Version 2.5.2.1 is released
Post by SubJunk » Tue Mar 19, 2013 9:54 am
General:
You can download it from the front page. This is a Windows-only release because it fixes a Windows-only bug.
This release fixes a startup error affecting some users
Changes since 2.5.2:
  • General:
    • Fixed the startup error introduced in 2.5.2
Upgrade Notes:
For versions prior to 1.5.0:
For all versions:
odysseuscm
Re: Version 2.5.2.1 is released
Post by odysseuscm » Tue Mar 19, 2013 7:54 pm
unfortunately using the exe to launch UMS still brings up "Error: Could not create Java Virtual Machine. Error: A fatal exception has occurred. Program will exit." (Windows 7x64 with JRE 1.7.0.17)
But UMS runs fine when startet via the batch command.
Regards
Chris
Optimus_prime
Post by Optimus_prime » Tue Mar 19, 2013 8:14 pm
Chris,
Follow my instuctions in this post to fix your problems, viewtopic.php?f=9&t=736
You should though set your java memory to 768 during install to skip this error
odysseuscm
Post by odysseuscm » Tue Mar 19, 2013 9:57 pm
Thanks Optimus,
that did the trick!
sanjeev
Post by sanjeev » Wed Mar 20, 2013 1:24 pm
When is the mac version coming ? I am a big fan of UMS, but it has been no mac build for a long time. It is frustrating :(
Appreciate your help !
Sanjeev
Post by SubJunk » Wed Mar 20, 2013 1:39 pm
Hi sanjeev, there should be a mac version coming within the new day or so if all goes well :)
sanjeev
Post by sanjeev » Thu Mar 21, 2013 2:06 pm
Awesome I can see it now. Thanks a lot. Downloading..
Uzerrr
Post by Uzerrr » Fri Mar 22, 2013 9:01 am
With this version when I try to watch 1080p .mkv video after 2minutes of watching movie skips another few minutes of movie. Javaw.exe hits 50% of CPU of my 4GHz PhenomII x4. (TV - Phillips PFL5007)
Everything is fine with 2.5.0.
