statusline=2
DEBUG 2012-06-09 15:46:09.123 [mencoder-4] Attaching thread: mencoder-4
DEBUG 2012-06-09 15:46:09.126 [mencoder-4] Unix process ID (/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder): 43329
INFO 2012-06-09 15:46:13.221 [StopPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv
DEBUG 2012-06-09 15:46:15.054 [New I/O server worker #2-3] Setting InputStream new position to: 99,999,000,000
INFO 2012-06-09 15:46:15.059 [StartPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv
DEBUG 2012-06-09 15:46:20.163 [New I/O server worker #2-4] Setting InputStream new position to: 99,998,000,000
DEBUG 2012-06-09 15:46:22.565 [New I/O server worker #2-3] Caught exception
java.lang.ArrayIndexOutOfBoundsException: 174564800
DEBUG 2012-06-09 15:46:25.069 [Buffered IO End Checker] Stopping Unix process 43329: mencoder-4
DEBUG 2012-06-09 15:46:25.088 [Thread-27] Error consuming stream of spawned process: Stream closed
INFO 2012-06-09 15:46:25.175 [New I/O server worker #2-1] Starting transcode/remux of 21 Jump Street BDRip.mkv
DEBUG 2012-06-09 15:46:25.195 [mencoder-5] Starting "/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder" -ss 0 -quiet "/Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv" -quiet -quiet -oac lavc -of mpeg -quiet -quiet -mpegopts format=mpeg2:muxrate=500000:vbuf_size=1194:abuf_size=64 -ovc lavc -channels 6 -lavdopts debug=0:threads=2 -lavcopts autoaspect=1:vcodec=mpeg2video:acodec=ac3:abitrate=640:threads=2:keyint=5:vqscale=1:vqmin=2:vrc_maxrate=11000:vrc_buf_size=1835 -quiet -quiet -subdelay 20000 -quiet -quiet -ofps 24000/1001 -quiet -quiet -lavdopts fast -mc 0 -noskip -af lavcresample=48000 -srate 48000 -o - -really-quiet -msglevel statusline=2
DEBUG 2012-06-09 15:46:25.482 [mencoder-5] Attaching thread: mencoder-5
DEBUG 2012-06-09 15:46:25.483 [mencoder-5] Unix process ID (/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder): 43332
INFO 2012-06-09 15:46:29.173 [StopPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv
DEBUG 2012-06-09 15:46:31.390 [New I/O server worker #2-1] Setting InputStream new position to: 99,996,000,000
INFO 2012-06-09 15:46:31.459 [StartPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv
DEBUG 2012-06-09 15:46:36.546 [New I/O server worker #2-2] Setting InputStream new position to: 1
DEBUG 2012-06-09 15:46:38.978 [New I/O server worker #2-1] Caught exception
java.lang.ArrayIndexOutOfBoundsException: 171564800
DEBUG 2012-06-09 15:46:39.129 [Buffered IO End Checker] Stopping Unix process 43332: mencoder-5
DEBUG 2012-06-09 15:46:39.137 [Thread-31] Error consuming stream of spawned process: Stream closed
INFO 2012-06-09 15:46:43.000 [StopPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv
DEBUG 2012-06-09 15:47:49.621 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 15:50:54.035 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-09 15:51:42.645 [New I/O server worker #2-4] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
DEBUG 2012-06-09 15:51:42.697 [New I/O server worker #2-1] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
DEBUG 2012-06-09 15:51:43.350 [New I/O server worker #2-2] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
DEBUG 2012-06-09 15:51:43.372 [New I/O server worker #2-3] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
DEBUG 2012-06-09 15:51:44.991 [New I/O server worker #2-2] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
DEBUG 2012-06-09 15:51:49.083 [New I/O server worker #2-1] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
DEBUG 2012-06-09 15:51:50.829 [New I/O server worker #2-4] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
INFO 2012-06-09 15:51:57.275 [New I/O server worker #2-3] Starting transcode/remux of 21 Jump Street BDRip.mkv
DEBUG 2012-06-09 15:51:57.331 [mkfifo-9] Starting mkfifo -m 777 /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271517330tsmuxerout.ts
DEBUG 2012-06-09 15:51:57.383 [mkfifo-10] Starting mkfifo -m 777 /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271517311ffmpegvideo
DEBUG 2012-06-09 15:51:57.386 [mkfifo-11] Starting mkfifo -m 777 /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271517311videoout
DEBUG 2012-06-09 15:51:57.423 [mkfifo-11] Unix process ID (mkfifo): 43401
DEBUG 2012-06-09 15:51:57.424 [mkfifo-9] Unix process ID (mkfifo): 43399
DEBUG 2012-06-09 15:51:57.424 [mkfifo-10] Unix process ID (mkfifo): 43400
DEBUG 2012-06-09 15:51:57.586 [mencoder-6] Starting "/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder" -ss 0 "/Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv" -quiet -quiet -really-quiet -msglevel statusline=2 -ovc copy -nosound -mc 0 -noskip -of rawvideo -o /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271517311ffmpegvideo
DEBUG 2012-06-09 15:51:57.623 [mencoder-6] Attaching thread: mencoder-6
DEBUG 2012-06-09 15:51:57.623 [mencoder-6] Unix process ID (/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder): 43402
DEBUG 2012-06-09 15:51:57.636 [mkfifo-12] Starting mkfifo -m 777 /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271517311ffmpegaudio01
DEBUG 2012-06-09 15:51:57.647 [mkfifo-13] Starting mkfifo -m 777 /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271517311audioout
DEBUG 2012-06-09 15:51:57.680 [mkfifo-13] Unix process ID (mkfifo): 43405
DEBUG 2012-06-09 15:51:57.683 [mkfifo-12] Unix process ID (mkfifo): 43404
DEBUG 2012-06-09 15:51:57.849 [mencoder-7] Starting "/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder" -ss 0 "/Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv" -quiet -quiet -really-quiet -msglevel statusline=2 -channels 6 -ovc copy -of rawaudio -mc 0 -noskip -oac lavc -quiet -quiet -lavcopts acodec=ac3:abitrate=640 -af lavcresample=48000 -srate 48000 -quiet -quiet -o /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271517311ffmpegaudio01
DEBUG 2012-06-09 15:51:57.899 [mencoder-7] Attaching thread: mencoder-7
DEBUG 2012-06-09 15:51:57.900 [mencoder-7] Unix process ID (/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder): 43406
DEBUG 2012-06-09 15:51:57.949 [tsMuxeR-8] Starting "/Applications/Universal Media Server.app/Contents/Resources/Java/osx/tsMuxeR" /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/pms-tsmuxer.meta /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271517330tsmuxerout.ts
DEBUG 2012-06-09 15:51:58.008 [tsMuxeR-8] Reading pipe: /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271517330tsmuxerout.ts
DEBUG 2012-06-09 15:51:58.200 [tsMuxeR-8] Attaching thread: tsMuxeR-8
DEBUG 2012-06-09 15:51:58.201 [Thread-62] SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net
DEBUG 2012-06-09 15:51:58.201 [Thread-62] 100.0% complete
DEBUG 2012-06-09 15:51:58.202 [tsMuxeR-8] Unix process ID (/Applications/Universal Media Server.app/Contents/Resources/Java/osx/tsMuxeR): 43407
DEBUG 2012-06-09 15:51:58.347 [Thread-62] M100.0% complete
DEBUG 2012-06-09 15:51:58.601 [Thread-62] M100.0% complete
DEBUG 2012-06-09 15:51:58.886 [Thread-62] M100.0% complete
DEBUG 2012-06-09 15:51:59.136 [Thread-62] M100.0% complete
DEBUG 2012-06-09 15:51:59.386 [Thread-62] M100.0% complete
DEBUG 2012-06-09 15:51:59.640 [Thread-62] M100.0% complete
DEBUG 2012-06-09 15:51:59.891 [Thread-62] M100.0% complete
DEBUG 2012-06-09 15:52:00.141 [Thread-62] M100.0% complete
DEBUG 2012-06-09 15:52:00.391 [Thread-62] M100.0% complete
DEBUG 2012-06-09 15:52:00.485 [Thread-59] Pes packet len too large ( >100Mb). Bad stream or invalid codec speciffed.
