4.1.2
4.1.2
I was trying out 4.1.2 and noticed that the {External Subtitles} tag at the end of the file is missing. Is there some conf setting that would allow me to see it again? It's very useful for me to know which files have external subs (as those are the files I can watch).
Thanks.
Thanks.
Re: 4.1.2
I also built the latest one today (v4.1.2 final) and having issues with mp4 files and files with aac audio tracks. Instead of aac/mp4a audio is detected as unknown 0x6134706D.
DEBUG 2014-09-20 11:45:40.231 [New I/O worker #1] HTTP User-Agent: Lavf53.32.100
DEBUG 2014-09-20 11:45:40.247 [New I/O worker #1] Starting transcode/remux of The.Great.British.Bake.Off.S05E07.Pastry.PDTV.mp4 with media info: container: mov, bitrate: 822272, size: 348937480, video codec: h264 (Main) (avc1 / 0x31637661), duration: 00:57:55.84, width: 640, height: 360, frame rate: 25.00, thumb size : 13892, muxing mode: null, mime type: video/mp4
Audio track id: 0, lang: und, flavor: null, audio codec: aac (mp4a / 0x6134706D), sample frequency:48000, number of channels: 2, bits per sample: 16
DEBUG 2014-09-20 11:45:40.262 [New I/O worker #1] Creating pipe \\.\pipe\1411224340262ffmpegvideo
DEBUG 2014-09-20 11:45:40.278 [New I/O worker #1] Creating pipe \\.\pipe\1411224340262videoout
DEBUG 2014-09-20 11:45:40.278 [Thread-33] Waiting for pipe connection \\.\pipe\1411224340262videoout
DEBUG 2014-09-20 11:45:40.278 [Thread-32] Waiting for pipe connection \\.\pipe\1411224340262ffmpegvideo
DEBUG 2014-09-20 11:45:40.278 [New I/O worker #1] Starting D:\Program Files\Universal Media Server test\win32\ffmpeg.exe -i E:\zInetTransfer\!(0TV) Various\The.Great.British.Bake.Off.S05E07.Pastry.PDTV.mp4 -vframes 1 -c:v copy -f h264 -bsf h264_mp4toannexb -an -y pipe:
DEBUG 2014-09-20 11:45:40.278 [New I/O worker #1] Attaching thread: ffmpeg.exe-7
DEBUG 2014-09-20 11:45:40.356 [ffmpeg.exe-7-2] ffmpeg version N-65971-g4c92047 Copyright (c) 2000-2014 the FFmpeg developers
DEBUG 2014-09-20 11:45:40.356 [ffmpeg.exe-7-2] built on Aug 28 2014 23:19:00 with gcc 4.8.3 (GCC)
DEBUG 2014-09-20 11:45:40.356 [ffmpeg.exe-7-2] configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-decklink --enable-zlib
DEBUG 2014-09-20 11:45:40.356 [ffmpeg.exe-7-2] libavutil 54. 7.100 / 54. 7.100
DEBUG 2014-09-20 11:45:40.356 [ffmpeg.exe-7-2] libavcodec 56. 1.100 / 56. 1.100
DEBUG 2014-09-20 11:45:40.356 [ffmpeg.exe-7-2] libavformat 56. 3.100 / 56. 3.100
DEBUG 2014-09-20 11:45:40.356 [ffmpeg.exe-7-2] libavdevice 56. 0.100 / 56. 0.100
DEBUG 2014-09-20 11:45:40.356 [ffmpeg.exe-7-2] libavfilter 5. 0.103 / 5. 0.103
DEBUG 2014-09-20 11:45:40.356 [ffmpeg.exe-7-2] libswscale 3. 0.100 / 3. 0.100
DEBUG 2014-09-20 11:45:40.356 [ffmpeg.exe-7-2] libswresample 1. 1.100 / 1. 1.100
DEBUG 2014-09-20 11:45:40.356 [ffmpeg.exe-7-2] libpostproc 53. 0.100 / 53. 0.100
