Version 7.1.0 released
erick diangilis
Re: Version 7.1.0 released
Post by erick diangilis » Fri Jun 22, 2018 1:55 am
hi subjunk! i've tested this new version 7.1.0 on the ps4 media player using the standard model not the ps4 pro. it worked fine for me i watched a bunch of stuff and listened to some music without any disconnections or memory bugs, the playback is also fine with a wired network with no stuter or audio out of sync the sound is also fine. transcoding videos also worked ok comparing the lastest software this new version is the best so far very stable and clean.
thanks again for this new release keep up with the good work. :)
J_345
Post by J_345 » Sun Jun 24, 2018 4:14 am
ps4 keeps disconnecting at around every 15 mins will try smart tv and see if it does it that way also
update: i went back and downloaded the previous version 7.0.1 and the problem doesn't exist so its something with 7.1,0 that is disconnect every 15 mins are so
wikig1itch
Post by wikig1itch » Mon Jun 25, 2018 4:23 pm
I can confirm I am suffering from the same issue as J_345 has stated on my PS4. I was trying to watch a 1080p video file but it would constantly crash to the "cannot read file" screen every 10 minutes or so. I have reverted back to 7.0.1 and the same video file runs without a hitch. I think I'll be sticking to 7.0.1 for good amount of time.
erick diangilis
Post by erick diangilis » Wed Jun 27, 2018 12:54 am
that's odd for me is just the opposite i had a lots of problems with the 7.0.1 like vídeos starting from the end, crashing during long pauses and continuing playing some disconnections here and there but this new one is working flawllessly no bugs or crashes. but i think maybe is duo to messing up with configurations and every person has a diffrent network in their homes.
Post by SubJunk » Fri Jun 29, 2018 3:24 pm
boss wrote:
Sun Jun 17, 2018 10:17 pm
I tried V7.1.0 (Linux headless) and UMS won't start.
It gets java heap space errors and crashes before starting completely.
EDIT: I deleted the data and database folders and restarted and now UMS starts OK.
What about UMS v4 and v5? It would be useful to know when the bug started for you. It would be best to reproduce it on a fresh install
boss
Post by boss » Fri Jun 29, 2018 4:28 pm
I have a couple of problems trying to run an earlier version.
Since installing V7.1.0 I have updated mediainfo and libmediainfo to 18.03. To run earlier versions of UMS mediainfo and libmediainfo 0.7.79 is required. The packages are so old that they are no longer in the repository for my Gentoo Linux server.
Also when I bought my LG WebOS 3.5 TV it had issues with photo files and some videos. This was rectified in V6.4 (from memory).
I Think it is the LG WebOS TV which causes the problem so prior to V6.4 I don't think it will work correctly.
At present, I am running UMS with the cache turned off and run a cron job every 2 days to restart UMS. This restarts it before it crashes with the java heap space errors.
I have also increased the heap space to 1GB.
I turned on caching about a week ago to see how that went with V7.1.0. UMS ran for about 12 hours before it crashed. Nothing was using UMS during that time although the LG WebOS TV was on for a lot of the time.
Trubbleguy
Not sure if this is happening with others
Post by Trubbleguy » Sat Jul 07, 2018 5:16 pm
I have been having an issue with this build,(which i have worked around by shutting down UMS), where all the movies are locked in place and i cannot rename or delete them, is anybody else experiencing this issue?
erick diangilis
Post by erick diangilis » Sun Jul 08, 2018 2:12 am
for me is working ok so far no issues.
yukonluke
Post by yukonluke » Mon Jul 09, 2018 11:15 am
Hi, sorry to bother you.
I'm getting a "no mountable file systems" error when trying to open the mac dmg (UMS-7.1.0.dmg). I've downloaded it twice, once with Safari and again with Chrome.
I'm running OS X 10.11.6
N3phastus
Post by N3phastus » Thu Jul 12, 2018 12:41 pm
Same problems as before... after running after a few hours it will use all memory and throttle the processor to 90%.
back to 6.8
Developing should concentrate in fixing problems instead of putting new and useless features ...
cheers