INFO 2012-06-09 15:52:00.513 [tsMuxeR-8] Process /Applications/Universal Media Server.app/Contents/Resources/Java/osx/tsMuxeR has a return code of 254! Maybe an error occurred... check the log file
DEBUG 2012-06-09 15:52:00.533 [tsMuxeR-8] Stopping Unix process 43399: mkfifo-9
DEBUG 2012-06-09 15:52:00.560 [tsMuxeR-8] Stopping Unix process 43402: mencoder-6
DEBUG 2012-06-09 15:52:00.563 [tsMuxeR-8] Stopping Unix process 43406: mencoder-7
INFO 2012-06-09 15:52:02.955 [StartPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv
DEBUG 2012-06-09 15:52:05.477 [Buffered IO End Checker] Stopping Unix process 43407: tsMuxeR-8
INFO 2012-06-09 15:52:06.981 [StopPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv
DEBUG 2012-06-09 15:52:09.871 [New I/O server worker #2-1] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
DEBUG 2012-06-09 15:52:09.980 [New I/O server worker #2-2] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
DEBUG 2012-06-09 15:52:10.020 [New I/O server worker #2-3] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
DEBUG 2012-06-09 15:52:10.047 [New I/O server worker #2-4] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
WARN 2012-06-09 15:52:10.564 [Process Destroyer] Sending kill -14 to the Unix process: 43402
WARN 2012-06-09 15:52:10.565 [Process Destroyer] Sending kill -14 to the Unix process: 43406
DEBUG 2012-06-09 15:52:10.688 [Process Destroyer] Successfully sent kill -14 to the Unix process: 43406
DEBUG 2012-06-09 15:52:10.701 [Process Destroyer] Successfully sent kill -14 to the Unix process: 43402
INFO 2012-06-09 15:52:14.890 [New I/O server worker #2-3] Starting transcode/remux of 21 Jump Street BDRip.mkv
DEBUG 2012-06-09 15:52:14.898 [mkfifo-25] Starting mkfifo -m 777 /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271534897tsmuxerout.ts
DEBUG 2012-06-09 15:52:14.934 [mkfifo-25] Unix process ID (mkfifo): 43412
DEBUG 2012-06-09 15:52:14.949 [mkfifo-26] Starting mkfifo -m 777 /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271534897ffmpegvideo
DEBUG 2012-06-09 15:52:14.957 [mkfifo-27] Starting mkfifo -m 777 /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271534897videoout
DEBUG 2012-06-09 15:52:15.009 [mkfifo-27] Unix process ID (mkfifo): 43414
DEBUG 2012-06-09 15:52:15.010 [mkfifo-26] Unix process ID (mkfifo): 43413
DEBUG 2012-06-09 15:52:15.158 [mencoder-22] Starting "/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder" -ss 0 "/Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv" -quiet -quiet -really-quiet -msglevel statusline=2 -ovc copy -nosound -mc 0 -noskip -of rawvideo -o /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271534897ffmpegvideo
DEBUG 2012-06-09 15:52:15.207 [mencoder-22] Attaching thread: mencoder-22
DEBUG 2012-06-09 15:52:15.214 [mkfifo-28] Starting mkfifo -m 777 /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271534897ffmpegaudio01
DEBUG 2012-06-09 15:52:15.225 [mkfifo-29] Starting mkfifo -m 777 /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271534897audioout
DEBUG 2012-06-09 15:52:15.262 [mencoder-22] Unix process ID (/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder): 43415
DEBUG 2012-06-09 15:52:15.266 [mkfifo-29] Unix process ID (mkfifo): 43417
DEBUG 2012-06-09 15:52:15.270 [mkfifo-28] Unix process ID (mkfifo): 43416
DEBUG 2012-06-09 15:52:15.425 [mencoder-23] Starting "/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder" -ss 0 "/Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv" -quiet -quiet -really-quiet -msglevel statusline=2 -channels 6 -ovc copy -of rawaudio -mc 0 -noskip -oac lavc -quiet -quiet -lavcopts acodec=ac3:abitrate=640 -af lavcresample=48000 -srate 48000 -quiet -quiet -o /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271534897ffmpegaudio01
DEBUG 2012-06-09 15:52:15.460 [mencoder-23] Attaching thread: mencoder-23
DEBUG 2012-06-09 15:52:15.461 [mencoder-23] Unix process ID (/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder): 43418
DEBUG 2012-06-09 15:52:15.525 [tsMuxeR-24] Starting "/Applications/Universal Media Server.app/Contents/Resources/Java/osx/tsMuxeR" /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/pms-tsmuxer.meta /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271534897tsmuxerout.ts
DEBUG 2012-06-09 15:52:15.561 [tsMuxeR-24] Reading pipe: /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271534897tsmuxerout.ts
DEBUG 2012-06-09 15:52:15.856 [tsMuxeR-24] Attaching thread: tsMuxeR-24
DEBUG 2012-06-09 15:52:15.859 [Thread-104] SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net
DEBUG 2012-06-09 15:52:15.859 [Thread-104] 100.0% complete
DEBUG 2012-06-09 15:52:15.859 [Thread-104] M100.0% complete
DEBUG 2012-06-09 15:52:15.873 [tsMuxeR-24] Unix process ID (/Applications/Universal Media Server.app/Contents/Resources/Java/osx/tsMuxeR): 43419
DEBUG 2012-06-09 15:52:16.074 [Thread-104] M100.0% complete
DEBUG 2012-06-09 15:52:16.324 [Thread-104] M100.0% complete
DEBUG 2012-06-09 15:52:16.574 [Thread-104] M100.0% complete
DEBUG 2012-06-09 15:52:16.824 [Thread-104] M100.0% complete
DEBUG 2012-06-09 15:52:17.075 [Thread-104] M100.0% complete
DEBUG 2012-06-09 15:52:17.325 [Thread-104] M100.0% complete
DEBUG 2012-06-09 15:52:17.526 [Thread-101] Pes packet len too large ( >100Mb). Bad stream or invalid codec speciffed.
