Noob Question
infidel
Re: Noob Question
Post by infidel » Thu Dec 11, 2014 5:56 am
fivecats wrote:Well I went back and did that now. Played fine as always when cued from the Onkyo.
I may have misunderstood your post up up above:
fivecats wrote:i can navigate and play the music that is stored on my PC via Universal / DLNA using the Onkyo remote contol & Onkyo window.
which I took to mean "It plays ok from the UMS gui's Onkyo renderer popup window (but not from the web interface)". If it doesn't play at all when controlled from UMS either way, then yes, the issue is with the Onkyo itself since your logs show it requesting data and data being sent. I don't think it will make any difference, but you can try adding this to Onkyo-TXNR717.conf:
ChunkedTransfer = true
fivecats
Re: Noob Question
Post by fivecats » Thu Dec 11, 2014 8:50 am
Hey, thanks for all your help. Didn't seem like that conf change helped. I think it is something with the Onkyo .... but i appreciate your time!
ExSport
Re: Noob Question
Post by ExSport » Mon Dec 22, 2014 10:47 pm
But if it works to push playback from another SW then it should work.
Try to find working SW and if you will be successful, WireShark trace can help (or only info that it works from another SW so problem is not Onkyo)
joyfreelance5
Re: Noob Question
Post by joyfreelance5 » Wed Dec 24, 2014 10:01 pm
I do on the Web interface, i can't get the the music to stream to the Onkyo from there. :shock:
