Sub-folders???
alfaslide
Sub-folders???
Post by alfaslide » Sun May 08, 2016 9:36 pm
UMS can not see the subfolders. How can it be done?
I find this feature indispensable.
valib
Re: Sub-folders???
Post by valib » Sun May 08, 2016 10:52 pm
I don't understand how it is possible because it is a standard feature. Please follow instruction at viewtopic.php?f=9&t=556
alfaslide
Re: Sub-folders???
Post by alfaslide » Mon May 09, 2016 12:05 am
I explained myself badly, I meant that UMS see the subfolders... but I would like it to sound files in those subfolders without having to open them. An example: I have folders devoted to musical genres. For example I have the "Soul" folder and inside there are folders of Otis Redding, of James Brown, Aretha Franklin etc ... but if I want to listen to all the Soul music mixed can not. UMS tells me that there are no multimedia files in the folder. In fact, there are sub-folders ... but UMS does not read those files. I can only listen to the files that are contained in a folder but not the ones that are in subfolders.
alfaslide
Re: Sub-folders???
Post by alfaslide » Tue May 10, 2016 2:56 am
Please, nobody help me?
squadjot
Re: Sub-folders???
Post by squadjot » Tue May 10, 2016 3:35 am
Please follow the instruction link Valib gave you.
valib
Re: Sub-folders???
Post by valib » Tue May 10, 2016 5:13 am
If I understand you well you are looking for something like Media database. In the UMS it is called "Cache" (maybe it is time to rename it). You can Enable the cache and disable the Hide the "Cache" folder at the Navigation/Share Setting tab. Than you can see in the root folder the #- Cache -# subfolder where are "Audio", "Photo" and "Video" subfolders. In the "Audio" folder is also the "By Genre" subfolder in which the subfolder "Soul" should be if some audio files have the Genre tag set properly.
alfaslide
Re: Sub-folders???
Post by alfaslide » Tue May 17, 2016 9:48 am
valib wrote:If I understand you well you are looking for something like Media database. In the UMS it is called "Cache" (maybe it is time to rename it). You can Enable the cache and disable the Hide the "Cache" folder at the Navigation/Share Setting tab. Than you can see in the root folder the #- Cache -# subfolder where are "Audio", "Photo" and "Video" subfolders. In the "Audio" folder is also the "By Genre" subfolder in which the subfolder "Soul" should be if some audio files have the Genre tag set properly.
hello Valib, I want make a for a slideshow and I would to play the images that are in the subfolders.... Sometimes I would to play the files in only one folder, sometimes I would to play the files in some folders, sometimes I would play all the files in all folders....
valib
Re: Sub-folders???
Post by valib » Wed May 18, 2016 9:03 am
Unfortunately that features are not implemented in the UMS. You can try to make the m3u playlists with the files you want to play.
alfaslide
Re: Sub-folders???
Post by alfaslide » Thu May 19, 2016 11:16 am
But dear friend.... "unfortunately"?
It seems to me absurd.
All those who have a photo archive have divided into subfolders!
And all these have hundreds or thousands of photos.
we should move all the images in a single folder? Unacceptable.
Possible that I read so many people asking questions about esoteric subjects, but this requirement is not common to ALL?
I can understand that there will be some technical issues for which a feature so obvious is impossible to achieve. But I can not accept anyone asking this feature! That all are surprised when make a request so obvious!
Excuse the outburst, but it seems to me a world of crazy!
valib
Re: Sub-folders???
Post by valib » Fri May 20, 2016 5:43 am
I don't understand why do you react in such way. Nobody force you to put images in one folder. I have also my photos divided into sub-folders. The problem is that the UMS is a media server and you evidently don't know what it means. The media server does only what the renderer is asking for. To play media also from sub-folders is the renderer responsibility not the UMS that is why I offered you to make a m3u playlists as a workaround. We can discuss with other developers if could be possible to implement such feature but now I don't have any idea how.