INFO 2012-06-09 15:52:17.527 [tsMuxeR-24] Process /Applications/Universal Media Server.app/Contents/Resources/Java/osx/tsMuxeR has a return code of 254! Maybe an error occurred... check the log file
DEBUG 2012-06-09 15:52:17.528 [tsMuxeR-24] Stopping Unix process 43412: mkfifo-25
DEBUG 2012-06-09 15:52:17.529 [tsMuxeR-24] Stopping Unix process 43415: mencoder-22
DEBUG 2012-06-09 15:52:17.529 [tsMuxeR-24] Stopping Unix process 43418: mencoder-23
INFO 2012-06-09 15:52:20.555 [StartPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv
DEBUG 2012-06-09 15:52:23.058 [Buffered IO End Checker] Stopping Unix process 43419: tsMuxeR-24
DEBUG 2012-06-09 15:52:24.106 [New I/O server worker #2-1] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
DEBUG 2012-06-09 15:52:24.206 [New I/O server worker #2-2] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
DEBUG 2012-06-09 15:52:24.236 [New I/O server worker #2-3] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
DEBUG 2012-06-09 15:52:24.266 [New I/O server worker #2-4] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
INFO 2012-06-09 15:52:24.578 [StopPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv
INFO 2012-06-09 15:52:26.990 [StartPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv
WARN 2012-06-09 15:52:27.530 [Process Destroyer] Sending kill -14 to the Unix process: 43415
WARN 2012-06-09 15:52:27.539 [Process Destroyer] Sending kill -14 to the Unix process: 43418
DEBUG 2012-06-09 15:52:27.596 [Process Destroyer] Successfully sent kill -14 to the Unix process: 43418
DEBUG 2012-06-09 15:52:27.603 [Process Destroyer] Successfully sent kill -14 to the Unix process: 43415
INFO 2012-06-09 15:53:20.661 [PMS Listeners Stopper] Sending BYEBYE...
DEBUG 2012-06-09 15:53:20.662 [UPNP-AliveMessageSender] Error while sending periodic alive message: sleep interrupted
DEBUG 2012-06-09 15:53:24.461 [PMS Listeners Stopper] Forcing shutdown of all active processes
INFO 2012-06-09 15:53:24.461 [PMS Listeners Stopper] Stopping server on host 192.168.1.7 and port 5001...
If your TV supports it you can enable it in the program settings (Transcoding Settings tab)karshkarsh92 wrote:I think I do have DTS! So does that mean I can use UMS transcoding to send a DTS stream to my Samsung?
Hmm OK there's some weird stuff happening with memory there. Can you see if this one is any different?karshkarsh92 wrote:Here's the debug.log:
DEBUG 2012-06-09 15:40:50.788 [main] Choosing java look and feel: com.apple.laf.AquaLookAndFeel INFO 2012-06-09 15:41:00.361 [main] Starting Universal Media Server 1.1.0 INFO 2012-06-09 15:41:00.372 [main] Based on PS3 Media Server (ps3mediaserver.org) by shagrath, copyright 2008-2012 INFO 2012-06-09 15:41:00.373 [main] http://www.universalmediaserver.com INFO 2012-06-09 15:41:00.373 [main] INFO 2012-06-09 15:41:00.374 [main] Build: b474813fb (2012-06-09) INFO 2012-06-09 15:41:00.374 [main] Java: 1.6.0_29-Apple Inc. INFO 2012-06-09 15:41:00.374 [main] OS: Mac OS X x86_64 10.6.8 INFO 2012-06-09 15:41:00.374 [main] Encoding: UTF-8 INFO 2012-06-09 15:41:00.375 [main] Memory: 763 MB INFO 2012-06-09 15:41:00.375 [main] INFO 2012-06-09 15:41:00.375 [main] Working directory: /Applications/Universal Media Server.app/Contents/Resources/Java INFO 2012-06-09 15:41:00.462 [main] Temp folder: /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver INFO 2012-06-09 15:41:00.463 [main] Logging config file: /Applications/Universal Media Server.app/Contents/Resources/Java/logback.xml INFO 2012-06-09 15:41:00.463 [main] debug.log: /Applications/Universal Media Server.app/Contents/Resources/Java/debug.log INFO 2012-06-09 15:41:00.463 [main] INFO 2012-06-09 15:41:00.464 [main] Profile directory: /Users/Karshbook/Library/Application Support/UMS INFO 2012-06-09 15:41:00.464 [main] Profile path: /Users/Karshbook/Library/Application Support/UMS/UMS.conf INFO 2012-06-09 15:41:00.464 [main] Profile status: rw INFO 2012-06-09 15:41:00.466 [main] Profile name: karshs-macbook.home INFO 2012-06-09 15:41:00.467 [main] INFO 2012-06-09 15:41:00.487 [main] Loading MediaInfo library INFO 2012-06-09 15:41:00.837 [main] Loaded MediaInfoLib - v0.7.58 INFO 2012-06-09 15:41:00.896 [main] Loading renderer configurations from /Applications/Universal Media Server.app/Contents/Resources/Java/renderers INFO 2012-06-09 15:41:00.924 [main] Loading configuration file: AirPlayer.conf DEBUG 2012-06-09 15:41:00.925 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/AirPlayer.conf INFO 2012-06-09 15:41:00.975 [main] Loading configuration file: Android.conf DEBUG 2012-06-09 15:41:00.976 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/Android.conf INFO 2012-06-09 15:41:00.977 [main] Loading configuration file: Bravia4500.conf DEBUG 2012-06-09 15:41:00.978 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/Bravia4500.conf INFO 2012-06-09 15:41:00.980 [main] Loading configuration file: Bravia5500.conf DEBUG 2012-06-09 15:41:00.981 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/Bravia5500.conf INFO 2012-06-09 15:41:00.989 [main] Loading configuration file: BraviaEX.conf DEBUG 2012-06-09 15:41:00.990 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/BraviaEX.conf INFO 2012-06-09 15:41:01.015 [main] Loading configuration file: DLinkDSM510.conf DEBUG 2012-06-09 15:41:01.016 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/DLinkDSM510.conf INFO 2012-06-09 15:41:01.017 [main] Loading configuration file: FreeboxHD.conf DEBUG 2012-06-09 15:41:01.018 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/FreeboxHD.conf INFO 2012-06-09 15:41:01.019 [main] Loading configuration file: FreecomMusicPal.conf DEBUG 2012-06-09 15:41:01.020 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/FreecomMusicPal.conf INFO 2012-06-09 15:41:01.021 [main] Loading configuration file: iPad-iPhone.conf DEBUG 2012-06-09 15:41:01.022 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/iPad-iPhone.conf INFO 2012-06-09 15:41:01.024 [main] Loading configuration file: Kuro.conf DEBUG 2012-06-09 15:41:01.025 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/Kuro.conf INFO 2012-06-09 15:41:01.026 [main] Loading configuration file: LGST600.conf DEBUG 2012-06-09 15:41:01.027 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/LGST600.conf INFO 2012-06-09 15:41:01.030 [main] Loading configuration file: N900.conf DEBUG 2012-06-09 15:41:01.030 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/N900.conf INFO 2012-06-09 15:41:01.032 [main] Loading configuration file: OPPOBDP83.conf DEBUG 2012-06-09 15:41:01.032 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/OPPOBDP83.conf INFO 2012-06-09 15:41:01.034 [main] Loading configuration file: OPPOBDP93.conf DEBUG 2012-06-09 15:41:01.034 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/OPPOBDP93.conf INFO 2012-06-09 15:41:01.036 [main] Loading configuration file: Panasonic.conf DEBUG 2012-06-09 15:41:01.036 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/Panasonic.conf INFO 2012-06-09 15:41:01.083 [main] Loading configuration file: Philips.conf DEBUG 2012-06-09 15:41:01.084 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/Philips.conf INFO 2012-06-09 15:41:01.086 [main] Loading configuration file: PhilipsPFL.conf DEBUG 2012-06-09 15:41:01.087 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/PhilipsPFL.conf INFO 2012-06-09 15:41:01.112 [main] Loading configuration file: PopcornHour.conf DEBUG 2012-06-09 15:41:01.113 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/PopcornHour.conf INFO 2012-06-09 15:41:01.121 [main] Loading configuration file: PS3.conf DEBUG 2012-06-09 15:41:01.121 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/PS3.conf INFO 2012-06-09 15:41:01.173 [main] Loading configuration file: Realtek.conf DEBUG 2012-06-09 15:41:01.174 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/Realtek.conf INFO 2012-06-09 15:41:01.176 [main] Loading configuration file: SamsungAllShare.conf DEBUG 2012-06-09 15:41:01.177 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/SamsungAllShare.conf INFO 2012-06-09 15:41:01.178 [main] Loading configuration file: SamsungWiseLink.conf DEBUG 2012-06-09 15:41:01.179 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/SamsungWiseLink.conf INFO 2012-06-09 15:41:01.182 [main] Loading configuration file: Showtime3.conf DEBUG 2012-06-09 15:41:01.183 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/Showtime3.conf INFO 2012-06-09 15:41:01.186 [main] Loading configuration file: SonyBluray.conf DEBUG 2012-06-09 15:41:01.187 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/SonyBluray.conf INFO 2012-06-09 15:41:01.189 [main] Loading configuration file: Streamium.conf DEBUG 2012-06-09 15:41:01.190 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/Streamium.conf INFO 2012-06-09 15:41:01.191 [main] Loading configuration file: WDTVLive.conf DEBUG 2012-06-09 15:41:01.192 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/WDTVLive.conf INFO 2012-06-09 15:41:01.193 [main] Loading configuration file: WMP.conf DEBUG 2012-06-09 15:41:01.193 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/WMP.conf INFO 2012-06-09 15:41:01.195 [main] Loading configuration file: XBMC.conf DEBUG 2012-06-09 15:41:01.196 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/XBMC.conf INFO 2012-06-09 15:41:01.197 [main] Loading configuration file: XBOX360.conf DEBUG 2012-06-09 15:41:01.197 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/XBOX360.conf INFO 2012-06-09 15:41:01.203 [main] Loading configuration file: YamahaRXV671.conf DEBUG 2012-06-09 15:41:01.204 [main] Base path set to file:///Applications/Universal%20Media%20Server.app/Contents/Resources/Java/renderers/YamahaRXV671.conf INFO 2012-06-09 15:41:01.204 [main] Checking MPlayer font cache. It can take a minute or so. DEBUG 2012-06-09 15:41:01.205 [main] launching: osx/mplayer INFO 2012-06-09 15:41:01.981 [main] Done! INFO 2012-06-09 15:41:02.044 [main] Searching for plugins in /Applications/Universal Media Server.app/Contents/Resources/Java/plugins INFO 2012-06-09 15:41:02.045 [main] No plugins found INFO 2012-06-09 15:41:02.060 [main] Registering transcoding engine: FFmpeg Audio INFO 2012-06-09 15:41:02.069 [main] Registering transcoding engine: MEncoder INFO 2012-06-09 15:41:02.069 [main] Registering transcoding engine: MPlayer Audio INFO 2012-06-09 15:41:02.070 [main] Registering transcoding engine: MEncoder Web INFO 2012-06-09 15:41:02.070 [main] Registering transcoding engine: MPlayer Video Dump INFO 2012-06-09 15:41:02.070 [main] Registering transcoding engine: MPlayer Web INFO 2012-06-09 15:41:02.072 [main] Registering transcoding engine: tsMuxeR INFO 2012-06-09 15:41:02.073 [main] Registering transcoding engine: Audio High Fidelity INFO 2012-06-09 15:41:02.074 [main] Registering transcoding engine: VLC Audio Streaming INFO 2012-06-09 15:41:02.074 [main] Registering transcoding engine: VLC Video Streaming INFO 2012-06-09 15:41:02.074 [main] Registering transcoding engine: dcraw Thumbnailer INFO 2012-06-09 15:41:02.188 [main] Using address /192.168.1.7 found on network interface: name:en1 (en1) INFO 2012-06-09 15:41:02.188 [main] Created socket: /192.168.1.7:5001 INFO 2012-06-09 15:41:02.492 [main] Checking shared folder: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN INFO 2012-06-09 15:41:02.493 [main] Checking shared folder: /Users/Karshbook/Desktop/50 BDRip DEBUG 2012-06-09 15:41:02.611 [main] Sending ALIVE... INFO 2012-06-09 15:41:02.643 [main] Using the following UUID configured in UMS.conf: 2c7f986e-5642-4bb7-b80c-b074455a25d3 INFO 2012-06-09 15:41:05.779 [New I/O server worker #1-1] No IP filter specified, access granted to /192.168.1.12 INFO 2012-06-09 15:41:05.826 [New I/O server worker #1-1] Another renderer like Samsung AllShare was found! INFO 2012-06-09 15:41:05.844 [pool-4-thread-1] Checking IP: 192.168.1.12 for Samsung AllShare INFO 2012-06-09 15:41:05.883 [pool-4-thread-1] Renderer Samsung AllShare found on this address: new-host-2.home (192.168.1.12) DEBUG 2012-06-09 15:41:05.917 [pool-4-thread-1] Starting ping -c 3 -s 64000 192.168.1.12 DEBUG 2012-06-09 15:41:06.078 [Thread-9] ping: sendto: Message too long DEBUG 2012-06-09 15:41:06.101 [pool-4-thread-1] Unix process ID (ping): 43270 DEBUG 2012-06-09 15:41:07.070 [Thread-9] ping: sendto: Message too long DEBUG 2012-06-09 15:41:07.918 [SpeedStats Failsafe] Stopping Unix process 43270: ping-0 INFO 2012-06-09 15:41:08.129 [New I/O server worker #1-3] No IP filter specified, access granted to /192.168.1.15 INFO 2012-06-09 15:41:08.177 [New I/O server worker #1-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Mozilla/4.0 (compatible) INFO 2012-06-09 15:41:08.241 [main] The server should now appear on your renderer INFO 2012-06-09 15:41:10.591 [pool-4-thread-1] Checking IP: 192.168.1.15 for Streamium INFO 2012-06-09 15:41:10.637 [pool-4-thread-1] Renderer Streamium found on this address: 00e036fa2536.home (192.168.1.15) DEBUG 2012-06-09 15:41:10.640 [pool-4-thread-1] Starting ping -c 3 -s 64000 192.168.1.15 DEBUG 2012-06-09 15:41:10.682 [Thread-12] ping: sendto: Message too long DEBUG 2012-06-09 15:41:10.683 [pool-4-thread-1] Unix process ID (ping): 43272 DEBUG 2012-06-09 15:41:11.675 [Thread-12] ping: sendto: Message too long DEBUG 2012-06-09 15:41:12.655 [SpeedStats Failsafe] Stopping Unix process 43272: ping-1 DEBUG 2012-06-09 15:41:18.240 [UPNP-AliveMessageSender] Sending ALIVE... DEBUG 2012-06-09 15:41:42.269 [UPNP-AliveMessageSender] Sending ALIVE... DEBUG 2012-06-09 15:44:46.310 [UPNP-AliveMessageSender] Sending ALIVE... DEBUG 2012-06-09 15:45:21.502 [background-task-0] singleton task restart started DEBUG 2012-06-09 