[Solved] srt subtitles stopped working a while back
Re: srt subtitles stopped working a while back
Thanks for all the info here guys, we are looking into this
pipin
Post by pipin »
SubJunk wrote: Fri Jul 19, 2019 9:59 am Thanks for all the info here guys, we are looking into this
Thanks, the strange thing is, my Samsung UE32 F4580SS is still working with external subtitles.
Would logs with different versions and using both tvs helpful?
Regards,
Jens
Yes that would be ideal, then we can see exactly what the difference is between what is being sent to the TV
pipin
Post by pipin »
SubJunk wrote: Thu Aug 22, 2019 2:19 pm Yes that would be ideal, then we can see exactly what the difference is between what is being sent to the TV
I will try to grab some logs in the next days.
Regards,
Jens
pipin
Post by pipin »
Ok here are my logs.
I just started the same file with 7.6.2:
Both working: Samsung UE32 F4580SS (schlaf) and Samsung UE48H6600 (Samsung LED38..)
With 9.0.0
Working: Samsung UE32 F4580SS
Not working: Samsung UE48H6600
ums_dbg_9_0_0.zip
Version 9.0.0
(94.01 KiB) Downloaded 1209 times
ums_dbg_7_6_2.zip
Version 7.6.2
(71.72 KiB) Downloaded 1054 times
Regards,
Jens
It would really help to know if the problem exists in 7.9.0 since that will let us know if it is a v8 problem https://sourceforge.net/projects/unimed ... e/download
Edit: Whoops I see on page 1 of this thread that the problem has existed since version 7.8.0 so that's good, because that means it is hopefully easier to fix.. I'll have a look and make a test build soon
pipin
Post by pipin »
SubJunk wrote: Tue Sep 17, 2019 2:07 pm It would really help to know if the problem exists in 7.9.0 since that will let us know if it is a v8 problem https://sourceforge.net/projects/unimed ... e/download
Yeah, I tried 7.9.0 too, same behaviour.
Regards,
Jens
Ok I can see that between versions 7.6.2 and 7.7.0 there was a lot of refactoring to the code that handles network requests so I will upload some builds to get feedback from you, to narrow down which commit caused the problem
