transcode only if bitrate higher than described
Hi all.
I'm from Ukraine, so sorry for my bad English.
Can you add small future:
in SUPPORTED MEDIA FORMATS parameter - video bitrate.
If bitrate of supported video greater then described then transcode video, else streem.
In my case, a TV will not play files with a bit rate higher than 20-25 Mbit/s. It's not foult of your program, its foult of my TV, but this setting would correct the problem!
Thank you! Greetings from Ukraine!
Re: transcode only if bitrate higher than described
What type of TV do you have? do you know if its using a specific CONF file?
Universal Media Server Wiki!