15:45:21.503 [background-task-0-restart(0)] task started INFO 2012-06-09 15:45:21.503 [background-task-0-restart(0)] Sending BYEBYE... INFO 2012-06-09 15:45:25.761 [background-task-0-restart(0)] Stopping server on host 192.168.1.7 and port 5001... INFO 2012-06-09 15:45:26.784 [background-task-0-restart(0)] Using address /192.168.1.7 found on network interface: name:en1 (en1) INFO 2012-06-09 15:45:26.785 [background-task-0-restart(0)] Created socket: /192.168.1.7:5001 DEBUG 2012-06-09 15:45:26.786 [background-task-0-restart(0)] Sending ALIVE... DEBUG 2012-06-09 15:45:30.108 [background-task-0-restart(0)] task ended DEBUG 2012-06-09 15:45:39.401 [New I/O server worker #2-3] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" DEBUG 2012-06-09 15:45:39.449 [New I/O server worker #2-4] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" DEBUG 2012-06-09 15:45:40.118 [New I/O server worker #2-1] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" DEBUG 2012-06-09 15:45:40.142 [New I/O server worker #2-2] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" INFO 2012-06-09 15:45:40.162 [New I/O server worker #2-3] Checking shared folder: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN INFO 2012-06-09 15:45:40.179 [New I/O server worker #2-3] Checking shared folder: /Users/Karshbook/Desktop/50 BDRip DEBUG 2012-06-09 15:45:42.371 [New I/O server worker #2-1] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" DEBUG 2012-06-09 15:45:42.454 [pool-9-thread-1] Starting "/Applications/Universal Media Server.app/Contents/Resources/Java/osx/ffmpeg" -ss 1 -i "/Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv" -an -an -s 320x180 -vframes 1 -f image2 pipe: DEBUG 2012-06-09 15:45:42.554 [pool-9-thread-1] Attaching thread: ffmpeg-2 DEBUG 2012-06-09 15:45:42.555 [pool-9-thread-1] Unix process ID (/Applications/Universal Media Server.app/Contents/Resources/Java/osx/ffmpeg): 43317 DEBUG 2012-06-09 15:45:44.625 [New I/O server worker #2-4] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" DEBUG 2012-06-09 15:45:44.648 [pool-11-thread-1] Duplicate 21 Jump Street BDRip.mkv for direct streaming to renderer: Samsung AllShare DEBUG 2012-06-09 15:45:45.226 [Buffered IO End Checker] Stopping Unix process 43317: ffmpeg-2 DEBUG 2012-06-09 15:45:47.019 [New I/O server worker #2-3] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" INFO 2012-06-09 15:45:51.179 [New I/O server worker #2-2] Starting transcode/remux of 21 Jump Street BDRip.mkv DEBUG 2012-06-09 15:45:51.263 [mencoder-3] Starting "/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder" -ss 0 -quiet "/Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv" -quiet -quiet -oac lavc -of mpeg -quiet -quiet -mpegopts format=mpeg2:muxrate=500000:vbuf_size=1194:abuf_size=64 -ovc lavc -channels 6 -lavdopts debug=0:threads=2 -lavcopts autoaspect=1:vcodec=mpeg2video:acodec=ac3:abitrate=640:threads=2:keyint=5:vqscale=1:vqmin=2:vrc_maxrate=11000:vrc_buf_size=1835 -quiet -quiet -subdelay 20000 -quiet -quiet -ofps 24000/1001 -quiet -quiet -lavdopts fast -mc 0 -noskip -af lavcresample=48000 -srate 48000 -o - -really-quiet -msglevel statusline=2 DEBUG 2012-06-09 15:45:51.448 [mencoder-3] Attaching thread: mencoder-3 DEBUG 2012-06-09 15:45:51.450 [mencoder-3] Unix process ID (/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder): 43326 INFO 2012-06-09 15:45:57.387 [StartPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv DEBUG 2012-06-09 15:45:58.578 [New I/O server worker #2-1] Setting InputStream new position to: 99,999,750,000 DEBUG 2012-06-09 15:46:03.673 [New I/O server worker #2-2] Setting InputStream new position to: 99,999,500,000 DEBUG 2012-06-09 15:46:06.172 [New I/O server worker #2-1] Caught exception java.lang.ArrayIndexOutOfBoundsException: 175314800 at net.pms.io.BufferedOutputFileImpl.read(BufferedOutputFileImpl.java:727) ~[ums-1.1.0.jar:na] at net.pms.io.WaitBufferedInputStream.read(WaitBufferedInputStream.java:43) ~[ums-1.1.0.jar:na] at java.io.FilterInputStream.read(FilterInputStream.java:66) ~[na:1.6.0_29] at java.io.PushbackInputStream.read(PushbackInputStream.java:122) ~[na:1.6.0_29] at org.jboss.netty.handler.stream.ChunkedStream.hasNextChunk(ChunkedStream.java:78) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.handler.stream.ChunkedStream.nextChunk(ChunkedStream.java:96) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.handler.stream.ChunkedWriteHandler.flush(ChunkedWriteHandler.java:208) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleDownstream(ChunkedWriteHandler.java:124) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.Channels.write(Channels.java:611) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.Channels.write(Channels.java:578) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.AbstractChannel.write(AbstractChannel.java:259) ~[netty-3.2.4.Final.jar:na] at net.pms.network.RequestV2.answer(RequestV2.java:805) ~[ums-1.1.0.jar:na] at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:313) ~[ums-1.1.0.jar:na] at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:271) ~[ums-1.1.0.jar:na] at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:148) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:116) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:302) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.handler.codec.replay.ReplayingDecoder.unfoldAndfireMessageReceived(ReplayingDecoder.java:522) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:506) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:443) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:274) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:261) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:349) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.socket.nio.NioWorker.processSelectedKeys(NioWorker.java:280) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:200) ~[netty-3.2.4.Final.jar:na] at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) [na:1.6.0_29] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) [na:1.6.0_29] at java.lang.Thread.run(Thread.java:680) [na:1.6.0_29] DEBUG 2012-06-09 15:46:08.676 [Buffered IO End Checker] Stopping Unix process 43326: mencoder-3 DEBUG 2012-06-09 15:46:08.681 [Thread-23] Error consuming stream of spawned process: Stream closed INFO 2012-06-09 15:46:08.794 [New I/O server worker #2-3] Starting transcode/remux of 21 Jump Street BDRip.mkv DEBUG 2012-06-09 15:46:08.814 [mencoder-4] Starting "/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder" -ss 0 -quiet "/Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv" -quiet -quiet -oac lavc -of mpeg -quiet -quiet -mpegopts format=mpeg2:muxrate=500000:vbuf_size=1194:abuf_size=64 -ovc lavc -channels 6 -lavdopts debug=0:threads=2 -lavcopts