Transcoding quality tweaks on each resolution
I think there should be an option where we're able to manually tweak the Transcoding Quality settings based on a media's input video resolution.
Here's how I've imagined it:
Re: Transcoding quality tweaks on each resolution
interesting idea, but this setting is based on your LAN settings... So if your whole Network infrastructure is 1GB then the highest setting is fine.
If you have a mixed environment then set this to the wireless setting and everything else will be matched to it.
Universal Media Server Wiki!
Assuming you're talking about using the Wired/Wireless Automatic settings, they don't work well with my Powerline LAN adapter limiting my streaming speeds to ~4MB/s (and my wireless is even worse) unless I use H264TSAC3 which has issues when seeking on PS3.
yeah Powerline Lan adapaters -- those are the EoP devices right? (Ethernet over Power)
Ive never used those. I always hear bad things about them.
I for one could have used this.
I have 1GB LAN, but slow CPU and my Sony BraviaW5500 has a slow ethernet interface.
So, i could manage to play 720p in decent quality, but 1080 i would have to tweak even more,.. more compression, and even rescale output to make it fit.
A whole script interface for *all those would have been king.
Above would require that the user gives each render a "name" ( via UMS gui )
if(renderer.name == "LivingRoomTV"){
if(file.height > 720){
if(file.hasExternalSubtitles()) {...}else {...}
}else if(file.height > 540){
}else {
