Version 3.4.2 is released
General:
This release improves audio sync, fixes video playback bugs, improves stability and fixes other bugs!
Changes since 3.4.1:
  • General:
    • Improved fontconfig cache creation
    • The shared directory setting in the config is read more safely
    • Fixed video playback on some renderers including OPPO devices
    • Fixed a crash with certain files
    • Fixed a buffer display error
  • Languages:
    • Updated Spanish translation (thanks, AlfredoRamos!)
  • External Components:
    • Updated FFmpeg to builds from 2014-02-12, which:
      • Improves support for the following video codecs: H.264, H.265, MPEG-1, MPEG-2, VC-1, VP8, VP9
      • Improves support for the following audio codecs: AC-3, DTS, WMA
      • Improves support for the following containers: AVI, Matroska, MPEG-TS
      • Fixes memory leaks
      • Improves detection of 60FPS
      • Improves audio sync
    • Updated MediaInfo for Windows to 0.7.64, which:
      • Fixes crashes
    • Updated Netty to 3.7.0
Upgrade Notes:
For all versions below 3.2.0:
If you have enabled FFmpeg's fontconfig or hid the New Media folder, you will need to re-apply those settings.
For all versions below 3.0.0-b1:
DeFlanko
Contact:
Re: Version 3.4.2 is released
Post by DeFlanko »
Awesome!
So does this mean we can now use ffmpeg to transcode to these better? i'm thinking Chromecast and that h.264 issue we noticed.
Madoka
Post by Madoka »
Thanks for the new version and fixing the flashing buffer bug.
Wolfgan
Post by Wolfgan »
Thanks for the new release!
Phonism
Post by Phonism »
Can't thank you enough for this software - it is AWESOME!!!
UMS 5.3.0 - Java 8 update 60 - Windows 10 Pro 64bit
Intel Core i7-3770 - 8GB RAM
PS3 Slim 120GB
PS4
r0nin
Post by r0nin »
all you guys hard work is appreciated thanks!
cbsewell
Post by cbsewell »
I hate to say this, but every release after 3.4.0 doesn't work quite right with my PS3. FF and Rewind used to run somewhat smoothly; 3.4.1 and 3.4.2 jump by minutes backwards and forwards. Copying MPG files produced by mkv2vob no longer show % copied, but copy like .mkv's with no estimate of completion.
CappySpectrum
Post by CappySpectrum »
I experienced this with 3.4.0 for OS X. Sadly the crash locked up the player.
Watched a film tonight *ahem* Gravity with 3.4.2 - OS X, fluid playback. Great experience on the Panasonic DMP-BDT330.
Optimus_prime
Post by Optimus_prime »
CappySpectrum, what version of OS-X and was it the normal version of UMS or Java 7 version (will have Java 7 in the title)
CappySpectrum
10.8.5 and non Java. I don't have Java installed. UMS-3.4.0.dmg UMS-3.4.2.dmg