DEBUG 2014-09-20 11:45:40.403 [ffmpeg.exe-7-2] Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'E:\zInetTransfer\!(0TV) Various\The.Great.British.Bake.Off.S05E07.Pastry.PDTV.mp4':
DEBUG 2014-09-20 11:45:40.403 [ffmpeg.exe-7-2] Metadata:
DEBUG 2014-09-20 11:45:40.403 [ffmpeg.exe-7-2] major_brand : isom
DEBUG 2014-09-20 11:45:40.403 [ffmpeg.exe-7-2] minor_version : 512
DEBUG 2014-09-20 11:45:40.403 [ffmpeg.exe-7-2] compatible_brands: isomiso2avc1mp41
DEBUG 2014-09-20 11:45:40.403 [ffmpeg.exe-7-2] encoder : Lavf54.63.104
DEBUG 2014-09-20 11:45:40.403 [ffmpeg.exe-7-2] Duration: 00:57:55.84, start: 0.000000, bitrate: 803 kb/s
DEBUG 2014-09-20 11:45:40.403 [ffmpeg.exe-7-2] Stream #0:0(und): Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 703 kb/s, 25 fps, 25 tbr, 16k tbn, 50 tbc (default)
DEBUG 2014-09-20 11:45:40.403 [ffmpeg.exe-7-2] handler_name : VideoHandler
DEBUG 2014-09-20 11:45:40.403 [ffmpeg.exe-7-2] Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 93 kb/s (default)
DEBUG 2014-09-20 11:45:40.403 [ffmpeg.exe-7-2] handler_name : SoundHandler
DEBUG 2014-09-20 11:45:40.403 [ffmpeg.exe-7-2] Output #0, h264, to 'pipe:':
DEBUG 2014-09-20 11:45:40.403 [ffmpeg.exe-7-2] encoder : Lavf56.3.100
DEBUG 2014-09-20 11:45:40.403 [ffmpeg.exe-7-2] Stream #0:0(und): Video: h264 (avc1 / 0x31637661), yuv420p, 640x360 [SAR 1:1 DAR 16:9], q=2-31, 703 kb/s, 25 fps, 25 tbn, 25 tbc (default)
DEBUG 2014-09-20 11:45:40.403 [ffmpeg.exe-7-2] Stream mapping:
DEBUG 2014-09-20 11:45:40.403 [ffmpeg.exe-7-2] Stream #0:0 -> #0:0 (copy)
DEBUG 2014-09-20 11:45:40.403 [ffmpeg.exe-7-2] Press [q] to stop, [?] for help
DEBUG 2014-09-20 11:45:40.403 [ffmpeg.exe-7-2] frame= 1 fps=0.0 q=-1.0 Lsize= 11kB time=00:00:00.04 bitrate=2172.8kbits/s
DEBUG 2014-09-20 11:45:40.403 [ffmpeg.exe-7-2] video:11kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000000%
DEBUG 2014-09-20 11:45:40.418 [New I/O worker #1] Creating pipe \\.\pipe\1411224340418ffmpegaudio01
DEBUG 2014-09-20 11:45:40.418 [New I/O worker #1] Creating pipe \\.\pipe\1411224340418audioout
DEBUG 2014-09-20 11:45:40.418 [New I/O worker #1] Creating pipe \\.\pipe\1411224340418tsmuxerout.ts
DEBUG 2014-09-20 11:45:40.418 [Thread-39] Waiting for pipe connection \\.\pipe\1411224340418ffmpegaudio01
DEBUG 2014-09-20 11:45:40.418 [Thread-40] Waiting for pipe connection \\.\pipe\1411224340418audioout
DEBUG 2014-09-20 11:45:40.418 [Thread-42] Waiting for pipe connection \\.\pipe\1411224340418tsmuxerout.ts
DEBUG 2014-09-20 11:45:40.543 [mencoder.exe-8] Starting D:\Program Files\Universal Media Server test\win32\mencoder.exe -ss 0 E:\zInetTransfer\!(0TV) Various\The.Great.British.Bake.Off.S05E07.Pastry.PDTV.mp4 -quiet -quiet -really-quiet -msglevel statusline=2 -ovc copy -nosound -mc 0 -noskip -of rawvideo -o \\.\pipe\1411224340262ffmpegvideo