autoaspect=1:vcodec=mpeg2video:acodec=ac3:abitrate=640:threads=2:keyint=5:vqscale=1:vqmin=2:vrc_maxrate=11000:vrc_buf_size=1835 -quiet -quiet -subdelay 20000 -quiet -quiet -ofps 24000/1001 -quiet -quiet -lavdopts fast -mc 0 -noskip -af lavcresample=48000 -srate 48000 -o - -really-quiet -msglevel statusline=2 DEBUG 2012-06-09 15:46:09.123 [mencoder-4] Attaching thread: mencoder-4 DEBUG 2012-06-09 15:46:09.126 [mencoder-4] Unix process ID (/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder): 43329 INFO 2012-06-09 15:46:13.221 [StopPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv DEBUG 2012-06-09 15:46:15.054 [New I/O server worker #2-3] Setting InputStream new position to: 99,999,000,000 INFO 2012-06-09 15:46:15.059 [StartPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv DEBUG 2012-06-09 15:46:20.163 [New I/O server worker #2-4] Setting InputStream new position to: 99,998,000,000 DEBUG 2012-06-09 15:46:22.565 [New I/O server worker #2-3] Caught exception java.lang.ArrayIndexOutOfBoundsException: 174564800 at net.pms.io.BufferedOutputFileImpl.read(BufferedOutputFileImpl.java:727) ~[ums-1.1.0.jar:na] at net.pms.io.WaitBufferedInputStream.read(WaitBufferedInputStream.java:43) ~[ums-1.1.0.jar:na] at java.io.FilterInputStream.read(FilterInputStream.java:66) ~[na:1.6.0_29] at java.io.PushbackInputStream.read(PushbackInputStream.java:122) ~[na:1.6.0_29] at org.jboss.netty.handler.stream.ChunkedStream.hasNextChunk(ChunkedStream.java:78) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.handler.stream.ChunkedStream.nextChunk(ChunkedStream.java:96) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.handler.stream.ChunkedWriteHandler.flush(ChunkedWriteHandler.java:208) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleDownstream(ChunkedWriteHandler.java:124) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.Channels.write(Channels.java:611) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.Channels.write(Channels.java:578) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.AbstractChannel.write(AbstractChannel.java:259) ~[netty-3.2.4.Final.jar:na] at net.pms.network.RequestV2.answer(RequestV2.java:805) ~[ums-1.1.0.jar:na] at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:313) ~[ums-1.1.0.jar:na] at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:271) ~[ums-1.1.0.jar:na] at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:148) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:116) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:302) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.handler.codec.replay.ReplayingDecoder.unfoldAndfireMessageReceived(ReplayingDecoder.java:522) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:506) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:443) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:274) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:261) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:349) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.socket.nio.NioWorker.processSelectedKeys(NioWorker.java:280) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:200) ~[netty-3.2.4.Final.jar:na] at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) [na:1.6.0_29] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) [na:1.6.0_29] at java.lang.Thread.run(Thread.java:680) [na:1.6.0_29] DEBUG 2012-06-09 15:46:25.069 [Buffered IO End Checker] Stopping Unix process 43329: mencoder-4 DEBUG 2012-06-09 15:46:25.088 [Thread-27] Error consuming stream of spawned process: Stream closed INFO 2012-06-09 15:46:25.175 [New I/O server worker #2-1] Starting transcode/remux of 21 Jump Street BDRip.mkv DEBUG 2012-06-09 15:46:25.195 [mencoder-5] Starting "/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder" -ss 0 -quiet "/Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv" -quiet -quiet -oac lavc -of mpeg -quiet -quiet -mpegopts format=mpeg2:muxrate=500000:vbuf_size=1194:abuf_size=64 -ovc lavc -channels 6 -lavdopts debug=0:threads=2 -lavcopts autoaspect=1:vcodec=mpeg2video:acodec=ac3:abitrate=640:threads=2:keyint=5:vqscale=1:vqmin=2:vrc_maxrate=11000:vrc_buf_size=1835 -quiet -quiet -subdelay 20000 -quiet -quiet -ofps 24000/1001 -quiet -quiet -lavdopts fast -mc 0 -noskip -af lavcresample=48000 -srate 48000 -o - -really-quiet -msglevel statusline=2 DEBUG 2012-06-09 15:46:25.482 [mencoder-5] Attaching thread: mencoder-5 DEBUG 2012-06-09 15:46:25.483 [mencoder-5] Unix process ID (/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder): 43332 INFO 2012-06-09 15:46:29.173 [StopPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv DEBUG 2012-06-09 15:46:31.390 [New I/O server worker #2-1] Setting InputStream new position to: 99,996,000,000 INFO 2012-06-09 15:46:31.459 [StartPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv DEBUG 2012-06-09 15:46:36.546 [New I/O server worker #2-2] Setting InputStream new position to: 1 DEBUG 2012-06-09 15:46:38.978 [New I/O server worker #2-1] Caught exception java.lang.ArrayIndexOutOfBoundsException: 171564800 at net.pms.io.BufferedOutputFileImpl.read(BufferedOutputFileImpl.java:727) ~[ums-1.1.0.jar:na] at net.pms.io.WaitBufferedInputStream.read(WaitBufferedInputStream.java:43) ~[ums-1.1.0.jar:na] at java.io.FilterInputStream.read(FilterInputStream.java:66) ~[na:1.6.0_29] at java.io.PushbackInputStream.read(PushbackInputStream.java:122) ~[na:1.6.0_29] at org.jboss.netty.handler.stream.ChunkedStream.hasNextChunk(ChunkedStream.java:78) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.handler.stream.ChunkedStream.nextChunk(ChunkedStream.java:96) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.handler.stream.ChunkedWriteHandler.flush(ChunkedWriteHandler.java:208) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleDownstream(ChunkedWriteHandler.java:124) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.Channels.write(Channels.java:611) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.Channels.write(Channels.java:578) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.AbstractChannel.write(AbstractChannel.java:259) ~[netty-3.2.4.Final.jar:na] at net.pms.network.RequestV2.answer(RequestV2.java:805) ~[ums-1.1.0.jar:na] at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:313) ~[ums-1.1.0.jar:na] at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:271) ~[ums-1.1.0.jar:na] at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:148) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:116) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:302) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.handler.codec.replay.ReplayingDecoder.unfoldAndfireMessageReceived(ReplayingDecoder.java:522) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:506) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:443) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:274) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:261) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:349) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.socket.nio.NioWorker.processSelectedKeys(NioWorker.java:280) ~[netty-3.2.4.Final.jar:na] at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:200) ~[netty-3.2.4.Final.jar:na] at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) [na:1.6.0_29] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) [na:1.6.0_29] at