Drop support for old HTTP Engine V1?
mfulgo
Post by mfulgo » Sat Jan 24, 2015 7:59 pm
I'd like to propose dropping support for the old HTTP Engine. I suspect there aren't really any users changing their UMS.conf to not use the default V2.
Technically, it would be a breaking change (so, semantic versioning would say that it needs to wait until version 6.0.0), but I'd like to remove the old code sooner than that. I can rip it out and log an error if the user happens to be using that setting... or we could deprecate it first, give a warning if its used, and rip it out later.
What do you think?
SharkHunter
Re: Drop support for old HTTP Engine V1?
Post by SharkHunter » Sun Jan 25, 2015 7:47 am
I use v1 :)
nickhere
Post by nickhere » Sun Jan 25, 2015 8:41 am
I use v1 :)
somebody old and resistant to upgrade to new and better tec :)
Post by SubJunk » Sun Jan 25, 2015 9:38 am
I think I remember that some users had problems with v2 interacting with their renderers so they used v1, ages ago.
nickhere
Post by nickhere » Sun Jan 25, 2015 10:33 am
What the latest? What the best for you to use?
Post by SubJunk » Sun Jan 25, 2015 1:27 pm
I've never changed it from the default (v2) but I've read people saying it has fixed an issue to change to v1, can't remember details.
mfulgo
Post by mfulgo » Sun Jan 25, 2015 5:46 pm
I'd be all for fixing whatever the issue is in V2...
Post by SubJunk » Sun Jan 25, 2015 7:01 pm
I have a feeling the issue was on the old PS3 Media Server forums, and may have been a dead end anyway; users often change 5 settings at once and it fixes the issue and then they attribute the fix to the wrong setting. Who knows.
Why do you use v1, SharkHunter?
SharkHunter
Post by SharkHunter » Sun Jan 25, 2015 8:33 pm
SubJunk wrote:I have a feeling the issue was on the old PS3 Media Server forums, and may have been a dead end anyway; users often change 5 settings at once and it fixes the issue and then they attribute the fix to the wrong setting. Who knows.
Sometime back in the days I had an issue (speed,start delay or whatever) with V2 so I changed to v1 and then never changed back.
What is the reason for removing it? As long as you don't change the APIs that are used from Request(v1|v2) towards the rest of UMS it really doesn't matter right? If you change those APIs we'll have other (bigger) problems...
mfulgo
Post by mfulgo » Mon Jan 26, 2015 3:48 am
I'm not sure why that would be, as long as I were to change everywhere that's calling into them, but that's off topic.
As for the issue you had with V2, it's quite possible that it's resolved with the switch to Netty 4; when I did that, I noticed some definite improvements in memory usage and the lack of the delayed streaming bug that made me investigate switching to 4 in the first place.
But, yes, you are correct. It doesn't really matter. I'm just trying to clean up the code base as much as possible; lines of code directly correlates to bug count, and if we can phase out features that are unused or have (better) replacements, that makes it easier to reason about what the program is doing.
