Subtitle encoding problem
petria
Post by petria »
recently updated from 6.4.0 to 6.5.3 UMS. After that subtitle encoding is not working anymore. Subtitles are
external .srt files and contains Finnish special characters: ÖÄÅöäå ... They are after update shown incorrectly by
the Samsung TV. Before update subtitles were working fine.... Any ideas where to seeks solution for this ?
Also did try with 7.0.0-a1 version, same problem with that.
Sami32
Re: Subtitle encoding problem
Post by Sami32 »
Did you tried to set the encoding manually ?
In the "Transcoding settings" tab, select "Subtitles settings" tab and change "Auto detect" to "ISO-8859-1 Western european" or "Codepage 1252".
You could be interested be this:
https://github.com/UniversalMediaServer ... -Subtitles
If it do not solve your issue, just follow these simple steps:
viewtopic.php?f=3&t=556
Please, don't forget to give feedback, as it could help other users or us to improve/fix issue.
