Version 3.6.1 is released
Post by SubJunk » Fri May 16, 2014 5:20 pm
General:
This release improves support for many file types, fixes many bugs, updates translations and more!
Changes since 3.6.0:
  • General:
    • Made resuming more intuitive
    • Fixed the aspect ratio of thumbnails by default (thanks, tdcosta100!)
    • Fixed the buffer going nuts after automatic subtitle conversion (thanks, tdcosta100!)
    • Fixed support for URLs in playlists
    • Fixed error with thumbnails of resume files (thanks, tdcosta100!)
    • Fixed the user interface when hiding advanced options
  • Languages:
    • Made more strings translatable
    • Updated Czech translation
    • Updated Russian translation (thanks, Tianuchka!)
  • External Components:
    • Updated FFmpeg to builds from 2014-05-05, which:
      • Improves support for many containers and codecs
      • Fixes bugs
    • Updated h2database to 1.3.176, which:
      • Improves stability
    • Updated MPlayer/MEncoder for Windows to SB57, which:
      • Adds AAC encoding support
      • Improves H.265 support
      • Improves speed
      • Fixes bugs
Upgrade Notes:
For all versions below 3.2.0:
If you have enabled FFmpeg's fontconfig or hid the New Media folder, you will need to re-apply those settings.
For all versions below 3.0.0-b1:
DeFlanko
Contact:
Re: Version 3.6.1 is released
Post by DeFlanko » Sat May 17, 2014 1:25 am
Excelent!
Gareee
Post by Gareee » Sat May 17, 2014 3:09 am
Just a head's up.. when 3.6.0 gave me the update option today, and I selected it, it opened a zillion update windows, and the download progress meter was at a crawl. I finally closed it and did a manual update to 3.6.1. There might be some oddness going on with the auto updater.
Wolfgan
Post by Wolfgan » Sat May 17, 2014 3:11 am
Wonderful, thanks!
chewie
Post by chewie » Sat May 17, 2014 6:21 am
Confirmed. Same issue here.
CardcaptorRLH85
Post by CardcaptorRLH85 » Sat May 17, 2014 6:24 am
Gareee wrote:Just a head's up.. when 3.6.0 gave me the update option today, and I selected it, it opened a zillion update windows, and the download progress meter was at a crawl. I finally closed it and did a manual update to 3.6.1. There might be some oddness going on with the auto updater.
Yup, same issue here.
phrozenstare
Post by phrozenstare » Sat May 17, 2014 4:20 pm
confirmed i am getting the same problem with auto update i was going to mention too the only time it will find an update is is when i close out of UMS and go back in
Post by SubJunk » Mon May 19, 2014 2:35 pm
Thanks for the report and confirmations guys, it will be fixed in 3.6.2 :)
