Version 3.3.0 is released
General:
This release lets you further customize your server name, automatically muxes more types of files, improves video compatibility, especially on Panasonic TVs, and more!
Changes since 3.2.0:
  • General:
    • Added the option to toggle the display of the profile name after the server name on the renderer
    • Added a warning on the Status tab if the UMS port is being blocked
    • Added some missing entries to UMS.conf
    • Added automatic video scaling to renderer resolution limits in FFmpeg
    • Added the ability to use asterisks for the "Force transcoding" and "Skip transcoding" options
    • Added config option "itunes_library_path"
    • Improved detection of which videos should be muxed automatically when using MEncoder or FFmpeg
    • Fixed files with compatible video but incompatible audio not muxing video
    • Fixed support for outputting 24-bit FLAC files as 24-bit by muxing them with video
    • Fixed audio playback if VLC is enabled
    • Made server restarts more reliable
    • Made sure FFmpeg outputs a compatible colorspace when transcoding to H.264
    • Made sure the transcode folder appears before files instead of after (below)
    • Renamed config setting "ffmpeg_font_config" to "ffmpeg_fontconfig"
    • Renamed config setting "hide_new_media" to "hide_new_media_folder"
  • Renderers:
    • Improved video compatibility on Panasonic TVs
    • Updated the PS3 image
    • Updated the XBMC logo
  • Languages:
    • Minor language tweaks
    • Renamed "Advanced Monitoring" to "Include in New Media folder"
Upgrade Notes:
For all versions below 3.2.0:
If you have enabled FFmpeg's fontconfig or hid the New Media folder, you will need to re-apply those settings.
For all versions below 3.0.0-b1:
DeFlanko
Contact:
Re: Version 3.3.0 is released
Post by DeFlanko »
Very nice! Good job team!
Sent from my SGH-T999 Using ForumTouch for Android
Uzerrr
Post by Uzerrr »
Nice! You're still kicking :D Thank you!
Wolfgan
Post by Wolfgan »
Thx for the new release!
sapsa
Post by sapsa »
virtual_folders = name|/mnt/path,/mnt/path2;name2|/mnt/path3; <-- dosn't work
it gave exception that "/mnt/path2;name2| could not be readed.
virtual_folders_file + json file work ok
and why it make a folder "/" which I see its real root '/' - and both UMS.conf files dont include it. Is it a bug then ?
I removed folders from my config, default config is not edited. and at virtualfolders.conf I dont include any folders with name '/'
server: C2D [email protected] 3GB RAM
network: wired 1000MB/s
OS: Linux 13.10 64bit
Hi sapsa. The note in UMS.conf explains what went wrong:
# Note: Backslashes must be doubled. For example, if you have a folder named
# SubFolder inside ParentFolder, write it like ParentFolder\\SubFolder
phrozenstare
Post by phrozenstare »
thanks for the update.
one thing though with all these frequent updates lately any chance bringing back the update feature within UMS
phrozenstare wrote:thanks for the update.
It's working for me, is there a bug we don't know about?
sapsa
Post by sapsa »
SubJunk wrote:Hi sapsa. The note in UMS.conf explains what went wrong:
Ain't backslash \ use in winOS ?
weren't slashs / use on Linux ?
If for both I should use \\ then ok.
But why then when using only virtualfodlers.conf I end up with "/" ? Should i use double backslash in virtualfolders.conf too ?
yetiboy
Post by yetiboy »
Option to both check for update and check automatically for updates is greyed out for me (Mac version).
yeti
