2012-07-20 Build Version 1.4.1
Download and discuss official beta builds here
Locked
counsil
Post by counsil » Sat Jul 21, 2012 9:07 am
There have been several commits since SubJunk released Version 1.4.0. I was encountering some issues that have since been corrected. Feel free to download the very latest version from here:
http://www.4shared.com/file/zzgQ0JhL/UMS.html
Also, I not only recommend that you uninstall UMS (and delete the 'Program Files/UMS' directory) before installing this version, but also make sure to delete your configuration files as well. They are located in 'ProgramData/UMS'. I recommend this because the default configuration files have been greatly changed in this particular version.
megapixel
Re: 2012-07-20 Build Version 1.4.1
Post by megapixel » Mon Jul 23, 2012 6:37 am
Habe ihre version getestet(2012-07-20 Build Version 1.4.1).
Sound war nicht syncron in NavX/Movie2K.
Lösung
Installieren sie MplayerMencoder sb25,dies ist einzig richtig funktionierende version.Mencoder sollte in V-Engines Prio haben.
Sonst stürzt Showtime bei stream2k ab.
Video/Webnstreaming PmsEncoder lässt sich nicht ändern.
Im Trancecode order werden keine alternativen angezeigt.
Aber Danke! So gut lief noch keine freilassung bei mir.
Have her tested version (Build 2012-07-20 version 1.4.1).
Sound was not in syncron NavX/Movie2K.
solution
Install MplayerMencoder SB25, this is only correct functioning version.Mencoder should have priority in V-engines.
Showtime will crash when starting Stream2k.
Video / Webnstreaming PmsEncoder can not be changed.
In order Trance code displayed no alternative.
Thank you so well but still no release was with me.
Reference
In WindowsXP Find she UMS.config Unter C :/ Dokumente und einstellungen Alluser.
Locked
