Version 4.1.1 is released
General:
This release improves speed, improves file support and fixes bugs!
Changes since 4.1.0:
  • General:
    • Made videos start faster sometimes when using FFmpeg
    • Improved accuracy when parsing rare files
    • Improved folder population speed
    • Fixed x264 transcoding when using recent versions of MEncoder
    • Fixed Windows Java 6 versions trying to update to Java 7
  • Renderers:
    • Fixed external subtitle streaming support on Samsung TVs
  • Languages:
    • Updated French translation (thanks, Kirvx!)
    • Updated Spanish translation
  • External Components:
    • Updated MPlayer/MEncoder for Windows to SB59, which:
      • Fixes decoding of PGS subtitles
      • Improves support for many containers and codecs
      • Improves 3D compatibility on some devices
      • Fixes bugs
    • Updated Netty to 3.9.4, which:
      • Improves security
      • Fixes bugs
      • Improves memory use
jrolson
Re: Version 4.1.1 is released
Post by jrolson »
Add Roku support please...
Wolfgan
Post by Wolfgan »
jrolson wrote:Add Roku support please...
Did you try installing Roku Media Player channel? http://www.roku.com/channels/#!details/ ... dia-player
It's what Roku owners say it allows them access DLNA servers...
xLuckless
Post by xLuckless »
Just to be clear, "Netty" is what handles the Webbrowser video's, right? the ones you access with ipadress:9001.
xLuckless wrote:Just to be clear, "Netty" is what handles the Webbrowser video's, right? the ones you access with ipadress:9001.
It handles the interactions between the renderer and UMS
raprop
Post by raprop »
HI LG-WebOS work perfect with 4.0.0 and profile LG LA 6200, other LG work fine too include the string into renderer file SupportedSubtitlesFormats = SUBRIP,ASS
with 4.1.1 or 4.1.0 failed to stream or is too slow....
Thx
Kreeker
Post by Kreeker »
I'm loving the improved folder population speed :D
jrolson
Post by jrolson »
Yes, they show up but they don't play. Needs transcoding...
Wolfgan
Post by Wolfgan »
Then create a custom profile following http://www.universalmediaserver.com/faq ... erSupport1 . It seems the Roku DLNA supports most common formats as per http://support.roku.com/entries/423946- ... l-support-
raprop
Post by raprop »
Hi!!
I detect with 4.1.0 or 4.1.1 and LG TV. when try to play a mp4, the ums transcode to mpeg but in 4.0.0 is detected h264 and send to TV perfectly.
in the 4.0.0 work perfect streams the subs when add SupportedSubtitlesFormats = SUBRIP,ASS to LGLA6200. This profiles works fine with LGWebOS and LG 60" top line 2013
Thx.
