[Suggestion] Unknown Renderer Conf Tool
So I'm sitting here thinking woukdent it be great if UMS came with a tool to help isers build conf files on detection of an unknown render discovered in the log.
Capture the user agent info from the log.
Ask if any existing devices are similar, if yes then pipe add with user interaction input box, the user agent. If no, build out a new conf file.
Thoughts?
It might be a little advanced for some users but what if it was a button on the log tab?
Thoughts?
Universal Media Server Wiki!
