Bug fixes and minor re-factoring inside DLNAResource.java
master-nevi
Post by master-nevi » Sat Nov 29, 2014 4:34 am
Hi there,
I had submitted a pull request with some bug fixes on github but it didn't seem to get any traction, so I'm taking a stab at using the forum.
The following is a copy and paste from the original pull request, https://github.com/UniversalMediaServer ... r/pull/419 :
I'm a developing a personal iOS app to serve as a control point for my Sony TV (renderer) and my UMS. As you may know Sony TVs are very strict as far as DLNA protocol is concerned and I found and fixed a couple of bugs which allow for better DLNA compliance (and my project) to be possible.
The commit messages should speak for themselves. Please don't hesitate to ask me anything and if you're not satisfied, or maybe you prefer applying fixes to a certain branch, I don't mind reworking if it means my fixes will be applied:
1) [LOW PRIORITY] 075f902 Allow the code path which creates the DLNA.ORG_PN string to be entered if the renderer is configured to use accurate DLNA.ORG_PN. The renderer configuration file for my BraviaEX had the "AccurateDLNAOrgPN" defined but not "DLNAOrgPN" and because of this, a necessary code path to create required DLNA header flags was not taken. I took these two options to mean that only one or the other should be defined in the configuration files, so fixing the code the way I did seemed like the logical thing to do. If my assumption is wrong then I could easily just add the "DLNAOrgPN" to my renderer's config and be done with it.
2a) [HIGH PRIORITY] e28ef8e Allow the DLNA.org content features header value to be set correctly when the method which sets necessary instance variables had not been called yet. Basically there's a method called getDidlString() which although it's a getter, oddly sets instance variables which are needed to ensure getDlnaContentFeatures() returns the correct header strings. So I had to call it before the return. Having a getter set instance variables is certainly a code smell to me, so I refactored this part in the next commit (3)
2b) [REFACTOR OF 2a] 82f48e0 Refactor the DLNA.ORG_OP and DLNA.ORG_PN flag instance variables into methods as they require a renderer configuration to be generated.
