Version 3.1.2.1 is released
General:
This release fixes a video compatibility bug affecting some users.
Changes since 3.1.2:
  • General:
    • Fixed a video compatibility bug affecting some users
Upgrade Notes:
For 3.0.0-b1 and newer:
No action necessary.
For all versions below 3.0.0-b1:
Madoka
Re: Version 3.1.2.1 is released
Post by Madoka »
Thanks for your hard work!
Now that you can't select both ffmpeg and tsmuxer in the ffmpeg settings, which one is preferred, if on Windows to a PS3?
Thanks.
Madoka wrote:Thanks for your hard work!
Thanks.
You're very welcome :) I set the default to tsMuxeR since it has a long history of stability for us, and I've had some problems with FFmpeg muxing personally
D-Kalck
Post by D-Kalck »
Thanks a lot, the duration bug is fixed !
sapsa
Post by sapsa »
thanks for fix ! I will check if running hedless linux UMS will trow OutOfMemory again :-)
server: C2D [email protected] 3GB RAM
network: wired 1000MB/s
OS: Linux 13.10 64bit
cheekyboy
Post by cheekyboy »
Thank you too Subjunk ;)
b0ris
Post by b0ris »
Great job! Only one questiond, does the plugin (Channels) install work now?
