Version 5.0.0-b1 is released
General:
This release adds a major redesign of the Status tab, automatic reloading of external files, dynamic playlist support, improvements to the web interface and more!
Note: This is a beta release, which means it may be unstable. Your testing is appreciated!
Download:
Windows
Linux
OS X
Note: These unstable releases are for versions of Java from 7 upwards, but we will continue to release all stable versions in Java 6, 7 and 8 variations.
Changes since 5.0.0-a1:
  • General:
    • Major redesign of the status tab to show per-renderer information
    • Improved player control
    • Includes the possibility to allow UMS to control renders automatically
    • Web player can also be controlled
    • Automatic reloading of external files
    • Documentation updates
    • New xmb playlist folders with optional automatic starting, looping, and saving, editable from web or xmb
    • A Dynamic xmb playlist for on-the-fly playlist creation from web or xmb
    • Better bump/gui player playlists with optional automatic looping
    • Push playback support for chromecast and web browsers
    • Improved Chromecast support (cast from UMS webui/gui)
    • All changes from 4.2.1, 4.2.2 and 4.3.0
pulp
Re: Version 5.0.0-b1 is released
Post by pulp »
Someone tell us if they finally get Grooveshark working, please. :)
Madoka
Post by Madoka »
Nice new interface. Few quick observations.
I've noticed a few rare instances where the scrolling name does not appear under the renderer.
Also, the time displayed for the file (X/Y) does not stop if you pause the file such that X>Y at the end of the file. Actually, if the file is done playing, X still keeps ticking. And in the memory bar, is the blue part the video buffer? And the rest used by the program itself?
SharkHunter
Post by SharkHunter »
Madoka - The time values are a bit render dependent. If your render behaves "good" it will report the current position back to UMS and we update that in the gui. If it doesn't we use an internal timer to update this and since the render doesn't report time it most likely doesn't report when it pauses/starts/stops either so thats why. Not much to do actually (except maybe add a check to prevent X>Y but that will not do that much).
The memory bar at the bottom is how much heap the JVM uses out of it's total allowed size. The blue bar that becomes visible over each renders IP address is the video buffer. There is no total video buffer anymore it is included in the total memory.
pulp - I'll see if I can have a look. Songs do work.
jps92
Post by jps92 »
hi,
I see
12-09 10:40:00 Web conf path: C:ProgramDataUMS
12-09 10:40:00 Web conf permissions: file not found" in the trace
in the trace page. iIs there a bug ?
SharkHunter
jps92 wrote:hi,
I see
Nope. it just means you don't have a WEB.conf file and thus UMS will not add a WEB folder. If this wasn't intended (or if you've got some odd permissions so that the WEB.conf can't be read) you should probably reinstall/restore the WEB.conf/make sure it is readable by UMS.
sma76928
Post by sma76928 »
Hi it doesn't work on LG WEBOS TV
it transcode on mpeg 2 without audio and buffering all the time.
https://drive.google.com/file/d/0B1YgMb ... sp=sharing
SharkHunter
Does it work with 4.x? This is not something that has changed in 5.0 so if it works in 4 it should work.
Late-Z
Post by Late-Z »
Somethings different on Xbox One, I can no longer stream .mkv:s without transcoding. I could do this fine on the 5.0aplha. When I open the GUI there are 2 instances of the Xbox One and when clicking them the other one has the play controls and the other one obly has the used .conf line.
shaina
Post by shaina »
xbox 360 still not working on this release ??