DEBUG 2014-09-20 11:45:40.668 [mencoder.exe-9] Starting D:\Program Files\Universal Media Server test\win32\mencoder.exe -ss 0 E:\zInetTransfer\!(0TV) Various\The.Great.British.Bake.Off.S05E07.Pastry.PDTV.mp4 -quiet -quiet -really-quiet -msglevel statusline=2 -channels 6 -ovc copy -of rawaudio -mc 0 -noskip -oac lavc -quiet -quiet -lavcopts acodec=ac3:abitrate=448 -af lavcresample=48000 -srate 48000 -quiet -quiet -o \\.\pipe\1411224340418ffmpegaudio01
DEBUG 2014-09-20 11:45:40.778 [New I/O worker #1] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2014-09-20 11:45:40.778 [tsMuxeR.exe-10] Starting D:\Program Files\Universal Media Server test\win32\tsMuxeR.exe C:\_Temp.sys\universalmediaserver\pms-tsmuxer.meta \\.\pipe\1411224340418tsmuxerout.ts
DEBUG 2014-09-20 11:45:41.262 [mencoder.exe-8] Attaching thread: mencoder.exe-8
DEBUG 2014-09-20 11:45:41.278 [New I/O worker #1] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2014-09-20 11:45:41.731 [tsMuxeR.exe-10] Reading pipe: \\.\pipe\1411224340418tsmuxerout.ts
DEBUG 2014-09-20 11:45:41.918 [New I/O worker #1] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2014-09-20 11:45:41.950 [tsMuxeR.exe-10] Attaching thread: tsMuxeR.exe-10
DEBUG 2014-09-20 11:45:41.950 [mencoder.exe-9] Attaching thread: mencoder.exe-9
DEBUG 2014-09-20 11:45:42.050 [Thread-32] Result of \\.\pipe\1411224340262ffmpegvideo : true
DEBUG 2014-09-20 11:45:42.154 [Thread-49] SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net
DEBUG 2014-09-20 11:45:42.233 [Thread-39] Result of \\.\pipe\1411224340418ffmpegaudio01 : true
DEBUG 2014-09-20 11:45:42.357 [Thread-33] Forced reconnection of \\.\pipe\1411224340262videoout with result : true
DEBUG 2014-09-20 11:45:42.357 [Thread-33] Result of \\.\pipe\1411224340262videoout : true
DEBUG 2014-09-20 11:45:42.357 [Thread-33] Disconnected pipe: \\.\pipe\1411224340262videoout
DEBUG 2014-09-20 11:45:42.358 [Thread-40] Forced reconnection of \\.\pipe\1411224340418audioout with result : true
DEBUG 2014-09-20 11:45:42.358 [Thread-40] Result of \\.\pipe\1411224340418audioout : true
INFO 2014-09-20 11:45:42.459 [StartPlaying Event] Started playing The.Great.British.Bake.Off.S05E07.Pastry.PDTV.mp4 on your KalemSoft Media Player
DEBUG 2014-09-20 11:45:42.461 [StartPlaying Event] The full filename of which is: E:\zInetTransfer\!(0TV) Various\The.Great.British.Bake.Off.S05E07.Pastry.PDTV.mp4 and the address of the renderer is: 192.168.1.101
DEBUG 2014-09-20 11:45:42.757 [Thread-42] Result of \\.\pipe\1411224340418tsmuxerout.ts : true
DEBUG 2014-09-20 11:45:42.758 [Thread-49] 100.0% complete
DEBUG 2014-09-20 11:45:42.759 [Thread-49] Processed 0 video frames
DEBUG 2014-09-20 11:45:42.759 [Thread-49] Decoding AC3 stream (track 2): Bitrate: 448Kbps Sample Rate: 48KHz Channels: 2
DEBUG 2014-09-20 11:45:42.918 [ffmpeg.exe-7-Cleanup] Stopping process: ffmpeg.exe-7
DEBUG 2014-09-20 11:45:43.022 [Thread-49] 100.0% complete
DEBUG 2014-09-20 11:45:43.104 [Thread-32] Error: Pipe closed
DEBUG 2014-09-20 11:45:43.295 [Thread-49] 100.0% complete
