FAQ | Forum | Tracker | Code
Version 1.4.0 is released
Postby SubJunk » Wed Jul 18, 2012 11:08 pm
General:
Changes since 1.3.0:
  • General:
    • Many improvements to FFmpeg, from audio sync to file-support to stability
    • Updated MPlayer and MEncoder for Windows to SB36, which:
      • Supports a lot more file formats and colour-spaces
      • Improves audio/video sync, especially with PAL (25FPS) videos
    • Added FFmpeg multithreading option
    • Updated FFmpeg for OS X to 57d5a224
    • Added a GUI config editor for those who like to edit manually
    • Improved audio/video sync when using MEncoder
    • Improved audio channel detection
    • Fixed support for some plugins
    • Added support for TX3G (MPEG-4 Timed Text) subtitles
    • Added support for WebM videos downloaded from YouTube
    • Fixed DV video detection
    • Fixed "Definitely disable subtitles" option with ASS/SSA subtitles
    • Fixed default audio/subtitle priority options
    • Fixed running on headless servers
    • Windows 7 and Vista users are reminded to run as administrator before attempting to automatically update
    • Fixed multithreading bug with MEncoder on Linux
    • Made layout more consistent
  • Plugin Installer:
    • Added Plugin Installer which lets you automatically browse plugins and install them, see this page for details: viewtopic.php?f=8&t=152
  • Web:
    • Added new default web video engine: FFMpeg Web Video
    • Updated WEB.conf with working default video streams
    • Added support for new web protocols: mmsh:// and mmst://
    • Added The Onion to the default video feeds
  • Languages:
    • Updated Simplified Chinese (thanks, lovenemesis!)
    • Updated Czech (thanks, valib!)
    • Updated English
    • Added image for Hebrew subtitle choosing
Upgrade Notes:
If you would like to take advantage of improved default settings and new engines (recommended) you can delete your old configuration files before installing a new version. For Windows users they are in ProgramData/UMS/.
The PMS developers.
glebb for building the OS X version.
Re: Version 1.4.0 is released
Postby Uppie » Thu Jul 19, 2012 8:23 am
Just popped in to say it just keeps getting better!
Thanx Subjunk and all contributors!
Uppie
Postby SubJunk » Thu Jul 19, 2012 10:21 am
Thanks Uppie! :D
Postby counsil » Thu Jul 19, 2012 10:56 am
I just donated $50.00 to you using the link on your blog (www dot spirton dot com). The donation is intended for you, and you alone. I will donate to the other developers at a later time. $ is really tight right now, but I wanted to at least show my thanks to you for all of your hard work.
counsil
Postby counsil » Thu Jul 19, 2012 10:58 am
Sorry, your blog is www dot spirton dot com. I couldn't find a way to edit my post.
This is off topic a bit, but is it possible to edit your posts? Also, how do you upload attachments?
counsil
Postby SubJunk » Thu Jul 19, 2012 12:46 pm
Thanks a lot for the donation, counsil! I really appreciate it :)
I've hopefully fixed the forum permissions now.
Postby gambit » Thu Jul 19, 2012 1:16 pm
sorry to say this but the installer plugin doesnt work, for example i cant get mediainfo doesnt download neither channels, was looking at the txt files for channels and psmencoder 1.60 doesnt exist anymore, developer deleted it and updated it to 1.6.1
gambit
Postby SubJunk » Thu Jul 19, 2012 1:25 pm
Thanks for reporting that, gambit. It will be updated soon :)
Postby gambit » Thu Jul 19, 2012 2:16 pm
in addition i am getting this error in the debug log when trying to play a link from icefilms
INFO 2012-07-18 22:14:35.615 [win32\ffmpeg.exe] Process C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe has a return code of 1! Maybe an error occured... check the log file
what does this mean
gambit
Postby SubJunk » Thu Jul 19, 2012 2:41 pm
gambit wrote:in addition i am getting this error in the debug log when trying to play a link from icefilms
what does this mean
Please create a new thread for this issue and attach your debug information
Next
Return to Announcements
Who is online
Users browsing this forum: No registered users and 1 guest
