FAQ | Forum | Tracker | Code
Version 2.4.2 is released
Postby SubJunk » Sun Feb 17, 2013 7:47 pm
General:
This release fixes a bug on some renderers where no files/folders were showing, updates FFmpeg for OS X and improves the Clean Install option on Windows.
Changes since 2.4.1:
  • General:
    • Fixed bug on some renderers where no files/folders were showing
    • The Clean Install option on Windows deletes the MPlayer Contconfig cache
  • External Components:
    • Updated FFmpeg for OS X to 1.1.2, which:
      • Adds automatic multithreading
      • Improves QuickTime format support
      • Supports decoding WMA Lossless
      • Supports decoding RealAudio Lossless
      • Fixes security issues
      • Fixes over 150 bugs
      • Supports RTMP
      • Supports Opus
      • Supports encoding external subtitles
      • Supports decoding DTS-HD
Upgrade Notes:
For versions prior to 1.5.0:
For all versions:
Cameron Spiers for building the OS X version
Re: Version 2.4.2 is released
Postby kuroukage » Sun Feb 17, 2013 8:47 pm
@SubJunk:
This breaks Infidel's update.jar. ;(
I get this error when loading up 2.4.2:
INFO  2013-02-16 23:43:11.582 [main] Configuration error: java.lang.NoSuchMethodError: net.pms.encoders.FFMpegVideo.<init>(Lnet/pms/configuration/PmsConfiguration;)V
EDIT: Just confirmed it too. I went back to 2.4.1 and it loads just fine.
黒影
kuroukage
Postby Optimus_prime » Sun Feb 17, 2013 9:23 pm
Project updated on sourceforge
Optimus_prime
Postby kuroukage » Sun Feb 17, 2013 9:24 pm
Optimus_prime wrote:Project updated on sourceforge
What changed since the release of 2.4.2?
黒影
kuroukage
Postby SubJunk » Sun Feb 17, 2013 10:57 pm
The OS X version is released :)
kuroukage wrote:This breaks Infidel's update.jar. ;(
Yeah that will have been caused by https://github.com/UniversalMediaServer ... db101bfb1d
Thanks!
Postby kuroukage » Sun Feb 17, 2013 11:38 pm
SubJunk wrote:Yeah that will have been caused by https://github.com/UniversalMediaServer ... db101bfb1d
2.4.2 completely breaks Jumpy? Or just the update.jar Infidel made?
EDIT: Jumpy is working fine in 2.4.2. Just the update.jar is broken now.
黒影
kuroukage
Return to Announcements
Who is online
Users browsing this forum: No registered users and 1 guest