java.lang.Thread.run(Thread.java:680) [na:1.6.0_29] DEBUG 2012-06-09 15:46:39.129 [Buffered IO End Checker] Stopping Unix process 43332: mencoder-5 DEBUG 2012-06-09 15:46:39.137 [Thread-31] Error consuming stream of spawned process: Stream closed INFO 2012-06-09 15:46:43.000 [StopPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv DEBUG 2012-06-09 15:47:49.621 [UPNP-AliveMessageSender] Sending ALIVE... DEBUG 2012-06-09 15:50:54.035 [UPNP-AliveMessageSender] Sending ALIVE... DEBUG 2012-06-09 15:51:42.645 [New I/O server worker #2-4] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" DEBUG 2012-06-09 15:51:42.697 [New I/O server worker #2-1] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" DEBUG 2012-06-09 15:51:43.350 [New I/O server worker #2-2] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" DEBUG 2012-06-09 15:51:43.372 [New I/O server worker #2-3] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" DEBUG 2012-06-09 15:51:44.991 [New I/O server worker #2-2] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" DEBUG 2012-06-09 15:51:49.083 [New I/O server worker #2-1] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" DEBUG 2012-06-09 15:51:50.829 [New I/O server worker #2-4] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" INFO 2012-06-09 15:51:57.275 [New I/O server worker #2-3] Starting transcode/remux of 21 Jump Street BDRip.mkv DEBUG 2012-06-09 15:51:57.331 [mkfifo-9] Starting mkfifo -m 777 /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271517330tsmuxerout.ts DEBUG 2012-06-09 15:51:57.383 [mkfifo-10] Starting mkfifo -m 777 /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271517311ffmpegvideo DEBUG 2012-06-09 15:51:57.386 [mkfifo-11] Starting mkfifo -m 777 /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271517311videoout DEBUG 2012-06-09 15:51:57.423 [mkfifo-11] Unix process ID (mkfifo): 43401 DEBUG 2012-06-09 15:51:57.424 [mkfifo-9] Unix process ID (mkfifo): 43399 DEBUG 2012-06-09 15:51:57.424 [mkfifo-10] Unix process ID (mkfifo): 43400 DEBUG 2012-06-09 15:51:57.586 [mencoder-6] Starting "/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder" -ss 0 "/Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv" -quiet -quiet -really-quiet -msglevel statusline=2 -ovc copy -nosound -mc 0 -noskip -of rawvideo -o /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271517311ffmpegvideo DEBUG 2012-06-09 15:51:57.623 [mencoder-6] Attaching thread: mencoder-6 DEBUG 2012-06-09 15:51:57.623 [mencoder-6] Unix process ID (/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder): 43402 DEBUG 2012-06-09 15:51:57.636 [mkfifo-12] Starting mkfifo -m 777 /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271517311ffmpegaudio01 DEBUG 2012-06-09 15:51:57.647 [mkfifo-13] Starting mkfifo -m 777 /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271517311audioout DEBUG 2012-06-09 15:51:57.680 [mkfifo-13] Unix process ID (mkfifo): 43405 DEBUG 2012-06-09 15:51:57.683 [mkfifo-12] Unix process ID (mkfifo): 43404 DEBUG 2012-06-09 15:51:57.849 [mencoder-7] Starting "/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder" -ss 0 "/Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv" -quiet -quiet -really-quiet -msglevel statusline=2 -channels 6 -ovc copy -of rawaudio -mc 0 -noskip -oac lavc -quiet -quiet -lavcopts acodec=ac3:abitrate=640 -af lavcresample=48000 -srate 48000 -quiet -quiet -o /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271517311ffmpegaudio01 DEBUG 2012-06-09 15:51:57.899 [mencoder-7] Attaching thread: mencoder-7 DEBUG 2012-06-09 15:51:57.900 [mencoder-7] Unix process ID (/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder): 43406 DEBUG 2012-06-09 15:51:57.949 [tsMuxeR-8] Starting "/Applications/Universal Media Server.app/Contents/Resources/Java/osx/tsMuxeR" /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/pms-tsmuxer.meta /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271517330tsmuxerout.ts DEBUG 2012-06-09 15:51:58.008 [tsMuxeR-8] Reading pipe: /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271517330tsmuxerout.ts DEBUG 2012-06-09 15:51:58.200 [tsMuxeR-8] Attaching thread: tsMuxeR-8 DEBUG 2012-06-09 15:51:58.201 [Thread-62] SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net DEBUG 2012-06-09 15:51:58.201 [Thread-62] 100.0% complete DEBUG 2012-06-09 15:51:58.202 [tsMuxeR-8] Unix process ID (/Applications/Universal Media Server.app/Contents/Resources/Java/osx/tsMuxeR): 43407 DEBUG 2012-06-09 15:51:58.347 [Thread-62] M100.0% complete DEBUG 2012-06-09 15:51:58.601 [Thread-62] M100.0% complete DEBUG 2012-06-09 15:51:58.886 [Thread-62] M100.0% complete DEBUG 2012-06-09 15:51:59.136 [Thread-62] M100.0% complete DEBUG 2012-06-09 15:51:59.386 [Thread-62] M100.0% complete DEBUG 2012-06-09 15:51:59.640 [Thread-62] M100.0% complete DEBUG 2012-06-09 15:51:59.891 [Thread-62] M100.0% complete DEBUG 2012-06-09 15:52:00.141 [Thread-62] M100.0% complete DEBUG 2012-06-09 15:52:00.391 [Thread-62] M100.0% complete DEBUG 2012-06-09 15:52:00.485 [Thread-59] Pes packet len too large ( >100Mb). Bad stream or invalid codec speciffed. INFO 2012-06-09 15:52:00.513 [tsMuxeR-8] Process /Applications/Universal Media Server.app/Contents/Resources/Java/osx/tsMuxeR has a return code of 254! Maybe an error occurred... check the log file DEBUG 2012-06-09 15:52:00.533 [tsMuxeR-8] Stopping Unix process 43399: mkfifo-9 DEBUG 2012-06-09 15:52:00.560 [tsMuxeR-8] Stopping Unix process 43402: mencoder-6 DEBUG 2012-06-09 15:52:00.563 [tsMuxeR-8] Stopping Unix process 43406: mencoder-7 INFO 2012-06-09 15:52:02.955 [StartPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv DEBUG 2012-06-09 15:52:05.477 [Buffered IO End Checker] Stopping Unix process 43407: tsMuxeR-8 INFO 2012-06-09 15:52:06.981 [StopPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv DEBUG 2012-06-09 15:52:09.871 [New I/O server worker #2-1] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" DEBUG 2012-06-09 15:52:09.980 [New I/O server worker #2-2] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" DEBUG 2012-06-09 15:52:10.020 [New I/O server worker #2-3] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" DEBUG 2012-06-09 15:52:10.047 [New I/O server worker #2-4] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" WARN 2012-06-09 15:52:10.564 [Process Destroyer] Sending kill -14 to the Unix