Unable to load Java Runtime Environment at startup on Mac OSX 10.11.3
TheRon79
Post by TheRon79 »
Hey all,
When I try to launch UMS 6.2.1 I get the above error.
When I run java -version in terminal, I get:
MBPderenegagnon:bin renegagnon$ java -version
java version "1.6.0_65"
Java(TM) SE Runtime Environment (build 1.6.0_65-b14-468-11M4833)
Java HotSpot(TM) 64-Bit Server VM (build 20.65-b04-468, mixed mode)
What can I do to fix this.
Jatinder Paul Singh
Re: Unable to load Java Runtime Environment at startup on Mac OSX 10.11.3
Post by Jatinder Paul Singh »
HI TheRon
I encountered the same problem. I was able to resolve this by downloading the latest Java update, from the Java.com/. Try if it still is an issue.
JP Singh
