Version 3.4.1 is released
General:
This release fixes bugs, improves stability and improves speed!
Changes since 3.4.0:
  • General:
    • Fixed MPlayer thumbnail generation
    • Fixed support for the MovieInfo and LastFMScrobbler plugins
    • Improved math accuracy
    • Improved thread-safety
    • Improved code speed
    • Minor GUI improvements
  • External Components:
    • Updated JGoodies Forms to 1.6.0
    • Updated Maven Checkstyle plugin to 2.11
    • Updated Maven Doxia Docbook Simple plugin to 1.5
    • Updated Maven FindBugs Plugin to 2.5.3
    • Updated Maven Site plugin to 3.3
    • Updated Maven Surefire Report plugin to 2.16
Upgrade Notes:
For all versions below 3.2.0:
If you have enabled FFmpeg's fontconfig or hid the New Media folder, you will need to re-apply those settings.
For all versions below 3.0.0-b1:
spkbr
Re: Version 3.4.1 is released
Post by spkbr »
Thank you SubJunk. LastFMScrobbler is working just fine now. Thanks!
Wolfgan
Post by Wolfgan »
Thanks for the release guys. Updating my install now. Wolf.
domain
Post by domain »
MediaInfo.dll still cause crash.
See also: viewtopic.php?f=9&t=1427
maildeamon
Post by maildeamon »
after update subtitles didn,t work anymore ?
rollin back to 330 and subs are back.
Madoka
Post by Madoka »
Thanks for the new release, SJ! So close to 3.1.4.
Subs work fine for me, but I'm on a PS3.
I've been meaning to ask, is there an advantage to using MPlayer to generate video thumbnails?
And since "A/V sync alternative method" is the default method, maybe it shouldn't be the "alternative" method anymore? Just wondering.
Madoka wrote:I've been meaning to ask, is there an advantage to using MPlayer to generate video thumbnails?
It's a good question, and it's explained in the tooltip for that option, but basically it's a tradeoff between speed and accuracy; MPlayer is slower at generating the thumbnails, but they are the correct aspect ratio, while FFmpeg is faster but all thumbnails are widescreen.
Madoka wrote:And since "A/V sync alternative method" is the default method, maybe it shouldn't be the "alternative" method anymore? Just wondering.
That's a good point, we should rename it! :)
maildeamon wrote:after update subtitles didn,t work anymore ?
On which device? Check the link in my signature :)
domain wrote:MediaInfo.dll still cause crash.
I'll rollback MediaInfo in the next version, sorry for missing that in this one :)
spkbr wrote:Thank you SubJunk. LastFMScrobbler is working just fine now. Thanks!
Cool, thanks for confirming :)
Wolfgan wrote:Thanks for the release guys. Updating my install now. Wolf.
You're welcome, hope it goes well :)
Monica Jae
Post by Monica Jae »
why do i keep getting this annoying
mediainfo64.dll error everytime i try to install? and i'm doing clean.
That probably means the program is still running while you're trying to install, or that it didn't close properly. You can open task manager and close "javaw.exe" manually, or restart your computer.
Monica Jae
SubJunk wrote:That probably means the program is still running while you're trying to install, or that it didn't close properly. You can open task manager and close "javaw.exe" manually, or restart your computer.
AAHHH that makes sense! ok, got it.
