Poll: Do you use "Clean install" option on Windows?
Yes
12
36%
No
21
64%
Total votes: 33
Post by SubJunk » Mon Sep 24, 2018 9:05 am
We are interested in knowing how many people use the "Clean install" option on Windows, which puts the program into a clean state with its settings and font cache
wazer
Re: Poll: Do you use "Clean install" option on Windows?
Post by wazer » Mon Sep 24, 2018 4:36 pm
I used to, but until virtual folders settings are implemented into the gui, I'm not going to, since im too afraid that it will delete my settings I did in notepad ever since you introduced me to virtualfolders.
Madoka
Post by Madoka » Mon Sep 24, 2018 7:07 pm
I have in the past when I had problems or went from n.x.x to n+1.x.x. I haven't in a long time.
Foxprime
Post by Foxprime » Tue Sep 25, 2018 12:11 am
I use it only if i have some problems
erick diangilis
Post by erick diangilis » Tue Sep 25, 2018 4:05 am
i Always use every new version since i don't change too much settings it usually took less than five minutes to set things the way i like.
con_1974
Post by con_1974 » Tue Sep 25, 2018 9:51 am
Thanks for asking, but I never used it.
fguzmant
Post by fguzmant » Thu Sep 27, 2018 3:55 am
Only if have an error using standar update.
pipin
Post by pipin » Sun Sep 30, 2018 9:38 pm
I voted no, but I use it if I run into problems or if there is a new major release.
Regards,
Jens
Uzerrr
Post by Uzerrr » Tue Oct 02, 2018 4:11 am
I used to, but since my Phillips is very stubborn and I need to set some things in a exact way to work I don't use it anymore :)
WAusJackBauer
Post by WAusJackBauer » Wed Oct 03, 2018 2:42 am
I use it