process: 43402 WARN 2012-06-09 15:52:10.565 [Process Destroyer] Sending kill -14 to the Unix process: 43406 DEBUG 2012-06-09 15:52:10.688 [Process Destroyer] Successfully sent kill -14 to the Unix process: 43406 DEBUG 2012-06-09 15:52:10.701 [Process Destroyer] Successfully sent kill -14 to the Unix process: 43402 INFO 2012-06-09 15:52:14.890 [New I/O server worker #2-3] Starting transcode/remux of 21 Jump Street BDRip.mkv DEBUG 2012-06-09 15:52:14.898 [mkfifo-25] Starting mkfifo -m 777 /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271534897tsmuxerout.ts DEBUG 2012-06-09 15:52:14.934 [mkfifo-25] Unix process ID (mkfifo): 43412 DEBUG 2012-06-09 15:52:14.949 [mkfifo-26] Starting mkfifo -m 777 /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271534897ffmpegvideo DEBUG 2012-06-09 15:52:14.957 [mkfifo-27] Starting mkfifo -m 777 /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271534897videoout DEBUG 2012-06-09 15:52:15.009 [mkfifo-27] Unix process ID (mkfifo): 43414 DEBUG 2012-06-09 15:52:15.010 [mkfifo-26] Unix process ID (mkfifo): 43413 DEBUG 2012-06-09 15:52:15.158 [mencoder-22] Starting "/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder" -ss 0 "/Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv" -quiet -quiet -really-quiet -msglevel statusline=2 -ovc copy -nosound -mc 0 -noskip -of rawvideo -o /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271534897ffmpegvideo DEBUG 2012-06-09 15:52:15.207 [mencoder-22] Attaching thread: mencoder-22 DEBUG 2012-06-09 15:52:15.214 [mkfifo-28] Starting mkfifo -m 777 /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271534897ffmpegaudio01 DEBUG 2012-06-09 15:52:15.225 [mkfifo-29] Starting mkfifo -m 777 /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271534897audioout DEBUG 2012-06-09 15:52:15.262 [mencoder-22] Unix process ID (/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder): 43415 DEBUG 2012-06-09 15:52:15.266 [mkfifo-29] Unix process ID (mkfifo): 43417 DEBUG 2012-06-09 15:52:15.270 [mkfifo-28] Unix process ID (mkfifo): 43416 DEBUG 2012-06-09 15:52:15.425 [mencoder-23] Starting "/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder" -ss 0 "/Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv" -quiet -quiet -really-quiet -msglevel statusline=2 -channels 6 -ovc copy -of rawaudio -mc 0 -noskip -oac lavc -quiet -quiet -lavcopts acodec=ac3:abitrate=640 -af lavcresample=48000 -srate 48000 -quiet -quiet -o /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271534897ffmpegaudio01 DEBUG 2012-06-09 15:52:15.460 [mencoder-23] Attaching thread: mencoder-23 DEBUG 2012-06-09 15:52:15.461 [mencoder-23] Unix process ID (/Applications/Universal Media Server.app/Contents/Resources/Java/osx/mencoder): 43418 DEBUG 2012-06-09 15:52:15.525 [tsMuxeR-24] Starting "/Applications/Universal Media Server.app/Contents/Resources/Java/osx/tsMuxeR" /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/pms-tsmuxer.meta /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271534897tsmuxerout.ts DEBUG 2012-06-09 15:52:15.561 [tsMuxeR-24] Reading pipe: /var/folders/k1/k19aURpHFf4CSBS9OZoS5k+++TI/-Tmp-/ps3mediaserver/1339271534897tsmuxerout.ts DEBUG 2012-06-09 15:52:15.856 [tsMuxeR-24] Attaching thread: tsMuxeR-24 DEBUG 2012-06-09 15:52:15.859 [Thread-104] SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net DEBUG 2012-06-09 15:52:15.859 [Thread-104] 100.0% complete DEBUG 2012-06-09 15:52:15.859 [Thread-104] M100.0% complete DEBUG 2012-06-09 15:52:15.873 [tsMuxeR-24] Unix process ID (/Applications/Universal Media Server.app/Contents/Resources/Java/osx/tsMuxeR): 43419 DEBUG 2012-06-09 15:52:16.074 [Thread-104] M100.0% complete DEBUG 2012-06-09 15:52:16.324 [Thread-104] M100.0% complete DEBUG 2012-06-09 15:52:16.574 [Thread-104] M100.0% complete DEBUG 2012-06-09 15:52:16.824 [Thread-104] M100.0% complete DEBUG 2012-06-09 15:52:17.075 [Thread-104] M100.0% complete DEBUG 2012-06-09 15:52:17.325 [Thread-104] M100.0% complete DEBUG 2012-06-09 15:52:17.526 [Thread-101] Pes packet len too large ( >100Mb). Bad stream or invalid codec speciffed. INFO 2012-06-09 15:52:17.527 [tsMuxeR-24] Process /Applications/Universal Media Server.app/Contents/Resources/Java/osx/tsMuxeR has a return code of 254! Maybe an error occurred... check the log file DEBUG 2012-06-09 15:52:17.528 [tsMuxeR-24] Stopping Unix process 43412: mkfifo-25 DEBUG 2012-06-09 15:52:17.529 [tsMuxeR-24] Stopping Unix process 43415: mencoder-22 DEBUG 2012-06-09 15:52:17.529 [tsMuxeR-24] Stopping Unix process 43418: mencoder-23 INFO 2012-06-09 15:52:20.555 [StartPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv DEBUG 2012-06-09 15:52:23.058 [Buffered IO End Checker] Stopping Unix process 43419: tsMuxeR-24 DEBUG 2012-06-09 15:52:24.106 [New I/O server worker #2-1] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" DEBUG 2012-06-09 15:52:24.206 [New I/O server worker #2-2] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" DEBUG 2012-06-09 15:52:24.236 [New I/O server worker #2-3] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" DEBUG 2012-06-09 15:52:24.266 [New I/O server worker #2-4] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList" INFO 2012-06-09 15:52:24.578 [StopPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv INFO 2012-06-09 15:52:26.990 [StartPlaying Event] renderer: 192.168.1.12, file: /Users/Karshbook/Desktop/21 Jump Street 2012 BRRip XviD-KAZAN/21 Jump Street BDRip.mkv WARN 2012-06-09 15:52:27.530 [Process Destroyer] Sending kill -14 to the Unix process: 43415 WARN 2012-06-09 15:52:27.539 [Process Destroyer] Sending kill -14 to the Unix process: 43418 DEBUG 2012-06-09 15:52:27.596 [Process Destroyer] Successfully sent kill -14 to the Unix process: 43418 DEBUG 2012-06-09 15:52:27.603 [Process Destroyer] Successfully sent kill -14 to the Unix process: 43415 INFO 2012-06-09 15:53:20.661 [PMS Listeners Stopper] Sending BYEBYE... DEBUG 2012-06-09 15:53:20.662 [UPNP-AliveMessageSender] Error while sending periodic alive message: sleep interrupted DEBUG 2012-06-09 15:53:24.461 [PMS Listeners Stopper] Forcing shutdown of all active processes INFO 2012-06-09 15:53:24.461 [PMS Listeners Stopper] Stopping server on host 192.168.1.7 and port 5001...
Re: Can't get stream to play on Samsung BD-E6500
Hmm, I could try this on Windows, but is there any way you can package that into a .dmg?
If you can test it on Windows that would save me a lot of time
Aww yiss. That worked like a charm!! Even with the fact that I'm running a Windows XP virtual machine on my Macbook... It only uses about 200MB of my memory!! Thank you so very much! Just in case, would I be able to get the Mac version of this? Please, take your time! I can definitely wait for your quality work!!
Great! The fix will be in the 1.1.1 release which will be out either today or tomorrow
