Version 6.6.0 released
coodie
Re: Version 6.6.0 released
Post by coodie » Sun Mar 19, 2017 10:23 pm
Hi Sami32,
Thanx for the tip!
Here is my logfile https://www.dropbox.com/s/oczgjfa7uaouu ... e.zip?dl=0
Not sure if I could reproduce the problem. PS3 just says "No files found" after opening the ISO folder.
Same for DVD (VOB files).
Sami32
Post by Sami32 » Sun Mar 19, 2017 11:01 pm
Thanks coodie :+1:
Do you mind if i ask you to post one other log with the same ISO file and the UMS version that work for you ?
As i'm not familiar with this, it shouldl be helpful to be able to compare.
So, i guess that you question was explictly related to PS3, as it look fine to me, meaning that if you try with an other renderer it'll play fine.
With your PS3, it say that the file is unsupported by your renderer.
So as i'm not a PS3 owner and never used ISO playing, an other "working" log to compare should help.
coodie
Post by coodie » Sun Mar 19, 2017 11:47 pm
Hi Sami32,
Thanx for your reply.
I also use 8Player (light) on my IPad, this is a free IOS app. With this app I connect to Universal Media Server.
Same problem here for ISO and DVD files. When I open the folder the IPad says: "Empty".
This happens for all ISO files and all DVD (VOB) files, it is not just one particular ISO file.
Is this helpfull?
coodie
Post by coodie » Sun Mar 19, 2017 11:49 pm
@Sami32,
I used to run version 5.1.4.
In this version I was able to play ISO and DVD files.
Sami32
Post by Sami32 » Mon Mar 20, 2017 12:39 am
1) Any log from your UMS 5.1.4 version ?
2) If your try to stream directly the ISO to your TV, it's play fine, is that correct ?
coodie
Post by coodie » Mon Mar 20, 2017 12:58 am
Thanx Sami32,
If I run 5.1.4 and start a movie the computer freezes, that is why I upgraded.
So I cannot create a log.
I do not know how to run Universal Media Server on the TV.
Since I am apparently the only one with this problem in version 6.6 I will just try to install all other versions available and see what version works for me.
Thanx for your help so far sami32!
coodie
Post by coodie » Mon Mar 20, 2017 1:26 am
@Sami32,
Version 7.0.0-a1 solved my problem.
I can run ISO and DVD files again! :-)
OzBrickie
Post by OzBrickie » Wed Apr 05, 2017 5:55 am
Hello All
Can you tell me why AviSynth MT wants to be installed now?
Oz
polster74
Post by polster74 » Fri Apr 14, 2017 10:06 am
Since the Windows 10 Creators Update, I can no longer add shared folders (shuts UMS down) :?:
