GPU Acceleration - Intel QuickSync
guimagination
Post by guimagination » Fri Feb 21, 2014 8:54 pm
Hey guys
I just noticed that GPU Acceleration is not supported for the Intel HD 4600 GPU, integrated to the Core i 4000-Series
Considering that the QuickSync decoder is actually way faster than nVidia's and ATI's implementation and there's a LOT of people out there with Core i CPU's with integrated QuickSync-enabled GPU, I think it would be a nice touch to UMS to support it.
Thanks!
ExSport
Re: GPU Acceleration - Intel QuickSync
Post by ExSport » Fri Feb 21, 2014 10:34 pm
It is a question of MEncoder/FFMpeg support, not UMS itself.
In past Sherpya implemented dsnative library to Windows MEncoder and later SubJunk integrated it to his SBBuilds but I am not sure if it will work in your case (depends on CODECxHW used) or if latest SB versions are compiled with it or not.
More you can read here in forum or on Sherpya site:
http://oss.netfarm.it/dsnative/
Optimus_prime
Post by Optimus_prime » Wed May 14, 2014 5:26 am
Interesting ffmpeg fork to utilise Intel Quicksync. I'm yet to test myself, but looks promising.
https://github.com/drocon11/ffmpeg-qsv
