Suggestion
slava494
Suggestion
Post by slava494 » Fri Jan 17, 2014 6:16 am
I have a good suggestion :-)
I have only one problem with UMS. I´d love to play my movies and videos wihtout transcoding. But subtitles don´t work without transcoding.
The "transcoding" file is not quite comfortable. Yes, I can force/skip transcoding for some extensions, but that doesn´t solve anything.
By my opinion, greate solution will be:
1. use subtitles without transcoding
2. or force/skip transcoding for some folders
P.S. sorry for my english, i´m not native speaker :-)
valib
Re: Suggestion
Post by valib » Fri Jan 17, 2014 8:26 pm
slava494 wrote: By my opinion, greate solution will be:
It was introduced in the version 3.0.0 three month ago. :)
Check the PS3.conf how to set you renderer.conf and make a test. It is not 100% guaranteed that it works. It depends on the renderer you have.
Wolfgan
Re: Suggestion
Post by Wolfgan » Mon Jan 20, 2014 6:18 am
It will be interesting to know which renderers it MAY work... anyone has a tentative list?
valib
Re: Suggestion
Post by valib » Mon Jan 20, 2014 10:03 am
For now it works for Panasonic, Samsung and WDTVLive. It may work for others but the testing of users is needed. No one of developers have all kind of renederers to test it.
DeFlanko
Contact:
Re: Suggestion
Post by DeFlanko » Tue Jan 21, 2014 5:45 am
yeah that would get expensive lol
Wolfgan
Re: Suggestion
Post by Wolfgan » Wed Jan 22, 2014 12:02 am
valib wrote:For now it works for Panasonic, Samsung and WDTVLive. It may work for others but the testing of users is needed. No one of developers have all kind of renederers to test it.
Thanks! I will test it on my WDTV and report back. Wolf