DEBUG 2014-09-20 11:45:43.590 [Thread-49] 100.0% complete
DEBUG 2014-09-20 11:45:43.924 [Thread-49] 100.0% complete
DEBUG 2014-09-20 11:45:44.270 [Thread-49] 100.0% complete
DEBUG 2014-09-20 11:45:44.441 [New I/O worker #2] HTTP User-Agent: Lavf53.32.100
ERROR 2014-09-20 11:45:44.443 [New I/O worker #2] There is no inputstream to return for The.Great.British.Bake.Off.S05E07.Pastry.PDTV.mp4 [tsMuxeR]
DEBUG 2014-09-20 11:45:44.476 [New I/O worker #1] HTTP User-Agent: Lavf53.32.100
DEBUG 2014-09-20 11:45:44.542 [Thread-49] 100.0% complete
DEBUG 2014-09-20 11:45:44.825 [Thread-49] 100.0% complete
DEBUG 2014-09-20 11:45:45.122 [Thread-49] 100.0% complete
DEBUG 2014-09-20 11:45:45.419 [Thread-49] 100.0% complete
DEBUG 2014-09-20 11:45:45.720 [Thread-49] 100.0% complete
DEBUG 2014-09-20 11:45:46.013 [Thread-49] 100.0% complete
DEBUG 2014-09-20 11:45:46.315 [Thread-49] 100.0% complete
DEBUG 2014-09-20 11:45:46.608 [Thread-49] 100.0% complete
DEBUG 2014-09-20 11:45:46.962 [Thread-49] 100.0% complete
DEBUG 2014-09-20 11:45:47.002 [tsMuxeR.exe-10-Cleanup] Stopping process: tsMuxeR.exe-10
DEBUG 2014-09-20 11:45:47.002 [tsMuxeR.exe-10-Cleanup] Stopping process: mencoder.exe-8
DEBUG 2014-09-20 11:45:47.003 [Thread-40] Error: null
DEBUG 2014-09-20 11:45:47.003 [Thread-40] Disconnected pipe: \\.\pipe\1411224340418audioout
DEBUG 2014-09-20 11:45:47.003 [tsMuxeR.exe-10-Cleanup] Stopping process: mencoder.exe-9
DEBUG 2014-09-20 11:45:47.013 [Thread-38] Error :null
INFO 2014-09-20 11:45:48.539 [StopPlaying Event] Stopped playing The.Great.British.Bake.Off.S05E07.Pastry.PDTV.mp4 on your KalemSoft Media Player
DEBUG 2014-09-20 11:45:48.539 [StopPlaying Event] The full filename of which is: E:\zInetTransfer\!(0TV) Various\The.Great.British.Bake.Off.S05E07.Pastry.PDTV.mp4 and the address of the renderer is: 192.168.1.101
Re: 4.1.2
I think the issue reported above is mediainfo related. Going back to previous Mediainfo.dll and Mediainfo64.dll v.0.7.69 solved all the issues...
Re: 4.1.2
@Wolfgan thanks for the info, I've just rolled back MediaInfo to 0.7.69 until we can figure out why that happened
@Madoka thanks for reporting that, I'll have a look
Re: 4.1.2
How do i get a Beta build? Link?
Re: 4.1.2
@jumperzz2014 use UMSBuilder to build it
@Madoka the "External subtitles" text has been changed to "Stream". So before it was "Filename {External subtitles} and now it's "Filename {Stream Sub: SubRip}". If it's not working properly please add logs, I'll wait for your response before releasing 4.1.2
Re: 4.1.2
It's still not working like it used to. I'm on a PS3 so the subs need to be transcoded. Trying the latest commit 78006d564, I still get Filename [FFmpeg], but no {External Subtitles} or anything that says Streaming after that. Also, looking in the transcode folder does not show anything that says Streaming, but it does say [Sub: SubRip].
Re: 4.1.2
Is it fixed in the latest code?
