Way to play files on android phones?
t_jay17
Post by t_jay17 » Mon Jan 02, 2017 4:21 pm
Is there a way to stream vr videos to an android phone with a vr headset?
atamariya
Re: Way to play files on android phones?
Post by atamariya » Fri Jan 13, 2017 5:15 pm
t_jay17 wrote:Is there a way to stream vr videos to an android phone with a vr headset?
VR videos are normal videos in terms of codec. So you should be able to stream it via UMS.
Onlyzen
Post by Onlyzen » Sat Aug 26, 2017 7:42 pm
I think yes, you should. First, a distinction should be made: 360-degree videos, often just called 360 Videos, can be viewed with Cardboard and other VR headsets, but they’re not quite the same as VR videos. That’s because proper VR videos add the illusion of depth.
prachijain
Contact:
Post by prachijain » Thu Apr 12, 2018 8:17 pm
Sami32 wrote:
Thu Jan 05, 2017 10:31 am
AFAIK only VLC video engines used by UMS support it for now, but it will not be upgraded to 3.0 version before some more UMS version, so patience... ;)
But you can always have a look at these links:
https://support.google.com/jump/answer/6395819
https://github.com/google/spatial-media
https://github.com/kronihias/ambix
https://francois.pitie.net/2016/05/05/3 ... be-upload/
https://vrwiki.wikispaces.com/MPlayer
Samples:
https://vrwiki.wikispaces.com/oculus+Rift+videos
Really useful resource, thanks for sharing!
