tsMuxerR-new.exe update
Sami32
Post by Sami32 » Mon Jun 20, 2016 5:24 am
i really use it to avoid transcoding :D , until FFmpeg upgrade do the job.
I already use it without any trouble for now. Many improvements (M2TS, PGS...), but i am not sure they are used by UMS though.
http://www.videohelp.com/software/tsMuxeR
http://www.videohelp.com/software/tsMux ... #changelog
Re: tsMuxerR-new.exe latest update (2.6.12)
Post by SubJunk » Mon Jun 20, 2016 8:04 am
Hi Sami32, we had that version and then had to roll back because it caused issues on PS3. It's a shame!
Sami32
Post by Sami32 » Mon Jun 20, 2016 8:21 am
So sad...for PS3 users, but for one time it's not for Panasonic :lol:
What kind of issues ? related to SEI ?
Post by SubJunk » Mon Jun 20, 2016 4:59 pm
There was a file that we submitted as a sample to the developer of tsMuxeR but he abandoned the project soon after so it was never addressed. You can probably see more details on doom9
Sami32
Post by Sami32 » Tue Jun 21, 2016 3:40 am
Hello Subjunk,
Thank for your answer.
so, if i believe you :D the problem since 2.6.9 (SEI issue solved) was with the use of MEncoder, but actually i tought that we are now only using it for a better VOBSUB subtitles support, since FFmpeg did greatly improved (ASS, AAC, AC3, DTS, PCM, PTS, SPS...) these last weeks ?
So, if MEncoder isn't used it will possibe to PS3 users to be able to use the last version ?
http://forum.doom9.org/showthread.php?t=168539&page=61
Originally Posted by physic View Post
I've checked your sample on a PS3 too. I haven't got problem either with Insert SEI parameter on and off.
You're right, it only happens when muxing with MEncoder like this:
mencoder input.mkv -ovc copy -nosound -mc 0 -noskip -of rawvideo -o pipevideo
mencoder input.mkv -ovc copy -of rawaudio -mc 0 -noskip -oac copy -o pipeaudio
Just wanted to report that all versions after 2.2.3b still have the regression that causes broken playback on PS3 with some videos when muxed via MEncoder
Could these alternatives links interest somebody :
https://github.com/kierank/libmpegts
https://github.com/Akagi201/ffmpeg-tsmuxer
https://github.com/google/shaka-packager
N.B. I disabled MEncoder, using only the latest FFmpeg and tsMuxeR and it's fine for me, but i don't know for PS3 users...
I am just wondering if all the code with MEncoder is again necessary anymore ? :roll:
Post by SubJunk » Tue Jun 21, 2016 9:47 pm
That would be worth re-testing, however tsMuxeR is disabled by default and probably will never be enabled by default again, unless the implementation is made more stable.
