Version 3.6.2 is released
Re: Version 3.6.2 is released
I am experiencing issues with 3.6.2 - until now UMS has been flawless for me.
UMS is installed on a win7 Pro based PC. The receiving devices are both Samsung model BD-D6500. Both receivers exhibit the same issue.
Whenever I power on one of these units it seems I must use "Restart Server" in UMS before I can see it, or wait a very long time. Frequently I get the message "Media Disconnected" while watching a program. If I leave the player at the "My Devices" screen I can watch as the UMS disconnects and (sometimes) reconnects.
UMS 3.6.2 is useless to me.
Any ideas as to what is causing this issue? Is there something I can try, or should I simply revert to 3.6.1?
UPDATE: Installed 4.0.0- 1a -- problem solved.
Keep up the great work!
- SharkHunter
- Developer
UMS doesn't reconnect/disconnect it is most likely your render doing this. The reason for your on/off of UMS is most likely that there are some dropped packets in the discovery/startup phase. Have you changed any thing in your setup?Mystif wrote:I am experiencing issues with 3.6.2 - until now UMS has been flawless for me.
And as always logs logs logs:
viewtopic.php?f=9&t=556
SharkHunter wrote:UMS doesn't reconnect/disconnect it is most likely your render doing this. The reason for your on/off of UMS is most likely that there are some dropped packets in the discovery/startup phase. Have you changed any thing in your setup?Mystif wrote:I am experiencing issues with 3.6.2 - until now UMS has been flawless for me.
I cannot explain it, I changed not one single thing beyond updating to 4.0.0-1a and the problem is resolved. Whatever the reason, it started and ended with 3.6.2. The machine is a file server, there is little beyond UMS and VLC on it.
