Version 4.2.2 is released
General:
This release fixes Xbox One detection, adds support for several new devices, improves folder population speed, fixes bugs and more!
Changes since 4.2.1:
Upgrade Notes:
For Linux versions below 4.2.1:
In 4.2.1 we renamed many of the renderer configuration files, so we recommend clearing the "renderers" folder before updating.
- General:
- Improved compatibility of H.264 transcoding when using MEncoder
- Customized buffer color
- Fixed Live Subtitles
- Renderers:
- Added support for Hama IR320 (thanks, Enrice!)
- Added support for Roku 3 (incomplete) (thanks, weyrava and drocket!)
- Added support for Panasonic ET60 Series TVs (thanks, Enrice!)
- Added support for Samsung F5100 Blu-ray Disc players (thanks, maracucho!)
- Added support for Samsung Galaxy S5 (thanks, FlyMcDoogal!)
- Added support for Sony PlayStation Vita (incomplete) (thanks, Verequies, Balmung and xubz!)
- Fixed Xbox One detection (thanks, Whogie!)
- Languages:
- Updated Spanish translation (thanks, AlfredoRamos!)
- External Components:
- Updated JNA to 4.1.0, which fixes bugs
- Updated Maven Exec Plugin to 1.3.2, which fixes bugs
- Updated Maven Findbugs Plugin to 3.0.0, which fixes bugs
- Updated Maven Javadoc Plugin to 2.10.1, which fixes bugs
- Updated Maven Jdepend Plugin to 2.0, which fixes bugs
- Updated Maven Site Plugin to 3.4, which fixes bugs
- Updated Netty to 3.9.5, which fixes bugs
Upgrade Notes:
Re: Version 4.2.2 is released
Thanks for the release! Just updated to it on windows, and on first load all video files are offered to be transcoded by ffmpeg in every renderer (had no time to investigate further and produce logs).
Did anyone observe anything like that? Wolf
Thanks for reporting this, Wolfgan. It's surprising since we didn't really make changes I would expect to cause this in this version, I'm interested to see logs if you can reproduce itWolfgan wrote:Thanks for the release! Just updated to it on windows, and on first load all video files are offered to be transcoded by ffmpeg in every renderer (had no time to investigate further and produce logs).
Great work. Will try it tomorrow, although 5.0 Alpha is working fine.
Regards,
Jens
Devices used with UMS : - Windows 7 PC, Samsung UE32 F4580SS, Samsung UE48H6600
Jens
Thankspipin wrote:Great work. Will try it tomorrow, although 5.0 Alpha is working fine.
Thanks for the new release. 4.2.2 is working fine for me (not everything is offered as transcoded). Also looking forward to 5.0.0-a2.
I noticed that 5.0.0-a1 does not defer to MEncoder for files with embedded fonts (like anime), unlike 4.2.1. Perhaps this was added after a1 was released? If so sorry....
hi, webos tv still not work when transcoding.
regards
regards
Fixes my Xbox One issue.. Thanks
My Xbox One still won't detect it, i'm using Mac and using the new 4.2.2 release. Anyone else having the same problem?
I am having the exact same issue! No matter what I try, it doesn't pick up my Xbox One but picks up my Xbox 360 just fine. Please fix.Becuzimbrown wrote:My Xbox One still won't detect it, i'm using Mac and using the new 4.2.2 release. Anyone else having the same problem?
