Optimal quality
Optimal quality
Thanks for a great program!
What settings/engine do you recommend for optimal picture and sound quality?
Re: Optimal quality
Hi Dallen, thanks for the kind words!
The default settings are the best for video and audio quality. If you have a DTS audio receiver you can also enable "Keep DTS tracks" on the Transcoding Settings tab to ensure maximum audio quality.
Re: Optimal quality
Easy enough, I can do that!
Do you also know if it should be possible to play 10bit movies without having to transcode them? I use Samsung Allshare on my E8005. I tried playing some 10bit movies but they wont open.
Re: Optimal quality
10-bit support on renderers is almost non-existent so yes you probably have to transcode them, unfortunately
Re: Optimal quality
Aha owwkay, too bad yes.
One last question, I am streaming 1080p-files wirelessly from my computer, does quality somehow adept to bandwidth? Or should I just see stutter/lag if the network wasn't beeing able to follow?
Re: Optimal quality
From version 3.0 onwards we have a feature that adapts the quality for the content, so if you use the new release (3.0.0-a1) and go through the configuration wizard that will let you use this new feature.
